Old 01-31-2012, 02:15 PM   #15
Shocks
Parts stocking Airstream dealers, have the correct shocks.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-03-2012, 12:05 PM   #16
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Lucymcdog, Your '65 will have vertical shocks. NAPA would be a good source.
Later years have horizontal shocks and those are a dealer only shock.
>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - Streamless at the moment.
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 02-25-2012, 05:29 AM   #17
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Images: 50
Cool
Originally Posted by racoco View Post
Not so sure the shocks are redundant. Couldn't figure out why our 2007 pulled so bad compared to our 1976. Interior rivets were shearing, we had to constantly tighten screws. Stuff rattled around more than we ever expected (opening doors became a game).
Then while replacing a tire I discovered that the RS shock was never installed. The mounting studs were immaculate. Got a shock ordered, got it on, and all the odd problems stopped immediately.
Well, except for traveling in Louisiana, but that's a whole different story.
Did you use an AS "horizontal" type shock?
Art, Margaret, and JAKI;
High Desert Country of New Mexico
'85 Sovereign 25'er "HI-HO-Ag"
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 02-25-2012, 06:35 AM   #18
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
All units built after 1966 are designed for a horizontal shock.
>>>>>>Action
Air brake warning intermittent landmarc Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 08-29-2011 09:33 AM
Land Yacht Dash Air DonaldW Land Yacht/Legacy Motorhomes 25 07-21-2011 07:48 PM
Air compressor silverdream2 Classic Motorhomes 9 06-22-2011 10:29 PM
Air suspension connection warrenivan General Motorhome Topics 4 06-09-2011 03:43 PM
Air horns on 390 XL jwitwer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-25-2011 07:49 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
