Old 01-18-2007, 04:14 PM   #29
Somewhere , Indiana
Yep!
Artificially lifting the trailer with "air shocks" will cause the shock studs to break.
Additionally, air shocks will not allow the torsion axle to resume its neutral position. This will cause undue ware on the internal rubber cords.
Just two cents from a retired Axledude!
Regards,
Henry
axleman is offline   Reply With Quote
Old 01-18-2007, 10:10 PM   #30
1960 24' Tradewind
santa barbara , California
Air shocks in general are to (make up) for a weak rear suspension on
cars and trucks .Back in the 70s ,we loved Gabriel high jacker air shocks on our older mustangs and camaros ,the result was a harsh rough ride ,but we could get those Firestone Super sport tires under the back wheel wells and the air shocks rigidness would keep the wheel wells from ripping up the sides of the tires as the suspension moved .They do put the strain on the shock mounts
but they didn't break too often ,(i never had one break) but its not the way to do it thats the point ,and if you put them on a trailer with verticle shocks
they will give the trailer a rough ride and thats no good .so a good set of shocks is good ,you don't need gas shocks ,the idea is to control the
tire/wheel rebound ,you don't want a stiffer shock ,gas shocks will be stiffer.
No question ,a high quality hydraulic shock will be fine .
Scott
scottanlily is offline   Reply With Quote
caravel
What shocks? Silver Annie Shocks 6 11-03-2002 11:14 PM
Shocks for a 68 Avion T-22 Dual Axle? 68 Suburban Shocks 1 10-18-2002 12:45 AM
ProComp Explorer Shocks BobbyW Shocks 0 09-25-2002 08:16 PM
New Shocks Melissa Hamilton Shocks 13 07-04-2002 07:30 PM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 10:13 AM
