Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 10-29-2008, 01:06 PM   #15
Diesel1's Avatar
Profile:  1967 24' Tradewind
Kingman , Arizona
Originally Posted by Inland RV Center, In View Post
Hayes axle Ontario facility update.
As of a few minutes ago, the following information was obtained from Hayes branch, in Ontario, California.
1. They have not sold retail in many years.
2. They have not built any torsion axles at their Ontario plant in over 10 years.
3. Corporate has deleted many of their dealers a frew years ago, "that did not spend enough money with them," like at least $50,000.00 per year, net.
4. The local Dexter plant in San Bernardino, California, has officially closed as of October 27th, 2008.
Andy, I need axles, and of course I am broke. So I am looking and learning. From looking at Dexter's on line info it appears to be a real pain to order their axles. However here in Kingman is a parts house that sell dexter & Hayes axles(remember we used to have the Ford Proving Ground here which was a big customer). If I take an old axle in they will order it no fuss. I am however a longtime Ford dealership mechanic, and as such am a firm beliver in the factory is almost without exception the best way to go as far as parts are concerned. So I am exploring and doing homework. I would very much apriciate a firm quote from you regarding my 1967 24" Tradewind. How much for bare axles( I already replaced the brakes with new loaded backing plates),& shocks including taxes & shipping. Thanking you in advance, John
Diesel1 is offline   Reply With Quote
Old 10-29-2008, 01:20 PM   #16
Commercial Vendor
Profile:  Corona , California
Our Henschen replacements, will have 12 inch brake flanges, not 10 inch as you would get with Dexter.
Also, we have a starting angle of 35 degrees, Dexter does not. If you use 45 degrees, Henschen and Airstream feel that angle is excessive and can cause problems.
We are not permitted to post prices. Please check your PM for them.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 10-29-2008, 01:36 PM   #17
Diesel1's Avatar
Kingman , Arizona
Andy, What is a 10 or 12 inch brake flange? And thanks for your prompt reply but in your reply no shipping cost ? If needed my zip is 86402. Thanks again, John
Old 10-29-2008, 01:41 PM   #18
Commercial Vendor
A 10 inch brake flange will only accept 10 inch brakes. A 12 inch flange will only accept 12 inch brakes.
Youe trailer was equipped with 12 inch brakes. Down grading to 10 inch would not be a good idea. If so, Airstream would have done that.
Are you going to use a residential or commercial address? It makes almost $100.00 difference in freight costs.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-29-2008, 01:49 PM   #19
Diesel1's Avatar
Kingman , Arizona
Thanks for the info, you are correct(as you already know) about the angles. I believe the Dexter had a 10,17,& 45 degree angle. Thanks for the brake info, I deffinatly want to keep the larger brakes. I will be using a commercial address. Thanks again, John
Old 10-29-2008, 02:09 PM   #20
Commercial Vendor
Starting angle are with zero load.
After a load takes place, a proper rated torsion axle will drop 10 to 12 degrees.
Therefore a 10 degree will position the trailer lower than intended, and the 17 degree will do the same.
A 35 degree starting angle will raise the trailer about 3 inches above the original starting angle. also 35 degrees loaded is the same as Airstreams 22.5 degrees, unloaded.
Your prices are in a PM.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-29-2008, 02:39 PM   #21
Diesel1's Avatar
Kingman , Arizona
Andy, Thanks for all the info. You are quoting me with shipping the same price as the local guy is quoting me. That is what I needed to know. I will use the factory parts. When I am ready I likely will come to your place and pick up the parts. In relation to the I-10 & the I-15 junction where are you located. Once again thanks for your speedy replys. John
Old 10-29-2008, 05:15 PM   #22
Commercial Vendor
We are about 20 to 25 minutes from I-10 and I-15.
Check your map for the junction of I-15 and 91, which is a little south of I-10.
From that junction, we are about 5 minutes away.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-29-2008, 06:42 PM   #23
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Diesel 1
Wise decision. I changed axles this yr. I ordered thru Andy and picked up at Henshen. Installed myself in about 3 hrs. Henshens spec's were so close to the original ('77) I had to gently convince them (with a plastic sledge) to slide up into the notches in the frame. All bolt holes lined up perfectly. Original parts is the only way to fly.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336
My your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 10-29-2008, 06:47 PM   #24
Profile:  Currently Looking...
Afton , Virginia
At the risk of sounding like an echo:
I once had a SOB trailer which did not have shocks. It would bounce all over the road, and on certain concrete roadways would just about make you sick if you saw the rear-view mirror. A hot-rod buddy of mine advised me to put shocks on; said if I would buy them, he would do the welding.
It was a vast improvement in handling, I could tow that trailer at 80 mph vice 50 over the same road.
Shocks are not nice, they are necessary.
regards
herrgirdner is offline   Reply With Quote
Old 10-30-2008, 10:57 AM   #25
68 Tradewind
greywolf's Avatar
Profile:  1968 24' Tradewind
Crestview , Florida
I've even had a situation where I had to fabricate my own shock mounts before welding them on, machine shop and welding rates may not be cheap, but it can certainly be accomplished.
In addition to shocks, I recommend the tires be balanced as well. A lot of tire stores will tell you that it's not neccessary to balance trailer tires. I believe these are guys who do not tow much. You do feel the vibration through the hitch and into the tow vehicle and it cause tire hopping. I even have the tires on my utility trailers balanced and this helps a lot on the highway.
Courtesy parking-- water, elect. and wi-fi.
To those who are about to Stream-I salute you!
greywolf is offline   Reply With Quote
Old 11-09-2008, 09:36 PM   #26
Diesel1's Avatar
Kingman , Arizona
Now that some time has passed how do you like your Hayes axle, would you reccomend Hayes axles? What about no shocks? Good or bad? Thanks, John
Jim I see you are online, I still wonder- how do you like/dislike not having shocks? Adios, John
Do I need shocks or not help please Joey 73 Shocks 17 05-16-2007 08:14 PM
A little birdy told me... Killo1 Tow Vehicles 5 09-08-2006 08:35 PM
shocks Al1 Shocks 1 07-11-2003 02:21 PM
Shocks: Chuck On The Road... 4 04-30-2003 03:46 PM
What shocks? Silver Annie Shocks 6 11-04-2002 12:14 AM
