Old 03-04-2011, 02:59 PM   #15
Richfield , Ohio
It is a Gabriel shock absorber made exclusively for Airstream. No one can order it , even with the Gabriel part number, except for Airsteam. The original manufacturer for the shock was Delco and when they stopped making shocks, Airsteam contracted with Gabriel to produce the shocks. The price is more than reasonable considering that it is a one of a kind part, the price is about the same as any multi application shock.
AN AIRSTREAM LOOKS BEST WHEN IT HAS A BOWTIE ON THE FRONT OF IT.
Topshelf is offline   Reply With Quote
Old 03-04-2011, 03:08 PM   #16
Any shock that costs less than $30.00 each, is a great deal, even for a sole application.
Old 03-04-2011, 04:03 PM   #17
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Using this logic of what to call things, if I sell my Gabriel shocks to Lahrfarm that I bought from OoDM, that bought them from Airstream, that bought them from Gabriel, can I call them "Top" shocks? I guess I could. It wouldn't change the fact that they are Gabriel shocks.
"For sale. Four "Top" shocks. Manufactured to my exacting standards! You can only buy "Top" shocks from Top. (please pay no attention to the small stamp that reads Gabriel)" Hows that for splitting hairs?
Lance
Top is offline   Reply With Quote
Old 03-07-2011, 03:11 PM   #18
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
You are correct. There are a limited number of shock manufacturers in this country. And you can buy shocks from retailers of many names. Those retailers many times have a specific application and a specific spec those shocks are made to fit the application. My example if Ford Motor Company. Ford does not manufacture shocks. However they do sell them under their label. And some of those shocks made by a shock manufacurer can not be sold by the same shock manufacturer's retail outlet. So if you want to retail shocks made to your specs with your name on it I am sure Gabriel would want to fill your order. And those shocks will have a Gabriel stamp on them with your sticker on it.
You can take that even furher, with a domestic made automobile with foreign parts content. However I would rather not as this is a different can of worms on the same topic.
>>>>>>>>>>>>>>>>>Action
Old 04-27-2011, 06:26 PM   #19
1990 36' Land Yacht
Dearborn Heights , Michigan
Is that horizontal shock the same one used on the motorhome tag axles? Mark
"Silver Lining"
MrFixit is offline   Reply With Quote
Old 04-27-2011, 06:36 PM   #20
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Yes.
Old 04-27-2011, 06:54 PM   #21
Central , Mississippi
In a previous life...I spent a fair amount of time in the Delco plant that made the shocks...I can say for some of the Delco parts "made exclusively" simply meant a standard part had a new part number assigned to it...you couldn't order 'that part number' unless you were the proper custmer...they did that with several of our products...
Having said that...I would LOVE for someone to disect an "airstream" shock and document the 'difference' between it and a standard Delco or Gabriel unit...I really believe the results might be eye opening...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-27-2011, 07:05 PM   #22
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I shouldn't read threads like this one. Shocks installed upside down. I'm sure I installed ours right. At least, I think so. Jeez, it's been over a year now! Did I do it right or not? Dang, I can't remember.
(I went out and checked. They're correctly installed.)
Lynn
WBCCI 21043
Old 04-27-2011, 07:10 PM   #23
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
I cut open an "Airstream" shock, along with the Monroe Gas-matic that I use, & guess what.................you're right I'll post some photos of both of them soon, along with the rest of the info that I discovered.
Colin
Colin H is offline   Reply With Quote
Old 04-27-2011, 07:30 PM   #24
dznf0g's Avatar
Oswego , Illinois
Top, get over it. Nobody makes their own shock, not GM, Ford, Chrysler, Toyota....nobody. There are only a couple of shock mfrs. There have been many buyouts over the years and although there are a lot of BRANDS, there are only a couple mainstream manufacturers. There are some specialty shocks for off road and racing, etc. These are Airstream specification built and therefore AS shocks just like Ford OEM engineering spec shocks are Ford shocks.
You can cut them all apart and compare, but what won't be apparent is: do they dampen on only compression or extension, or both. What are the fluid specifications? What is the rate (valving) of the dampening? Is it a constant rate or a staged rate? Etc...etc.
Point is, they are spec'ed specifically to a particular suspension type. In cars this is VERY carline specific...probably not so much with AS, but I suspect rubber suspension behaves very differently than coil or leaf springs dynamically.
Old 04-27-2011, 07:44 PM   #25
dznf0g's Avatar
Oswego , Illinois
IIRC the AS shock has virtually no resistance to compression and a lot of dampening on extension (rebound). That's pretty unusual in the automotive world.
Old 04-27-2011, 08:01 PM   #26
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
dznf0g,
What exactly should I "Get over"? I purchased genuine Airstream shocks from Out of Doors Mart. They were stamped "Gabriel" The only reason I bought them was because I didn't feel like repainting yellow Monroe shocks black.
Lance
Old 04-27-2011, 08:37 PM   #27
dznf0g's Avatar
Oswego , Illinois
Didn't mean to offend...I just don't get why folks seem to always think that the engineers somehow designed to a lesser standard than the aftermarket. Sometimes new technology allow for a better mousetrap when that technology wasn't available at design inception. If length and stroke were the only parameters for shock design, there would be a LOT less part numbers out there. I am suggesting the yellow shock is very different in it's internal design. If there's no cross reference number, use the OEM number. That's all I mean.
Old 04-27-2011, 09:39 PM   #28
cojer's Avatar
1966 17' Caravel
salida , Colorado
Colin
the suspense is killing me colin whatcha got!?! because i'm not so sure the gasmatics i installed with my new axle really do much of anything
cojer is offline   Reply With Quote
Need spec info on what trailers are made of......... funhouse Buyer Guidelines 25 03-05-2011 06:51 PM
looking for info on solar battery charging Globie64 Generators & Solar Power 11 02-21-2011 11:03 AM
Where to find detailed restoration info wworx General Repair Forum 23 02-18-2011 04:36 AM
Needing 1965 Silver Streak Wheel/Tire Info BigJim General Repair Forum 1 01-26-2011 08:34 PM
1978 23' Safari International info needed ktmmike1 1974 - 1979 Safari 4 01-19-2011 11:07 AM
