Old 02-17-2008, 02:52 PM   #1
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
why is this vent here?
I'm about to redo the front of the tub/sink/toilet unit in my'64 Globetrotter; the fiberglass piece has been hacked up and had carpet glued to it... there is a vent through it to the rear compartment (where the battery, pumps, electrical stuff is). Why is this vent here, and is it necessary? I seems like you wouldn't want to share air with the battery and the interior of the rig. I'm thinking I'll put a piece of Marmoleum on the front of all of this, and maybe I'll just leave the vent out?
Peter
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 02-17-2008, 02:56 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can eliminate the vent, just make sure you have a vent in the battery compartment to vent the hydrogen gas. It is lighter than air, so it will need to be near the top of the compartment.
Old 02-18-2008, 11:25 AM   #3
Globie64's Avatar
Images: 18
Thanks. I also wondered if there was a way the compartment vented through the hot water heater vent/intake.
Old 02-18-2008, 12:03 PM   #4
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
The water heater's hot parts should be sealed from the interior of the trailer. It is a high used of oxugen, and produces toxic fumes. That is why water heaters are typically vented to the outside via vents in the water heater door.
Uwe
www.area63productions.com
Old 02-18-2008, 03:44 PM   #5
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Hi Peter:
I always thought the vents on either side of the flush pedal helped keep the rear utility compartment warm during freezing weather, and made a small contribution to preventing the water pipes from freezing by circulating some warmer cabin air in there. I'd be inclined to leave the vent open if you ever plan to camp in cold weather.
Originally, the battery had its own top cover and a vent tube (for hydrogen gas) that ran up towards the rear end. On the outside rear, towards the curb side, you will find a short upside down "L" bracket riveted on as a drip cap to the small hole underneath it that accepts the vent tube from the battery.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 02-18-2008, 05:44 PM   #6
Globie64's Avatar
Images: 18
"...you will find a short upside down "L" bracket riveted on as a drip cap to the small hole underneath it..."
would this be visible on the outside, or underneath? I have the original battery cover, but it doesn't fit the current battery.
Peter
Old 02-19-2008, 06:37 AM   #7
47WeeWind's Avatar
1948 16' Wee Wind
Denver , Colorado
Images: 20
"...you will find a short upside down "L" bracket riveted on as a drip cap to the small hole underneath it...". Would this be visible on the outside, or underneath? I have the original battery cover, but it doesn't fit the current battery. Peter
Hi Peter:
It is visible on the outside rear end of the trailer, on the right side, above the access hatch to the rear utility compartment and lower than the tail lights. If the "L" bracket has been removed, the small hole should still be there (unless someone filled it with a rivet).
Airstream Life
"From the Archives"
Old 02-25-2008, 06:30 PM   #8
Globie64's Avatar
Images: 18
I'll look; I've seen those vent things, and mine doesn't have one. There may be a rivet. Might it be something that was on earlier trailers only? I wonder if it might be an Ohio vs CA manufactured rig?
Loosening Vent Handles and Aluminum Vent Replacement kincaidjesse Roof Vents, Skylights & Fans 4 04-16-2007 10:37 PM
vent chuck schmit Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-26-2006 06:42 AM
What Is this vent? Stagehand Roof Vents, Skylights & Fans 7 06-26-2005 08:39 AM
Fridge Vent CampSayler Refrigerators 14 04-19-2005 03:11 PM
mystery vent silver suz Roof Vents, Skylights & Fans 2 07-12-2004 06:22 AM
