Old 05-09-2010, 12:01 AM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
OMG, Shocks again
This has been discussed to death, and I think I have read every post in the "Running Gear - Axles, Brakes, Wheels & Tires" forum and still do not have an answer.
What is the correct shock for a 1966 Globetrotter, it is a vertical shock not the horizontal type like on my 1975 Tradewind.
The most recommended shocks are NAPA/Monroe 95004, O'Reilly's 20718, Monroe 33033 and 555003, but these are all gas filled shocks.
I am almost positive I need a hydraulic static shocks, I am sure the vertical shocks for an Airstream should just dampen the movement whether the shock is being pushed or pulled.
It's been beaten to death, time to put it out or its misery. What is a correct part number?
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 05-09-2010, 01:29 AM   #2
Bruce.
If you wish, you could use Airstream's shock, which is a horizontal shock, but does work vertically as well.
But, you would have to shorten the vertical bracket.
Sooner or later, you will have to do that anyway.
Then, you question would be permanently answered, and the source of supply would always be easy.
OMG!!! They're all yellow! AIR-Quarius The Pet Forum 8 04-15-2009 10:04 PM
Shocks or no shocks with new Dexter Axles? nick6930 Axles 5 04-13-2009 03:41 PM
OMG - I've got water!!! wannaroam General Repair Forum 9 08-18-2008 11:13 AM
OMG someone please save these poor Birds SaabLover Off Topic Forum 7 05-31-2008 07:30 PM
OMG!! Getting 2nd dog - can't wait!! Mackhopp The Pet Forum 43 04-24-2008 06:22 PM
