Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 04-08-2007, 05:05 PM   #1
Joey 73's Avatar
Profile:  1973 29' Ambassador
hastings , Florida
Do I need shocks or not help please
I have a 73 ambassadore that i cut and shortened to a 10 ft body length.My question is do I need to put shocks under it or not it seems like a little bit of an overkill to me but I figured I would ask the experts about my dilemma.Im posting some pics so you will know what I have.Thanks a million in advance.
Joey 73 is offline   Reply With Quote
Old 04-08-2007, 05:36 PM   #2
Joey 73's Avatar
hastings , Florida
Here are the photos
Name:	WEST VIRGINIA 075.JPG
Old 04-08-2007, 05:39 PM   #3
Druupy's Avatar
Profile:  2005 28' Safari
Port Orchard , Washington
You don't NEED shocks. It will operate without them, but much better with, and safer with.
shocks keep the trailer body lean/roll to a minimum if you have to change lanes fast or corner quickly. there was a video last year that showed how an Airstream handled in high speed avoidance manuvers.
A standard SOB about rolled over during the second half of the manuver.
Shocks keep the springs on the inside side of the cornering trailer from
Pushing (springing back) to fast and hard, that results in bouncing the inside wheels off the ground. usually in the second half of the "S" turn.
Druupy is offline   Reply With Quote
Old 04-08-2007, 05:42 PM   #4
Joey 73's Avatar
hastings , Florida
I put the torsion axle from the original camper in it so the torsion axle dont need it that is cool.
Old 04-08-2007, 06:21 PM   #5
Profile:  Currently Looking...
Afton , Virginia
That's a beautiful little trailer. On the subject of shocks, long ago I owned a conventional trailer and couldn't understand why the drawers always were open after a drive. Also, sometimes the cushions would be on the floor. And on certain highways, the trailer just hopped along. After I had shock absorbers added, all of those problems went away.
Strictly speaking, you might not NEED shocks, but I wouldn't be without them.
regards
herrgirdner is offline   Reply With Quote
Old 04-08-2007, 07:00 PM   #6
Joey 73's Avatar
hastings , Florida
Yea yall are right its best to put it back under the airstream better safe than sorry.
Old 04-08-2007, 08:40 PM   #7
Phil and/or Sue's Avatar
Profile:  1983 31' Excella
1973 31' Sovereign
Ellijay , Georgia
Images: 68
But what happened to the rest of the trailer?
Shocks would be good, but which ones? There is so little weight compared to the original.
Phil and/or Sue (with Gus, Penny and Roger)
(Buffett RIP 9/15/08)
1983 31' Sovereign
1973 31' Sovereign (project)
'01 Dodge Ram 2500 Quad LWB 2x4 6sp
Cummins Turbo Diesel
AIR 1753
Phil and/or Sue is offline   Reply With Quote
Old 04-08-2007, 08:53 PM   #8
Profile:  1977 29' Ambassador
Brandon , Mississippi
You may not need shocks, but with that big 'ole airconditioner on the top of that cool little 'stream, going inside after a hike should be a thermal shock. Seriously with the original suspension you will either have one rough ride or you need to put in about 1000 lbs of ballast to get the torsion axle to work.
Cool Sami!
Old 04-08-2007, 09:40 PM   #9
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
The first thing I would do is get that puppy on scale, the axle your using is likely a 3200lb cap.
If the trailer is too lite you're going to tear it apart with a very stiff ride.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 04-09-2007, 02:47 PM   #10
Joey 73's Avatar
hastings , Florida
Thanks the rest of the camper is on the ground at my house I call it my little bubble it has a tendacy to sway with my suzuki samurai hooked to it at 55.I think my samurai has the heart of a lion but not the size to keep the camper still.
Old 04-09-2007, 03:08 PM   #11
Commercial Vendor
Profile:  Corona , California
I suspect the reason you have a sway, is that the tongue weight is inadequate.
In looking at your photo's the axle is mounted forward of the side centerline, suggesting a very low tongue weight.
That rig should have a tongue weight of at least 350 pounds or so, and then you can utilize a load equalizing hitch for proper towing.
If you are now towing with just a ball, then that's another reason for the sway.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-16-2007, 08:14 PM   #12
rbrown's Avatar
Profile:  1961 16' Bambi
Waterloo , South Carolina
Small car Small Airstram Sway.
I have a small car and a small Airstream. Sway at highway speeds was common until some wise Airstream serviceman told that I needed to level my Bambi. He wanted the roof line to be horizontal with the road. Using my airshocks on the 1965 Mustang to achieve the level. Speed and sway are not an issue. Now I need to fix my sagging axel.
rbrown is offline   Reply With Quote
What shocks? Silver Annie Shocks 6 11-04-2002 12:14 AM
Shocks for a 68 Avion T-22 Dual Axle? 68 Suburban Shocks 1 10-18-2002 01:45 AM
New Shocks Melissa Hamilton Shocks 13 07-04-2002 08:30 PM
installation of shocks TCP4 Shocks 1 05-02-2002 05:45 PM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 11:13 AM
