08-23-2006, 04:38 PM
1972 23' Safari
Placitas
, New Mexico
Airstream Shocks?
I've been reading the Forum since before I got my Airstream and I've never seen any mention of Airstream shocks. In the strange and on-going saga of my Airstream, Airylle is presently at Oasis RV in Tucson having just been re-finished and clear-coated courtesy of the movie company that damaged her. In talking to Jay at Oasis, I mentioned that I had the tires and shocks replaced to make sure the contractor Oasis hired to tow her down there didn't have any problems. (Also had the wheel bearings greased.) Jay asked me, "Are the shocks Airstream OEM?" Of course they weren't because I didn't even know there was such a thing. The tire company ordered the Goodyear Marathons recommended by everyone here on the Forums and I left it to their best judgement what kind of shocks to put on. Now Jay tells me that shocks other than the Airstream OEM shocks (which are some sort of special Gabriel shock that can only be gotten through and Airstream dealer) can eventually damage the rig. If the shocks are too soft there will be bottom-out problems; too stiff and the interior will be destroyed, particularly in the kitchen area. So, friends, how many of you have replaced the shocks on your trailers with Airstream shocks? If you replaced with "other" have you had problems? The contractor can't bring my baby home until next week and I'm wondering if I should have Oasis put yet another new set of shocks on her>
Airylle 1972 Safari featured for 5 nanoseconds in the movie Wild Hogs
08-23-2006, 06:18 PM
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern
Replaced mine with shocks from Airstream.
I look at this shock thing as they were on when it rolled off the build line so I will put the specified shocks back on.
Peace
Gary
08-23-2006, 06:28 PM
1973 31' Excella 500
Morristown
, Tennessee
I am also replacing my shocks when I put on the new axles. I am going with shocks from Airstream. I am not sure that that matters, however. I'm ready to be flamed.
It does make a difference that you use a shock rated for it's use and I was not sure about the rating for the Airstream axle. The shock is not part of the support system, however, but rather the dampening when the tire takes bumps. Think about a car without shocks. The suspension will hold the car off the ground at the exact same height unless the car is equiped with air shocks to raise the height - not stock. The shock does allow the car to keep the wheel on the road and prevent bounce leading to air time and poor control.
I just felt better going stock and I'm sticking to it. I am doing the work myself so I don't mind paying for parts and not trying to save money that way. I generally do shop around for the best price and service weighing both equally.
Joe
08-23-2006, 06:47 PM
1965 20' Globetrotter
Yakima
I replaced the original shocks on my '65 GT with Gabriel shocks that I ordered on the Internet.
08-23-2006, 07:23 PM
1972 23' Safari
Placitas
, New Mexico
So 65glb, how are they working out for you? (If it's been long enough to tell.) It's not like I told the guy at the tire place to just put any ol' thing on it. He's pretty experienced with travel trailers in general, but not Airstream specifically. And what he put on was supposed to be appropriate for the length and weight. I just hope that this thread alerts newbies like me that there actually are Airstream shocks.
08-23-2006, 10:18 PM
Hill Country
Just went through the shock investigation this week. According to the Airstream-certified tech at closest dealer (and according to Inland RV), Airstream uses exact same shock on every unit, from 19' to 34', and has been using same ones for >50 years!
I wound up going there because no one else had a double-eyed shock the right length and throw. Cost was ~$68 for two. They couldn't tell me its "rating," just that it was "the Airstream shock." It was made by Gabriel.
If I were you, I guess I'd try to find out from Gabriel what the "rating" is on their Airstream shocks, then call whoever made your shocks and see if the two are equivalent.
Lynne
08-23-2006, 11:03 PM
1960 24' Tradewind
santa barbara
Hello everyone ,
the shock used on the torsion axles mounts different than the early leaf
spring axle does .the torsion axle shock mounts at an angle more layed back
close to horizontal ,so the shock valving is designed differently for a shock that mounts that way.The early shock mounted in the normal position such as my 60 trdwnd ,in the vertical position as most vehicals are ,also can
be a gas shock or standard hydraulic type shock .I used Gabriel shocks
,regular hydraulic type .They work great .So the airstream shock talked
about here ,does need to be airstream specific do to that type of mounting.
