Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 09-22-2013, 08:06 AM   #1
1969 27' Overlander
St. Louis , Missouri
Monroe 555003 shocks???
I have a 1969 overlander, I have replaced the axels and I am needing to put new shocks on. I was told Monroe shock 555003 would work, has anyone used these or have an alternative I can find fairly quick? Thanks for the help
Noco is offline   Reply With Quote
Old 09-22-2013, 08:17 AM   #2
thomdial's Avatar
1979 23' Safari
, Ohio
Those are the shocks that Colin Hyde uses and recommends.
Thom
thomdial is offline   Reply With Quote
Old 09-22-2013, 08:18 AM   #3
thomdial's Avatar
1979 23' Safari
, Ohio
I just ordered 4 from Amazon for about 80 bucks with shipping. -Will be putting them on this week. Are you using Axis or Dexter?
Old 09-22-2013, 09:43 AM   #4
1969 27' Overlander
I got my axels from Colin, they went in good, but the hub size on the new axel is smaller than the old one, I am nervous about the wheels but I guess with self centering lugs it shouldn't hurt anything??? Oreilly auto parts is getting me the Monroe shocks, then I need new tires. I'd like to get the Michelin mxts but they are pricey!!!
Old 09-22-2013, 10:45 AM   #5
thomdial's Avatar
1979 23' Safari
, Ohio
That's interesting about the hub size, but I'm guessing they will work. Are your brakes 10 or 12? I hated buying tires. I ended up buying Carlisle bias ply because they were the most reasonable and an exact replacement. I think a lot of people are going with the radials however.
Old 09-22-2013, 10:50 AM   #6
Several Airstream dealers have the correct shocks for your 69.
Are the Monroes a horizontal shock, that you must use?
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-22-2013, 10:58 AM   #7
A smaller hub would mean 10 inch brakes.
Your trailer was built with 12 inch brakes.
When 10 inch brakes are in perfect adjusment, a tandem axle set will stop 7000 pounds.
Should the brakes fail on your tow vehicle, and you use the trailer brakes to stop your complete rig, you will find that the brakes will over heat, and take a long long time to stop you.
On the other hand a tandem set of 12 inch brakes, in perfect adjustment, can stop 12,000 pounds. Now, you have good things on your side to stop.
Also, "self adjusting electric brakes" have been available for a little while, which keeps the brakes at maximum stopping power.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-07-2015, 06:10 AM   #8
1970 27' Overlander
1989 32' Excella
Bay City , Texas
replacing shocks
would the 555-003 monroe shocks work ok on my 89 excella 32" ?
capt ken is offline   Reply With Quote
Old 01-07-2015, 07:49 PM   #9
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Here's a good place to get the 555003 shocks if they are what you need. I ordered 6 555001 shocks from them because they had the best price anywhere.
555003 Monroe Gas Magnum RV Motorhome Shock
Enter coupon code of TJOOS and get an additional 2% off.
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 01-08-2015, 07:34 AM   #10
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The '67 and later Airstreams had shock absorbers mounted more or less horizontally. This was done to save on interior space. Shocks designed to be mounted vertically will not perform because the valving internally to the shock is in a postion that requires the shock to be mounted verticaly.
>>>Action
