Old 01-13-2019, 04:12 PM   #1
4Kilefamily's Avatar
2009 34' Classic
North Richland Hills , Texas
Question Rattle from shock absorbers
Does anyone else have a rattling sound coming from the shock absorber outer casing rattling against the inner piston when rolling over bumps or rocks at slower speeds?? I notice it most when I'm driving in a campground with my window open and I can hear the shocks rattling as I go over small bumps in the road.
Rod & Teresa "On the road again."
4Kilefamily is offline   Reply With Quote
Old 01-13-2019, 04:56 PM   #2
1994 34' Excella
Warren , Manitoba
I have never heard a shock rattle!! I imagine that you are hearing stones in your hubs. If the shocks rattled they would be totally destroyed. Have someone drive it while you are beside the trailer and listen close.
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 01-13-2019, 04:59 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
What happens is, the outer dust shell comes loose from the shock piston, and will rattle. While it won't hurt anything, short-term, it would be a good idea to replace it.
Old 01-14-2019, 04:26 PM   #4
2009 34' Classic
Thanks Overlander63, that's what I've been hearing, but I didn't know how common it was. Planning on replacing all 6 this Spring.
But I did find a second problem while checking out the rattle. I also have two "Nev-R-Lub" caps that come off over time and rattle inside the wheel hub cap cover.
I take off the tire and push them back on and they eventually come back off.
Any solutions for tightening up the "Nev-R-Lub" caps to help keep them on????
Old 01-14-2019, 04:54 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
The only "rattle" we hear when slow rolling...the little balls in the centramatic wheel balance rings.
Are you so equipped?
“Side effects from the Network News Broadcast?…ask your Doctor." 🤪
RLC
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old Yesterday, 03:34 PM   #6
2009 34' Classic
No centramatic balancing rings.
Old Yesterday, 06:02 PM   #7
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Some of my 6 shocks rattle. I've learned to live with it...
Old Yesterday, 06:37 PM   #8
Well Preserved
1993 21' Sovereign
A couple of drops of BLUE Loctite on the flange that goes into the hub should do the trick. Make sure you mention it to the guy that takes your brake drums off, for obvious reasons.
Old Today, 07:32 AM   #9
dznf0g's Avatar
Oswego , Illinois
Electric brakes or Dexter Disc brakes? If Disc, the pads do not fit well into the calipers. They rock back and forth in the caliper and create a rattle. I only hear it with the windows down and low speeds. It goes away when the brakes are lightly applied. Dexter knows about this and I was a "field tester" for two different anti-rattle clips they were developing. Neither worked and I gave up calling them. This was about 5 years ago.
-Rich-
Delco shock absorbers TomW Shocks 13 06-21-2016 12:48 AM
shock absorbers for 1969 Tradewind TCL Member Introductions 1 04-06-2006 09:46 AM
Shock Absorbers for 62 Overlander Silverfly Shocks 6 07-14-2004 02:18 PM
Shock Absorbers for Ford Excursion Ed Keyes Tow Vehicles 2 06-12-2004 06:29 PM
Shock absorbers changing gary 1970-79 Tradewind 8 03-10-2004 07:15 PM
