Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 07-18-2004, 09:53 AM   #1
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
Delco shock absorbers
While replacing the shock abosrbers on my '67 Overlander, I noticed the following on the existing shocks:
4975425 PLIACELL 136 72
DELCO PRODUCTS DAYTON OHIO USA
I have read in past posts that Gabriel is the approved Airstream shock absorber manufacturer for Airstream. If someone from Gabriel should happen to read this post, how about making the top, rubber bushing in two pieces? I was able to remove this old shock without bending the top shock bracket. If my new shock-from-an-Airstream-dealer had had this feature, the installation would have been considerably easier.
Interesting thing is that my Airstream's PO always had work done by RV dealerships, usually the dealership he purchased the unit from new.
Tom
Old 07-18-2004, 05:18 PM   #2
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
When I was in the automotive industry I was told that there are something like 5 manufacturers of shocks. (There may be more now) And if a company wanted to sell shocks that company could give the specs to a manufacturer and (with enough quanitity) could brand and market their own shocks. With that said, I do not believe that Delco makes shocks.
>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 07-18-2004, 05:38 PM   #3
TomW's Avatar
Originally Posted by Action
..With that said, I do not believe that Delco makes shocks.
Okay, so what is your point? I am not telling anyone something to do. My shocks had that wording on them. I thought I would share it for what it is worth.
Tom
Old 07-18-2004, 05:58 PM   #4
Moderator dude
Action's Avatar
Phoenix , Arizona
Images: 13
Didn't really have a point.
I thought you were asking a Q as to why the shock was stamped Delco. I have seen shocks that were stamp with one manufacture, tagged with a label from a reseller and boxed with a different name. The experience I had was at a Ford Dealership. The shock that I saw was in a Motorcraft box. Inside was a Delco painted and labeled shock with a Monroe stamp.
Just thinking that you may actually have a Gabriel shock with a Delco stamp.
>>>>>>>>>>Action
Old 08-27-2008, 11:11 AM   #5
Profile:  1992 34' Limited
Waterloo , Ontario
Exclamation Airstream shocks
My 1992 Limited tri axle has Delco Product shocks 4975425 FLIACELL. What is the replacement for them other than an Airstream dealer? Gabriel? Monroe?
Tony Skells is offline   Reply With Quote
Old 08-27-2008, 11:28 AM   #6
Profile:  Corona , California
The Delco shock was made for exclusively for Airstream, who required a 'horizontal shock."
Sometime back, Delco quit the deal.
Airstream then contacted Gabriel to make that special shock, and they have ever since.
There is NO satisfactory substitute for that shock.
It's available from a few dealers like us, who always has them in stock.
CAUTION.
NAPA stores have a shock that's exactly the same, physically, but it's a vertical shock.
When you mount that shock horizontally, it will not work.
The correct horizontal shock, is priced very reasonably.
Every few months, this same subject appears, and the answer is always the same. It's the Airstream horizontal shock, or nothing.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-27-2008, 12:30 PM   #7
Foiled Again's Avatar
Virginia Beach , Virginia
Horizontal?
CAUTION.
I seem to remember the Victorians called high class courtesans
"Grand Horizontals"
P
no particular point
VA-6 yah!
HONK if you love Jesus,
TEXT if you want to meet him personally.
Old 05-04-2009, 01:07 PM   #8
kennethowens's Avatar
Profile:  1975 Argosy 24
Malakoff , Texas
I ordered 4 shocks from an AS dealership here in Texas. The rubber
insert(s) came as one piece. That was fine on the bottom...but on the top
it was not possible to put the one-piece in....so it had to be cut in half
and assembled in two parts....the OEM shock aint OEM....there was no
taper either(straight cylinder shape). Anyone else notice the "subtle difference"?
kennethowens is offline   Reply With Quote
Old 05-04-2009, 01:22 PM   #9
Delco shocks have been history for years.
They have been replaced by Gabriel, and have been OEM for many years.
Installing them is easy and there is no need to cut anything.
The dealer should have told you how to do it. Sorry.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-05-2009, 03:01 AM   #10
toddster's Avatar
Profile:  1967 20' Globetrotter
Campbell , California
Andy,
For those of us too far away to stop by Inland RV to get our shocks changed, can you give some insight how to easily replace these horizontal shocks?
Thanks in advance!
toddster is offline   Reply With Quote
Old 05-05-2009, 07:13 AM   #11
Originally Posted by toddster View Post
Andy,
Thanks in advance!
There are two ways to change the shocks.
One way is with the tires and wheels on, and the other is with the tires and wheels off.
The fastest way to change the shocks of course is with the tires and wheels off. Changeout time per shock, about 5 minutes each.
With the tires and wheels on, changeout is about 15 minutes each. Close working quarters.
In some cases, the shock bracket on the axle may have to be bent outward a 1/4 inch or so, which will provide the necessary clearance to get the shock off. That takes a minute or two.
CAUTION: These times so not included any "stop for a sip of beer."
Tools needed. A couple of good hands, a socket set, or a crescent wrench, or a open end wrench.
No need to jack the trailer up, unless you want a little more working room. Then, only jack up one side at a time, from the axle mounting plate.
Andy Rogozinski
Inland RV Center
Corona, CA
Bilstein shocks ebay evan Airstream Motorhome Forums 31 08-04-2005 08:38 AM
Shock Absorbers for 62 Overlander Silverfly Shocks 6 07-14-2004 01:18 PM
Shock Absorbers for Ford Excursion Ed Keyes Tow Vehicles 2 06-12-2004 05:29 PM
Shock absorbers changing gary 1970-79 Tradewind 8 03-10-2004 06:15 PM
Shock Replacement Time? 87MH Mechanics Corner - Engines, Transmission & More... 3 03-09-2003 08:41 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
