Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 07-04-2009, 06:01 AM   #1
Profile:  1986 34' Limited
Delano , Minnesota
Inland RV Had the Shock Mounting Stud!
I called Inland RV and Greg knew exactly what I was talking about. (Unusual because most people don't!) Inland RV sent one out and it was exactly what I needed.
I have ground off the weld, and drilled out the broken shock mounting stud from the bracket. Now I will take the Airstream to a good weld shop and in five minutes I should have the new shock mount welded in place.
Name:	Shock Stud Broken.jpg
Rats!! warnicks Member Introductions 12 03-09-2008 07:23 PM
3 out of 4 Broken Shock Mounts? Lookinghard Shocks 8 04-14-2006 10:08 PM
Broken rear upper shock mount Robfike Mechanics Corner - Engines, Transmission & More... 7 02-27-2006 09:06 PM
The Rats ate it. jt6128 Interior Restoration Forum 6 03-21-2005 02:56 PM
Broken shock absorber stud jasper2222 Axles 7 01-31-2005 07:34 PM
