Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Shocks
Old 05-08-2018, 03:40 PM   #1
1962 22' Safari
Brooklyn , New York
Bent shock mounts?
Are these shock mounts bent or is this how they are supposed to be?
The backstory....
After the shell-off renovation of my 1962 safari, when putting the aluminum wheel covers back on, they no longer fit. The tip of the shock mount was about 1 1/4” out of vertical, towards the interior, on both sides. There was nothing that banged into the frame at any point during the restoration. And there were no marks on the inside of the old wheel wells indicating rubbing between them and the shock mounts. The deflection of the Click image for larger version
ID:	310462shock mounts was significant enough that I had to cut flaps in the aluminum wheel wells so that they could fit back on.
I’m currently making new wheel wells and have the opportunity to adjust the mount alignment, but don’t want to mess up the engineering of the suspension.
Does anyone know if these mounts look like standard issue? Anyone have pics of their early 60’s shock mounts to share?
Thanks for your help!
my current shell-off: https://www.airforums.com/forums/f44/...ht-144874.html
skyclad is offline   Reply With Quote
Old 05-09-2018, 04:09 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
That shock mount can be bent by you for installation and/or removal of the shock.
The fact that it is bent now should not be an issue.
>>>>>>>>>>>>>Action
Old 05-09-2018, 04:30 PM   #3
1962 22' Safari
Brooklyn , New York
>>>>>>>>>>>>>Action
Thanks for your reply, Action. I’m not sure I understand though.
Are you saying the mount looks deformed to you? Or does it look like the factory setup?
Are you saying that bending the shock mount will have no effect of the suspension? What is your experience with this?
Old 05-09-2018, 08:07 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The unit is almost 60 years old. I am not experienced with units built in 1962. It doesn't look to bad and you would want the mount to be as vertical as possible. I had a '66 that I had to bend the mount to remove and install the replacement shock. If you want to bend the mount some so it has less of a inboard cant it is OK to do so.
>>>>>>>>>>>>>>>>Action
Old 05-09-2018, 08:26 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I'm no engineer and not qualified to offer an opinion. I do have a question though - you say both mounts moved inward? Is it possible that with the weight of the shell off the frame and the disconnection of skins to frame, the alignment of the shock mounts just pushed inward? Would it come back into alignment when all is reconnected?
Please re-read caveat at the beginning of this. They say there's no such thing as a dumb question - which itself is a dumb statement [emoji3]
Old 05-10-2018, 01:17 AM   #6
1962 22' Safari
Brooklyn , New York
Thanks for weighing in (bad pun unintentional). Your thought is a good one but unfortunately the problem persists even when everything is back together. This is a real head scratcher. I have no idea how the mounts could have shifted so much without any force being put on them.
Old 05-10-2018, 06:29 AM   #7
"Cloudsplitter"
Thumbs up
They do appear straight here....
Old 05-10-2018, 06:44 AM   #8
1962 22' Safari
Brooklyn , New York
thanks for the pic. it looks like your mounts are attached to the axil? i'm trying to figure out the alignment of my top mounts which are attached to the frame.
or am i misreading you pic?
Old 05-10-2018, 06:50 AM   #9
1967 17' Caravel
They are bent. Bend them back to vertical. I had to do the same when I replaced the axle on my '67 Caravel.
David F is offline   Reply With Quote
Old 05-10-2018, 07:49 AM   #10
"Cloudsplitter"
No mis-reading...your mount is attached differently, but I believe, as noted above, your plate is bent. Straighten, make sure you maintain tire clearance . 👍
Old 05-10-2018, 09:29 AM   #11
1962 22' Safari
Brooklyn , New York
thanks for all the thoughts. my hesitation is that on both sides the top of the mount and the bottom of the mount look parallel (see pics below). this seems too consistent to be coincidental. if they were bent out of shape i wouldn't expect this.
David F, do you have pics of before and after you mount fix?
Robert Cross, did you post something about clearance? i saw it on my app, but then can't find it in this thread.
ID:	310597   Click image for larger version
Old 05-10-2018, 10:13 AM   #12
Central , Mississippi
My '63's mounts are straight up.
http://www.airforums.com/forums/f109...tml#post956772
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 05-10-2018, 11:04 AM   #13
1962 22' Safari
Brooklyn , New York
Originally Posted by HiHoAgRV View Post
ok thanks for the feedback!
Old 05-10-2018, 11:05 AM   #14
1962 22' Safari
Brooklyn , New York
out of curiosity, what do your '61 mounts look like? straight? or bent?
Old 05-10-2018, 11:19 AM   #15
"Cloudsplitter"
Originally Posted by skyclad View Post
SNIP
Yes I changed it a bit on edit.... You'll notice that your plate is bent at the bottom where it's welded to the frame and again at the top shock mount. So if you do straighten the plate I would do nothing with the angle at the top shock mount, that looks to have been done during manufacture. If you do straighten..consider welding a 1" flat on each edge, 90* angle=stronger.
Old 05-10-2018, 01:05 PM   #16
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
skyclad,
I believe you are over thinking this a bit.
With out the benefit of speaking to the last person that worked on the shocks or access to the 50 year chain of ownership all we can say is they are what they are. Don't assume any significance.
In the word called perfect they would not bend to either side.
>>>>>>>>>>>>>Action
Old 05-10-2018, 01:14 PM   #17
1962 22' Safari
Brooklyn , New York
skyclad,
>>>>>>>>>>>>>Action
Guilty as charged I’m sure!
Old 06-04-2018, 12:50 PM   #18
1962 22' Safari
Brooklyn , New York
Went ahead and had my mounts straightened. Ended up welding a c channel to the outside of the mounts. Hoping this will be sufficient but could add more stiffening material if needed.
Old 06-04-2018, 12:55 PM   #19
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
One thing you might want to verify.
That is removal and installation of the shock after the body is reinstalled. It is far easier to install shocks with out the coach attached. It may be more difficult (or not possible) to do so with the trailer re-assembled.
I state this as I have known some to post that they had to bend the shock mount to get the old shock off and new one reinstalled.
Painting one's self in a corner isn't pleasant. Trust me I have been there.
>>>>>>>>>>>>Action
Old 06-04-2018, 01:03 PM   #20
1962 22' Safari
Brooklyn , New York
>>>>>>>>>>>>Action
thanks Action. I will definitely be remounting the shocks before putting the new wheel wells and flooring on.
Axle Shock Mounts Cos Shocks 9 03-04-2009 01:18 PM
shock mounts tebone Land Yacht/Legacy Motorhomes 4 12-20-2008 03:19 AM
64 Globetrotter shock mounts bad? koltys Shocks 1 08-13-2007 07:48 PM
3 out of 4 Broken Shock Mounts? Lookinghard Shocks 8 04-14-2006 09:08 PM