I don't know of any real "Rating" of the shock however ,and a comparable
shock that mounts on the early leaf spring axle really can be matched to
your old shock at most parts stores ,if they take the time to look in the
cataloge under the shock specifications for most any shock.The specs are
by length ,eye on either end or not ,compressed length ,and extended
length or overall length (same thing).I did that exact thing to get my 60
shocks thru CarQuest Auto Parts store.and they are Gabriel as I said.
hope this helps folks in there shock shopping.
Scott of scottanlily
08-24-2006, 01:27 AM
a.k.a. Ambassador Tim
1960 28' Ambassador
Northern
I don't know how much that shock really does anyway. I would not worry about it.
The main concern is how your axles are. If they are fine you should be ok.
The torsion axles don't really need shocks from what I understand. When I replaced the 30 year old ones on my '71 Safari with the proper new Airstream shocks that I paid a premium for, the compression of the shock between the old and new one were the same, and not too hard to compress by hand. Meaning to me they did not do very much.
Of course, Airstream put them on so we don't want to re-engineer things, but in your case, if your axles are fine, I would not worry about the shocks.
08-24-2006, 08:30 AM
When checking the shock specks., dont forget the specs. for resistance on opening and the resistance on closing. This is important, to keep the tire in contact with the road. One obvious result would be tire cupping. You should be able to get these specs. from the shock manufacturer. Good luck
Nye
08-24-2006, 11:06 AM
1972 23' Safari
Placitas
, New Mexico
Thanks for that insight SafariTim. The axels are in good shape according to Lewster. The PO bought the trailer in the late '80s and used it less than two dozen times. Then it sat for the last 7 years under a carport. The tires, while they had a lot of tread were basically rotten. I figured maybe the shocks were just worn out from sitting as well and I might as well get them replaced while the wheels were off to have the bearings greased. Yeah, ok, maybe Airstream has used the same shocks for the last 50 years. That tells me your assesment is right, that the shocks don't make all that much difference. Since the newer rigs are supposed to be heavier than the older rigs and, obviously, a longer one is going to weigh more than a shorter one, I just find it hard to believe that a one size fits all shock is that critical to the overall performance. In terms of vehicles you obviously couldn't put Hummer shocks on a Kia and vice-versa.
08-24-2006, 02:35 PM
Frank S
peoria
Hi--In Aug 1989 I purchased 4 shocks at the A/S factory store in Jackson Center, for $13.06 each. They were made by Delco, part # 4975425, and the A/S part # was 400008.--Frank S
08-24-2006, 02:39 PM
Morristown
, Tennessee
Dear Lady,
While it is true that you don't want to put shocks from a Hummer on a Kia, it is not because the shock is part of the support system. The shoch absorber stops the tire from bouncing on the road. This could be from bumps or holes (dips) in the road or a harmonic result of unbalanced tires. Either of these would result in an unstable ride and the tire not in contact with the road. The classic appearance of tires on trailers with worn out shocks is "cupping". This looks like alternating areas of good tread and then worn tread followed by good tread etc. all around the tire.
Think of the shock as a dampener system for the tire bounce. Bounce a ball on concrete then bounce a ball on the same concrete with 2-3 inches of water on it. Similar effect with shocks.
So what is important in being able to compress the shock when the tire hits a bump and letting the tire relax back to the road without bouncing. The expension and compression of the shock absorber depends on several factors with one being the weight of the vehicle - thus no Hummer shock on the Kia.
Again, it is not part of the support system but a dampening system designed to keep the tires on the road yet still eliminate constant jolts to the coach that jars things loose like rivets, etc.
Although the rubber in the torsion axle and the spring in conventional suspension acts to slow any bouncing simply by the nature of their design, they are mainly for supporting the structure. I think the shock absorber is a necessary part of a complete suspension.
Ever ride a Harley hard tail? Try it and you'll get a better idea of the jolting. On the Harley, it's your kidneys and on the trailer, it's your Airstream.
I'm using the original, installing them myself and not guessing if it's rated properly.
Hope that helps.
Joe
08-25-2006, 12:37 AM
1960 24' Tradewind
santa barbara
hello all ,I have presented the same thoughts on the shocks as defelice ,
but the axle manafactures say no need ,I see it different ,airstream does also .The shock need not be different because the coach is heavier ,as the axle carrying capacity handles that aspect ,the axle arm movement ,tire rebound is the shocks job of controlling that movement.Anyway the rubber torsion rods absorb some of that movement as they resist that action
of movement by design ,I like the idea of putting back on what was there.
Airstream still installs them today.
