Old 07-29-2011, 03:04 PM   #1
1963tradewin's Avatar
1963 24' Tradewind
, , Minnesota
Lower Shock Brackets
My lower shock brackets have folded into my frame. When I replaced the axle I cut the lower brackets off and welded them onto the dexter. My question is does this prevent the torflex dexter from moving? Can I cut the brackets off, take the shocks out, and ride just on the torflex for 200 miles? I was told you can do this just wanted to make sure. From what I have read I should order dexter brackets 033-088-01 and 02. Thanks for the help.
Psalm 67:7
1963tradewin is offline   Reply With Quote
Old 07-29-2011, 07:05 PM   #2
1963 24' Tradewind
, , Minnesota
I talked to Andy from Inland Rv, and he stated to pull the shocks before the trip. Thanks for the quick response Andy
Psalm 67:7
Sheared shock mounts? Where to get replacements? robwok Shocks 3 05-31-2011 10:40 AM
Roof mount Brackets for Solar Panel Bo2020 Generators & Solar Power 2 04-11-2011 01:20 PM
Reese snap up brackets Khulse Hitches, Couplers & Balls 0 02-05-2011 01:03 PM
