05-07-2016, 07:54 AM
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin
, Georgia
Help! Which shock absorbers?..?
I'm restoring a couple of 1970s airstreams. I want to replace the shock absorbers on all of these campers, but they are too rusted to read.
I'd welcome your advise or opinion on which ones to buy.
Thanks, in advance, for your knowledge.
05-07-2016, 12:24 PM
1978 25' Tradewind
Metro Phoenix
To get at both ends of the shock absorbers, you'll either need to bend the axle-shock arms or drop the axles. That's the bad news. If you're gonna do that, you might as well go with new axles.
Andy of Inland RV swears up and down that the only shocks that will work are Gabriels made specifically to mount horizontally.
Colin Hyde suggests Monroe Gas Magnum Shocks part #555003.
You pays your money, and you takes your chances.
05-09-2016, 09:15 PM
2016 26' Flying Cloud
Southlake
Bilstein shocks will work in any position, but they would need to be custom ordered. They have a lifetime warranty and IMO are the best shocks for any application.
05-10-2016, 01:50 PM
Moderator dude
1966 26' Overlander
Phoenix
Shock absorbers are designed to restrict suspension movement when traveling over uneven surfaces. This is done in part by fluid internally in a shock passing through a measured orifice. Since the fluid is influenced by gravity the internal workings of most shocks is a design for more or less vertical mounting with fluid passing through an orifice or several in a designed position.
In the late 1960s, (1967 I believe) Airstream redesigned the running gear to incorporate a more or less horizontally mounted shock absorber. This was in an effort to create greater room inside the coach of the RV. To do this it required a shock absorber that had internally designed valves for fluid that wasn't in a vertical position. Hence the special Airstream shock absorber that is made to be horizontally mounted. It is rather unique and shocks designed to be mounted vertically will not work in a horizontal position.
Regarding gas charged shocks, the mounting bracket isn't exactly super strong. And it is not unheard of for a bracket to bend or break. Gas charged shocks tend to be more resistant to movement and will put greater pressure on the mounting points. Could it work? Sure and may be not for ever.
>>>>>>>>>>>>>Action
05-10-2016, 02:32 PM
1973 21' Globetrotter
Houston
You can order the exact shock you need from outofdoorsmart.com.
http://odmrv.com/catalog/index.php?m...roducts_id=199
They also have a video on their site that shows the "trick" to installing the new shocks without dropping the axles or bending the mounting studs.
http://odmrv.net/shocks/shocks.php
All that being said, a torsion axle usually has a functional life of around 25 years, so if you have the original, sagged out, axles on your trailer, it doesn't make a lot of sense to put a new shock on an axle that is in need of replacement. There are many threads on these forums that describe techniques for determining whether your axles of lost their "spring".
good luck!
05-10-2016, 03:44 PM
Moderator dude
1966 26' Overlander
Phoenix
Interesting vid, and in the remove process the tech used a pry bar on the axle bracket. This can be done for installation as well.
As a tip for all vertically mounted shocks. Bleeding them by extending and contracting the shock before installation will go far to putting the liquid and gas in their respective places. During shipping and packaging the shock lays horizontal and the liquid is in places it will not be during service. Bleeding them with help the shock start in running form. With out bleeding the liquid (oil) in the shock will eventually get to the place it needs to be. By bleeding you are getting the shock set for service in the first mile. Not sure about horizontal shocks.
>>>>>>>>>>>>>>>Action
05-10-2016, 05:23 PM
Corona
Originally Posted by Action
Shock absorbers are designed to restrict suspension movement when traveling over uneven surfaces. This is done in part by fluid internally in a shock passing through a measured orifice. Since the fluid is influenced by gravity the internal workings of most shocks is a design for more or less vertical mounting with fluid passing through and orifice or several in a designed position.
>>>>>>>>>>>>>Action
Action.
Airstream switched to the horizontal shocks during the mid year production of the 1968 models, or thereabouts, according to them. That's somewhere around Thanksgiving to Christmas of 1967.
As a surprise, the horizontal shocks work equally well when mounted "vertically".
05-11-2016, 11:05 AM
1974 25' Tradewind
Lexington
, Kentucky
Shocking news
Monroe Gas Magnum shock #555003
....sales@stengelbros.com.....about $20.00 each.