Scott
08-25-2006, 07:55 AM
1948 16' Wee Wind
1953 21' Flying Cloud
Denver
Some shocking history ...
Early postwar (1947 and 1948) Airstream Liners did not have shock absorbers. Shocks were added in the 1949 model year when the chassis frame was strengthened by extending the outside spring hanger frame rails forward of the door in the pipe frame chassis. The shock absorbers used from 1949 through 1960 were vertically mounted on a leaf spring axle, also used through the end of 1960.
The Dura Torque (internal rubber compression) axle replaced the leaf spring axle for the 1961 model year and used vertical shock absorbers from 1961 through the end of the 1966 model year. The Super Dura Torque axle was introduced for the 1967 model year and it featured new (nearly) horizontally-mounted shock absorbers for increased floor space. These are the shocks that might have special valving for horizontal use, but I don't have any details on that. Nevertheless, please be aware of the year of your trailer and the mounting configuration of the shocks before ordering replacements.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life "From the Archives"
08-26-2006, 02:33 PM
1972 23' Safari
Placitas
, New Mexico
Saved from my ignorance
by an honest business man.
So, here's the final chapter in my shocks saga. My son was the one who took my Airstream to have the tires and shocks put on it while I was on vacation. When I got back he had gone on his vacation. When he got back today I asked him what kind of shocks they'd put on Airylle. He said, "oh, I forgot to tell you. Philip at Bernalillo Tire decided not to replace the shocks because he said he said they were some kind of weird shock and he didn't feel that it would be a good idea to replace them with anything except the kind that were on it and he couldn't order those from his distributer."
I called Jay at Oasis this morning to find out if my trailer was still there and he told me the driver was on the way to pick it up right then. I told him that the shocks had indeed not been replaced. He took my credit card number and said he'd put a set in the trailer so I could get the right ones put on here--at wonderful, ethical Bernalillo Tire. So, in the end, I'll be getting the right kind of shocks after all.
08-29-2006, 02:49 PM
Moderator dude
1966 26' Overlander
Phoenix
The special shocks that the other place could not get are Airstream only shocks. They are Airstream only because they are installed in a horizontal position as has stated above. And a shock in the horizontal position can not use gravity to move the oil inside as a vertical shock. So the valving is different as stated above.
My '66, while it does have a torsion axle the shocks are mounted vertically. So the choices are much greater than a horizontal mounted shock.
Horizontal = Airstream dealer only
Vertical = Airstream and other outlets that meet the same specs.
>>>>>>>>>>>>>>>Action
09-03-2006, 12:42 PM
Morristown
, Tennessee
Just put on my new shocks. They have the Gabriel brand stamped on them but cannot find them on the Gabriel site. They fit perfectly.
I must say that the old shocks still had a lot of resistance when extending but I could compress them with almost no force. It is the compression that happens when the tire hits a bump and the extension that relaxes the tire back to the road.
I'll report on how the new axles and shocks ride.
Joe
09-03-2006, 05:03 PM
2016 25' Flying Cloud
Sunnyvale
Gabriel Pat Number?
Joe-
Did the Gabriel Shocks from Airstream have a part number on the box or units? It might still be orderable from Gabriel even if it is not on their website...
(and yeah, I'm in market for shocks too...)
John McG
Condoluminum
09-04-2006, 12:31 PM
Corona
Originally Posted by Condoluminum
Joe-
John McG
The Gabriel shocks are an OEM item from Airstream, only.
Accordingly, Gabriel is not allowed to sell them to anyone, except Airstream.
The horizontal shocks are available from an Airstream dealer that also sells parts over the counter.
07-25-2007, 09:03 PM
2006 19' Safari SE
Tucson
I can't resist it!
Forgive me in advance...I just can't resist it... I find it all "shocking"!!
Seriously, though, this stuff is good to know. I hope it's a very long while before we have to deal with new shocks...does anyone know the shock situation for an 06 19' Bambi? I can't imagine that there are no shocks at all...
One more thing, Blu_Hwy_Ldy...we were just at Oasis RV just today picking up the Bambi today! Good folks...they have been very good to us. We had a mysterious leak coming in from the seam just in front of the TV antenna crank...it took 2 trips and lots of water-testing and such, but Richard at Oasis assures me that they found the culprit this time...a mounting screw for the solar panel had not been properly sealed at the factory...and that's where the water was finding its way in. Keep your fingers crossed that that is the end of that drip!
Happy Trails...TB
