Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 06-24-2009, 09:40 AM   #1
Profile:  1986 34' Limited
Delano , Minnesota
Rats, broken shock mount
I WAS replacing the shocks on our 86 Limited 34. All six of them! All 12 rusted shock mounting bolts. I soaked them good for several days with the best penetrate I could find. Even so, one of the axle shock mounts fractured while untorquing the nut. 23 years of rust!
So now what? The shock mount is welded in the axle bracket. Looks like I need a torch to cut out the old one, and then a machine shop to make a new one, and then a welder to weld in the new one while keeping it all strong and square.
Is there an easier way? Anyone ever had this kind of touble?
David
Old 06-24-2009, 10:15 AM   #2
Commercial Vendor
Profile:  Corona , California
David
Sock studs and shock brackets are both available.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 06-24-2009, 11:20 AM   #3
blickcd's Avatar
Profile:  1979 31' Sovereign
Batavia , Ohio
Yeah, that happened to 3 out of 4 of mine. What I did was cut off the remnants of the stud, then drill a 3/8" hole thru the frame where the stud was. Of course you start with a small drill bit and work up to a 3/8". For bolting on the shock I used a heavy grade 3/8" bolt and washers, and put a spacer sleave over the bolt, which gave it an outside diameter that snuggly fit the rubber shock bushing. As I recall I had to cut the sleave to length so it was no more longer than the shock bushing is wide.
Christopher
blickcd is offline   Reply With Quote
Old 06-24-2009, 11:25 AM   #4
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
automotive stores sell replacement shock studs. you might try looking there.
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
richinny is online now   Reply With Quote
Old 06-25-2009, 06:29 AM   #5
Delano , Minnesota
Thanks for sharing your experience with this problem. My shock mount stud is about 1" diameter at the end welded into the axle bracket. It appears to be the same size stud welded into the frame on small end of the shock. I've tried grinding the weld off, but the weld penetration is good from the factory, as expected. It would take a lot of drilling to remove that much metal to get the stud free of the bracket.
Maybe I can find the correct shock mount stud, and then find a good welding shop. That would save machining a new one.
I hope Airstream is using all plated fasteners now. I think this minor maintenance job (replacing shocks) would have been problem free with good plated hardware that doesn't rust.
David
Old 06-25-2009, 07:04 AM   #6
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
David
I would place a call to Inland before putting a whole lot of effort in to machining and such. You might be able to take of this without quite as much effort as described.
And you're correct. It seems like nothing is ever as easy as should be when working on these things.
Regards,
Kevin
Experience can be a difficult teacher...You usually get the lesson first...And the instruction afterwards...
Kevin245 is online now   Reply With Quote
Old 06-25-2009, 08:47 AM   #7
Commercial Vendor
David
The correct original shock studs with the mounts for your axle, is available.
They are available in left and right hand mountings.
Plating them would serve no benefit, since they are welded to a cast torsion arm.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-04-2009, 06:01 AM   #8
Delano , Minnesota
Inland RV Had the Shock Mounting Stud!
I called Inland RV and Greg knew exactly what I was talking about. (Unusual because most people don't!) Inland RV sent one out and it was exactly what I needed.
I have ground off the weld, and drilled out the broken shock mounting stud from the bracket. Now I will take the Airstream to a good weld shop and in five minutes I should have the new shock mount welded in place.
Name:	Shock Stud Broken.jpg
Rats!! warnicks Member Introductions 12 03-09-2008 07:23 PM
3 out of 4 Broken Shock Mounts? Lookinghard Shocks 8 04-14-2006 10:08 PM
Broken rear upper shock mount Robfike Mechanics Corner - Engines, Transmission & More... 7 02-27-2006 09:06 PM
The Rats ate it. jt6128 Interior Restoration Forum 6 03-21-2005 02:56 PM
Broken shock absorber stud jasper2222 Axles 7 01-31-2005 07:34 PM
