Old 05-22-2010, 03:08 PM   #1
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Airstream makes good on six year old trailer.
Hi, I was doing my brake and bearing inspection and found that my trailer, since new, had both rear shock absorbers mounted up-side-down. My trailer was built in 07/04 and that makes it 2 months short of 6 years old from actual production. I E-mailed Airstream and asked them for two new shocks. I was fully prepared to get nothing, but Airstream made good and sent to me two brand new shock absorbers VIA Fed-Ex. I got them today. My story is posted in my blog "A Shocking Brake story" [click on my blog, under my avatar]
THANK YOU AIRSTREAM
Name:	IMG_1995 (Large).JPG
ID:	103098   Click image for larger version
Name:	IMG_1999 (Large).JPG
Name:	img_2039 (Large).jpg
ID:	103100   Click image for larger version
Name:	IMG_2041 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 05-22-2010, 03:20 PM   #2
Lily&Me's Avatar
Normal , Illinois
They did the right thing. Good for them!
Maggie
Old 05-22-2010, 07:44 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Looks like you can get to all four bolts holding the axle and if that is the case the easiest way to mount the shocks would be to drop the axle so you can get to the top stud. No need to cut the brake line if you have a couple of floor jacks and support the center of the tube. Just let the jacks down slowly and let the tube rotate on the center support.
2004 Excursion 4x4
Old 05-23-2010, 08:59 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Don't drop the axle!
You don't have to drop the axle to replace the shocks. Especially if the original shocks have split grommets. I just replaced those on my trailer yesterday. Just remove the inside half of the grommet first. It takes a little maneuvering but you can get the shock off. The new shocks have a solid grommet. I removed the grommet from the new shock. Slid it over a wooden dowel then split it down the middle using my band saw. Installed one half of the grommet then the shock and the other half of the grommet, washer and nut.
New Quickbite coupler makes hooking up the trailer a breeze Morgan Fletc Hitches, Couplers & Balls 61 05-26-2016 10:17 PM
Vintage Airstream trailer great shape for year eBay Watch Airstreams on eBay 0 03-11-2010 12:50 PM
What makes a good dealer? 7husker 2008 Safari SE 15 06-04-2008 05:58 PM
Good price for a 1 year old Bambi? silverback 1997 - 2004 Bambi 8 06-27-2003 08:14 AM
Suggestion: Airstream trailer Forums (by Model & Year) hex Forum Admin, News and Member Account Info 2 10-15-2002 06:38 PM
