Old 03-02-2011, 08:36 PM   #1
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
Monroe shock info
This week I was involved in a lot of talk about the correct shocks for an AS. I contacted Monroe and asked if the gasmatic they offered would work in a horizontal application on my AS. The following is a copy of the response I recieved. I always admit when I am wrong!
Thank you for contacting Tenneco Automotive. No they are not. Must be
mounted vertical.
Monroe Team Member
lahrfarm is offline   Reply With Quote
Old 03-02-2011, 08:44 PM   #2
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
I meant would not wood
Old 03-02-2011, 08:52 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
The rest of the story...
http://www.airforums.com/forums/f437...les-74384.html
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-02-2011, 09:01 PM   #4
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Interesting. When I look at the orientation of these shocks on my 72, they are not truly horizontal. There is the end that is lower with the stamp that says "bottom ". Now it seems to me that a "horizontal" shock would be stamped with left, right, forward, aft but not bottom. Bottom infers a "vertical" installation to me.
Lance
Top is offline   Reply With Quote
Old 03-02-2011, 10:02 PM   #5
The bottom means it won't collect and store water.
If you put the bottom on top, water will collect and ruin the shock shaft.
Old 03-02-2011, 11:45 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, this is what it looks like with a shock installed correctly and another shock installed in-correctly. [or upside down, on a horizontal mount] Note: it has been corrected.
Name:	IMG_1994 (Large).JPG
ID:	123501   Click image for larger version
Name:	IMG_1995 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-03-2011, 12:34 AM   #7
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Hi Bob, if I remember correctly from an earlier post wasn't the incorrect mount on the right from the factory?
Cheers, Dan
Old 03-03-2011, 05:17 PM   #8
Salem , Oregon
Images: 18
Cheers, Dan
Hi, Dan. Yes both rear axle shocks were in-correctly installed at the factory, but Airstream sent to me, two brand new shocks, for free.
2005 Safari 25-B
Old 03-03-2011, 07:38 PM   #9
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I received the new shocks I ordered from OODM. They have the following stamped on them
Gabriel
Made in Mexico Q10226
610816
I'm sure with those numbers Monroe, Bilstein, KYB, Koni or another manufacturer can cross reference a suitable shock for this application.
Lance
Old 03-03-2011, 07:52 PM   #10
jackson center , Ohio
These shocks were made specifically for Airstream and only sold to Airstream.I am not aware of any other shock that is the correct length etc.
Schu is offline   Reply With Quote
Old 03-04-2011, 08:07 AM   #11
Gabriel
610816
There is "no" cross reference shock, that will properly replace the Airstream shock absorber..
Schu is the parts and service director at Airstream.
Old 03-04-2011, 12:03 PM   #12
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
It is "not" an Airstream shock. It is a Gabriel shock.
Lance
Old 03-04-2011, 12:36 PM   #13
BUT, it's only available from Airstream, or an Airstream dealer.
No one, absolutely no one, can buy them from Gabriel, EXCEPT Airstream.
And since it was designed for Airstream, at Airstreams request, that pretty much makes it an Airstream only part.
Hence the name.
Old 03-04-2011, 02:34 PM   #14
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
You can call it whatever makes you happy. To me, it's a Gabriel shock because it is stamped with Gabriel.
Lance
Need spec info on what trailers are made of......... funhouse Buyer Guidelines 25 03-05-2011 06:51 PM
looking for info on solar battery charging Globie64 Generators & Solar Power 11 02-21-2011 11:03 AM
Where to find detailed restoration info wworx General Repair Forum 23 02-18-2011 04:36 AM
Needing 1965 Silver Streak Wheel/Tire Info BigJim General Repair Forum 1 01-26-2011 08:34 PM
1978 23' Safari International info needed ktmmike1 1974 - 1979 Safari 4 01-19-2011 11:07 AM