05-11-2016, 11:27 AM
1963 22' Safari
Vail
If the shocks are as old as the trailers, wouldn't the axles be suspect as well especially if they are the torque spring type encased in rubber. I am sure Andy would have advice on how to evaluate the current axles.
MOB
05-11-2016, 12:21 PM
1994 30' Excella
alexandria
, Kentucky
Originally Posted by The Twinkie
If you call Monroe tech support they will tell you that this shock WILL NOT WORK IN THE HORIZONTAL or ANGLED POSITION, MUST BE VERTICAL!
Buy the Gabriel, they are affordable and last many years.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
07-02-2016, 07:25 AM
Northeastern
, Kentucky
Clearly there are differing opinions on the Monroe vs Gabriel shocks. The Gabriel seem they'd be a non issue since Airstream uses them and they've been in use with success for some time now. Colin recommends the Monroe and likewise has a long track record. Anyone know why he recommends them instead of the Gabriel?
07-17-2016, 03:17 PM
1978 25' Tradewind
Metro Phoenix
Because they work just fine and they're cheaper and more readily available would be my guess.
Here's my question for those who maintain that only Airstream special shocks must be used for the horizontal mounting:
"How do you know which side of the shock goes up?"
07-17-2016, 09:09 PM
Moderator dude
1966 26' Overlander
Phoenix
Horizontal means neither end is up. In actuality a horizontal shock is not mounted in a true horizontal manner. For shocks with a dust shield, the shock is mounted so the dust shield empties towards the ground.
And shock brand isn't the factor that drives the function. It is the design. Shocks that are designed for a vertical mounting are not designed to be mounted in a different orientation. This is because the internal valves are designed with gravity for oil flow. IN a horizontal mounting the effects of gravity are not present in the same manner. Don't take my work for it ask a professional.
Call Airstream, they are the ones that designed the system in the late 1960s.
>>>>>>>>Action
07-17-2016, 09:15 PM
1978 25' Tradewind
Metro Phoenix
Which side is up, not which end.
07-18-2016, 07:53 AM
Moderator dude
1966 26' Overlander
Phoenix
It does not matter.
>>>>>>>>Action
12-03-2017, 07:45 AM
Houston
>>>>>>>>>>>>>Action
This is promoting FUD (fear, uncertainty, doubt) on your part and creates confusion. Gas shocks are not going to bend anything. If you would like to post your empirical evidence to the contrary, please do so we can review.
Just because you feel it will doesn't mean it's a fact and just because you are right about other things doesn't mean you are correct on this part. I know, I know...your escape clause was "Could it work? Sure and may be not for ever."
12-03-2017, 09:20 AM
Vintage Kin
Fort Worth
The design is for hydraulic. Horizontal mount.
The correct ones aren’t expensive.
Do a test comparison and quantify the empirical results for us.
12-03-2017, 10:19 AM
Houston
I don't have to since that was NOT my point.
He was just saying the gas shock has more pressure and therefore might-probably-could bend the bracket. That is nonsense and creating a non issue out of thin air.
The gas shock is fine; the correct hydraulic shock is fine too.
12-03-2017, 09:42 PM
Vintage Kin
Fort Worth
I agree with him. The shock specified is very low pressure. Compress by hand.
Do what you will.
12-12-2017, 01:53 PM
Moderator dude
1966 26' Overlander
Phoenix
Airstream trailers were not designed for gas shocks. Airstream trailers have never had gas shocks installed by the factory.
Hydraulic shocks give a softer ride. This is what Airstream is looking for in the design of the suspension for Airstream trailers a soft ride. Rubber torsion springs provide a softer ride than other suspension types. Again one of the factors for using rubber torsion springs.
The shock mountings in some of the Airstream trailers is not made from thick steel. The top mounting for a vertical shock in some of Airstream trailers is rather light duty.
http://www.shocks2springs.com/Hydrau...arged%20Shocks
Anyone can use what ever they want. And a gas charged shocks only have vertical applications. For most if not all Airstreams build after 1966 the mounting is horizontal. Why would one want to use a shock absorber that is not recommended by high end RV manufacturer.
>>>>>>>>>>>>>>>Action
