Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 09-30-2006, 12:57 PM   #1
eikel1we's Avatar
Profile:  1975 25' Tradewind
, middle of the mitt
Send a message via AIM to eikel1we
Question Need shocking advise!
Can anyone send me in the right direction on replacing shocks on Cupcake, our '75 Tradewind? I don't know if they are the originals so how do I determine the correct shock brand and part #? How about the install - would there be any modifications? Recommendations welcome.
Ike
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
2004 GMC Yukon XL 2500
Michigan - "middle of the mitt"
eikel1we is offline   Reply With Quote
Old 09-30-2006, 02:02 PM   #2
Commercial Vendor
Profile:  Corona , California
Ike
Your shocks are Airstream standard "horizontal" shocks.
They are a "OEM" item, therefore available only from a stocking Airstream parts center.
They cost about $34.00 each.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 09-30-2006, 02:58 PM   #3
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
I would try going into NAPA they will measure them and just tell them there horizontal.
I would guess half that price, shocks are very cheap!
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 09-30-2006, 03:04 PM   #4
Commercial Vendor
Airstream "OEM" shocks are not available from anyoneexcept an Airstream dealer, under any circumstances.
Napa nor any other parts supply house or company in the world, can provide that horizontal shock, or a proper replacement or sustitute, at any price.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-30-2006, 04:00 PM   #5
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
If these are horizontal shocks, (They are installed parallel to the ground) and a '75 should be horizontal shocks, it would be a factory shock. A vertical designed shock does not have the valving to operate in the horizontal position.
Removing and reinstallation should be straight forward, except any rusted nuts or bolts. Soak with a penetrating oil for some days before to allow easier removal.
>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Action is online now   Reply With Quote
Old 09-30-2006, 05:52 PM   #6
Silver Mist
LI Pets's Avatar
Horizontal shocks are made for other applications SEE Koni
Also Monroe
makes them so it is worth checking out, I doubt any manufacturer could justifiy just making a special shock for A/S's, there must be cross matches at half the cost.
If A/S dealers sell them for $34 they are paying perhaps 16-20$.
So it is resonable to find them on the Internet or NAPA for a lot less.
I'm taking mine off in a few weeks and will check it out
WBCCI
Old 09-30-2006, 05:57 PM   #7
Silver Mist
LI Pets's Avatar
Chevy ---all S-trucks. GM knew of its traction problems and added a horizontal shock absorber to S-trucks equipped with a V-6 and ZQ8 suspension package to control wheelhop. This worked so well that the horizontal shock was later installed on all V-6 five-speed S-trucks built after 1996, making it a relatively easy part to find used.
WBCCI
Old 09-30-2006, 06:17 PM   #8
Profile:  , Minnesota
Images: 59
"Steering stabilizers" are horizontal shock aborbers. Should be lots of sizes available, but I don't know if there is one which would replace the airstream shock.
edit: I guess the Monroe link says that, so pardon the duplication.
Old 10-01-2006, 03:30 PM   #9
Moderator dude
Action's Avatar
Phoenix , Arizona
Images: 13
[SIZE=-1If A/S dealers sell them for $34 they are paying perhaps 16-20$.
Bob,
Please report back (in a new thread) when you do this. As best as I can tell, Koni's far exceed $35 each and I personally wouldn't want a steering stabilizer for use as a shock. Different usage would usually mean different design. Not always, just most of the time in my experience.
So what I would like to know, if you would be so kind, is what did the trailer handle like before and after the replacement only if you used non-A/S shocks. And what was your choice and did it cost over $35 each for shocks. Thanks in advance for your feedback.
>>>>>>>>>>>>>>Action
Old 09-30-2006, 07:14 PM   #10
eikel1we's Avatar
Thumbs up Ome Shocks
To everyone, thanks for the speedy response on my inquiry. I believe I'll check out the OEM horizontal shocks at an A/S dealer. There are a couple in Michigan that are within reasonable distance from us ....... one on the way to Kalamazoo where daughter #2 lives! Road trip!
Again, thanks,
Ike
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
Need Advise bhammond Member Introductions 5 06-18-2006 02:25 PM
advise for a beginner kc airstreamer 1965 Safari 4 05-18-2003 08:21 AM
Need some advise maybe a Rally of a different kind.. JodynJeep Our Community 5 02-01-2003 12:11 PM
What shocks? Silver Annie Shocks 6 11-04-2002 12:14 AM
Export To U.k.----helpful Advise Needed CHRIS CANNON Our Community 4 09-30-2002 06:16 PM
