Old 11-16-2005, 06:19 PM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by StingrayL82
Car shocks are vertically mounted, whereas my Airstream shocks are horizontally mounted, so I don't understand how the shocks could be of any value. As everyone knows, riding in a travel trailer while in motion is 100% illegal in all states.
Frederic
Supposedly, the shocks designed for Airstreams are intended for use in a horizontal orientation, although I haven't seen any internal differences. Maybe someone can supply us with a diagram highlighting the differrences in the vertical and horizontal shock. My Overlander has vertical shocks, too. The good news is I can theoretically use shocks that sell for $6.99/each, and the ones that are designed for horizontal use are much more.
In my case, they are so inexpensive I may as well put them on, even if they don't work.
As far as riding in a trailer, illegalities aside, it would be an "E" coupon ride.
Old 11-16-2005, 06:20 PM   #16
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Frederic
Stingray,
Not 100% true. Chech out this site. http://www.recvehicle.com/laws.html#passenger
Many states (mine included) do not have laws regarding this issue. I do believe anyone who would do this is nuts!
Richard
Old 11-16-2005, 06:26 PM   #17
Images: 59
Originally Posted by overlander63
. . . Maybe someone can supply us with a diagram highlighting the differrences in the vertical and horizontal shock. .
The difference is that horizontal shocks (also known as 'steering stabilizers') have a bag, foam, or other method for confining the gas. This is true wheather they are gas filled or regular shocks. If you hold a regular shock upside down and operate it you will quickly see how bad this is.
The purpose is to keep air or gas from going through the valving.
Old 11-16-2005, 06:30 PM   #18
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Originally Posted by azflycaster
Stingray,
azflycaster,
Great site, thanks for the info. Does "not specified" mean that you can, or that you're just incredibly stupid for attempting such a stunt...either way, it's illegal in California, as well as my state.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 11-16-2005, 06:37 PM   #19
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by DavidsonOverlander
I've got new torsion axles ready to put on our '64 Overlander. Should I bother installing new shocks? When I removed the old shocks one of the bolts broke off, so if I put on new shocks I'll have to have a new mounting bolt welded on. I'm wondering it this is worth it or if I should just go without the shocks. The Overlander has vertical shocks.
I think that all things considered, and the fact that i am a mere owner, not an engineer, you should not take my work for shock gospel...as I said, just my opinion.
You should probably get the bolt fixed and put on the shocks, they definitely can't hurt anything, even if they don't do all that much ( which is open for debate..)
That way you have a complete and official undercarriage.
Uwe
www.area63productions.com
Old 11-17-2005, 01:54 PM   #20
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Thanks for your input. I'll feel better knowing I have new shocks.
How do I know what shocks to buy for my '64 Overlander? They are vertical shocks.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 11-17-2005, 04:56 PM   #21
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
You can use the regular Airstream shocks. They will work in both vertical and horizontal positions. They also fit both style brackets.
Uwe
Old 11-17-2005, 08:13 PM   #22
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Frederic
Not specified means there is no law regulating the act of doing that.
In fact in this state (AZ) it is legal to ride in the back of a pick up truck (the bed) in anyway you want*, however if you ride in the cab you must wear a seat belt.
* As long as the load (In this case people) are secured. If the load/people fall out of the bed the driver has some problems. Otherwise the driver is good to go. Street, highway, or freeway, and I have seen it almost every day.
On the shock vertical versus horizontal - it is all about the valving as to whether the shock can be horizontal mounted.
>>>>>>>>>>>>>>>Action
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 02:55 PM
'58 Overlander in need ! scooter 1954 - 1959 Overlander 6 12-29-2002 10:21 AM
What shocks? Silver Annie Shocks 6 11-03-2002 11:14 PM
receptacle replacement 1960 overlander rod Electrical - Systems, Generators, Batteries & Solar 3 10-31-2002 07:19 AM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 10:13 AM
