Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 12-22-2007, 10:34 PM   #1
Jim Foster
Jim Foster's Avatar
Profile:  1965 17' Caravel
1983 27' Excella
Walnut Grove , California
We had to replace the torsion axel on our '65 Caravel. The old axel had shock mounts. The new axel did not have shock mounts. I was told by the axel company, Hayes Axels in Ontario, CA, that their torsion axels are used on all types of trailers, horse trailers, car haulers and others. They said that Airstream is the only one who adds shock mounts to torsion axels. Others don't bother. They said that torsion axels don't seem to have the "fight back" and bounce that conventional leaf springs have. I did not add them to my unit.
Old 12-22-2007, 11:48 PM   #2
68 Tradewind
greywolf's Avatar
Profile:  1968 24' Tradewind
Crestview , Florida
That's news to me, I though the axels came with shock mounts. You could always wled some mounts on latter if the ride seems to give you problems. My Airstream is the only trailer I have that has shocks, all the others use just the leaf springs, all though that list includes utility and boat trailers.
FOR THOSE WHO ARE ABOUT TO 'STREAM, WE SALUTE YOU!
greywolf is offline   Reply With Quote
Old 12-23-2007, 05:43 AM   #3
Commercial Vendor
Profile:  Corona , California
If shocks were not needed, then why does Airstream install them?
Shocks are used to dampen vertical movements.
A torsion axle, to some degree does that, but not as much when it's combined with shocks.
Airstream engineers disagree with Hayes.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 12-23-2007, 07:29 AM   #4
toastie's Avatar
1955 22' Safari
Michigan , The Great Lakes State
question to Andy
Will be replacing axle on a 1955 Airstream Safari, and thinking about re-using the leaf spring. Will have the leaf spring inspected. What are you thoughts.
I attached a few pictures.
ID:	51366   Click image for larger version
toastie is offline   Reply With Quote
Old 12-23-2007, 08:26 AM   #5
Profile:  , Minnesota
Images: 59
Very nice springs. I would add skid plates.
markdoane is online now   Reply With Quote
Old 12-23-2007, 08:41 AM   #6
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1995 21' Sovereign
1947 22' Liner
Valley View , Texas
Images: 42
Just a thought
I'd consider reinstalling those with the axel mounted below the spring. It will give you longer legs, but not out of any comfort zone. Even on my short Caravel those service station sloped entrys come mighty close to testing out the drain fitting skid plate and removing the trap cover. A higher ground clearance is also handy on some boondock trips.
Melody Ranch is online now   Reply With Quote
Old 12-23-2007, 09:01 AM   #7
Commercial Vendor
Originally Posted by toastie
question to Andy
If your springs check out, I would think that they could use a good coat of paint, and probably some bushings too.
Adding skid plates is OK, but it won't help much more than letting the trailer drag on the U-bolts.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-24-2007, 01:44 AM   #8
68 Tradewind
greywolf's Avatar
Crestview , Florida
I think mounting the springs on top of the axels is a good idea, too. I did that on a large utility trailer that I hauled heavy loads with and it helped, especially when I need clearance at the landfill. It didn't really have a noticable affect on the center of gravity either.
Courtesy parking-- water, elect. and wi-fi.
To those who are about to Stream-I salute you!
Old 12-24-2007, 06:38 AM   #9
robandzoe's Avatar
Profile:  1958 30' Sovereign of the Road
Plymouth , New York
Images: 26
Skid plates and welding
First, I would not weld anything to the Torsion Axle as welding may damage it's rubber components inside. For a trailer the size of a Caravel, I think you'll be fine (what spec axle did you install) as the shock travels very minimal anyway (assume you'll not be off roading it anyway). As to the skid plates - rather than that, I'd put a set of those curved "Tire Saver" steel springs that mount under the axle that the axle drops onto in case of blowout, instead of the rim dropping onto the tire and shredding it. Good luck.
Rob
Rob, Zoe', Stanton, Bryce and Braedon Baker
Past President WDCU
Do you Listen to the www.theVAP.com
Plymouth, NY 13832 WBCCI #2820
Courtesy parking
robandzoe is offline   Reply With Quote
Old 12-24-2007, 08:53 AM   #10
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
question to Andy
If you get a straight(no drop) axle, you can still mount the axle over the springs as designed, and raise your ground clearance. The springs looks good, though rusty. New springs are pretty inexpensive, and metal fatigue could cause a leaf to crack. They are a half century old, you know.
(No Longer at Inland RV)
Old 12-24-2007, 09:46 AM   #11
urbanfood's Avatar
Profile:  1956 22' Flying Cloud
Venice , California
toastie,
the consensus on here seems to be you can definately re-use the leaf springs (after your inspection). they'll need some lubing up and new bushings. i went through the same conversation with myself. it seems some people prefer the leaf springs to the torsion axle. i decided to go with the latest and greatest and upgrade to torsions axle with kodiak disc braking system. much more expensive than rebuilding the leaf springs though.
rob,
do you have a picture of that thing? is there something that works like that for a torsion axle? since i'm still working on the frame i could incorporate something.
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 10-29-2008, 08:49 AM   #12
Diesel1's Avatar
Profile:  1967 24' Tradewind
Kingman , Arizona
Now that some time has passed how do you like your Hayes axle, would you reccomend Hayes axles? What about no shocks? Good or bad? Thanks, John
Diesel1 is offline   Reply With Quote
Old 10-29-2008, 10:29 AM   #13
Commercial Vendor
Hayes does not and will not build an axle to duplicate the original axles used on Airstream trailers. Their starting angles, load ratings and brakes used, do not match, or for that matter, even exceed the original Airstream specs.
Therefore what you get, is what you must live with.
The shock subject has been covered many many times, on these Forums.
Hayes, does not know how an Airstream behaves, which leaves them as an outsider when to comes to shock advice.
Someone, on this Forums, sometime back, did some tests, with and without shocks.
Their results clearly showed an improvement in the stability of the trailer, when shocks were used.
We just turned out an axle job yesterday, that were it not for the shocks, alll 4 wheels, hub and drums, and axle shafts would have separated from the trailer.
Individual re-engineering of a variety of Airstream specs, especially axles, usually winds up as a real headache, for the second owner, when the person that made those changes finds out that it didn't work out as they thought.
E-BAY is full of modified stuff, that is cleverly hidden from the photo's and description.
We see these problems every week in our shop.
Mickey Mousing has a place, but not with an Airstream, unless the owner is willing to accept problems associated with the poor choices.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-29-2008, 11:05 AM   #14
Commercial Vendor
Hayes axle Ontario facility update.
As of a few minutes ago, the following information was obtained from Hayes branch, in Ontario, California.
1. They have not sold retail in many years.
2. They have not built any torsion axles at their Ontario plant in over 10 years.
3. Corporate has deleted many of their dealers a frew years ago, "that did not spend enough money with them," like at least $50,000.00 per year, net.
4. The local Dexter plant in San Bernardino, California, has officially closed as of October 27th, 2008.
Andy Rogozinski
Inland RV Center
Corona, CA
Do I need shocks or not help please Joey 73 Shocks 17 05-16-2007 08:14 PM
A little birdy told me... Killo1 Tow Vehicles 5 09-08-2006 08:35 PM
shocks Al1 Shocks 1 07-11-2003 02:21 PM
Shocks: Chuck On The Road... 4 04-30-2003 03:46 PM
What shocks? Silver Annie Shocks 6 11-04-2002 12:14 AM
