02-06-2010, 10:59 PM
Powder Springs
, Georgia
Who's screws in my '59 Overlander?
While gutting our '59 Overlander I've noticed that there are all types of screws. (In one trim piece there were no less than 5 different types of screws (small Phillips head, large Phillips head, small standard, medium standard, large standard.)
Do you know if Airstream used Phillips head screws (at all) in 1959 or just standard? I'm wondering if all of the Phillips head screws are from a PO?
All of these curious things about our new Overlander are making me feel like I'm loosing a screw or two myself!
Thanks!
02-07-2010, 06:32 AM
1967 22' Safari
1960 Caravel
Edmonds
Thanks!
From my experience the standard screws are the original ones used by Airstream.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
02-07-2010, 07:01 AM
Baltimore
, Maryland
No philips heads were ever used. All of those were put in by someone else. There were actually just five or six screws or bolts used for everything. You will know the original ones because they will all be very difficult to get out.
02-07-2010, 07:21 AM
1967 24' Tradewind
Sebastian
I'm new to renovating my 67 Tradewind....I am replacing some screens and all of the plastic holders...can I use the cheap screws that come with the plastic or should I get aluminum (hard to find in my area) or stainless?????
02-07-2010, 07:53 AM
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
It's also been my experience with my own '59 that the factory used only slotted screws and these were either the flat domed or flat head screws.
Yea!!! Another '59 owner. Post some pictures, we'd love to see.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
02-07-2010, 08:03 AM
The screws that usually come with screen clips are galvanized, and are okay with aluminum as far as I have heard. These hopefully won't be getting wet on a regular basis so stainless is probably over-kill. I would reuse the old ones if they are not too far gone, or lost.
Rich the Viking
02-07-2010, 11:05 PM
Powder Springs
, Georgia
While we've been gutting ours, I've come across lots of standard-head screws that are rusted out to the point that I've had to extract or cut them. My internal debate is whether I should replace these culprits with more standard-head screws or maybe switch to posidriv for the hidden ones.
02-08-2010, 03:50 AM
Baltimore
, Maryland
When I first started doing this I saved every single screw, put it in a baggie, a post it note with the location it came from. Baggie filed into a box labeled with the trailers serial number. Now I toss every single one in the trash and when the time comes I replace it with a brand new screw.
02-08-2010, 08:32 AM
Austin
Same here. Not a single slotted screw has gone back in my trailer. It's all philips or square drive for me.
02-08-2010, 09:21 AM
1964 28' Ambassador
Oklahoma City
, Oklahoma
Am doing the same here, Utee. After gutting the trailer, I developed a strong dislike for flat head slotted screws...not too fond of rusted carriage bolts either.
02-08-2010, 03:25 PM
Baltimore
, Maryland
They are the easiest of all. Just grab the nut with vise grips and snap them off. Two seconds...
