Old 01-28-2014, 10:26 AM   #1
Chillbilly's Avatar
1987 32' Excella
Maryville , Tennessee
Which would you recommend?
I'm about to install Allure Vinyl Plank Flooring in our Excellon. I'm undecided about which way to run the grain, side-to-side or front-to-back. Which direction would you recommend and why?
Chillbilly
1987 Excella 32 Foot
"Campgrounds In And Around The Great Smoky Mountains National Park"
Chillbilly is offline   Reply With Quote
Old 01-28-2014, 10:34 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have never done a trailer, but have done a lot of hardwood in houses. I have found that it usually looks best if the planking runs with the long dimension of the room. Running it side to side can sometimes give it a "ladder" look. If I were doing it, I would go front to back.
Brian
SuEllyn & Brian McCabe
Old 01-28-2014, 11:37 AM   #3
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
I vote the same as Brian. I had a hardwood installation business for a while and corridors do look better to me with the grain parallel to the corridor flow. It's slightly more work with actual hardwood to go that direction but still. That being said hardwood has different installation factors than vinyl plank. Traditionally we always tried to get grain direction parallel to light from windows but again not such a consideration in a trailer. Keeping the boards at 90 to the floor joints will help hide inconsistencies too. If you really can't decide you could go for 45 degrees, even more work but sometimes gives visual interest….
truckasaurus is offline   Reply With Quote
Old 01-28-2014, 12:29 PM   #4
Central , Mississippi
I've done trailers each way. Our 34' has it side to side in an attempt to visually reduce the extremely long look inside. The drawback is any section of that flooring less that 1' long will start to creep. There is a bunch of cutting if you go crossways.
Our 29' had it long ways. It was tough to plan the cuts because you need a long straight run from the front to the rear. It's impossible to do that in a trailer and still start at one side. Lots of measuring and marking!
We like the flooring, it's easy to sweep it clean.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-28-2014, 01:31 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Doing design study on residential spaces, I've learned it is good to run the grain in the direction of the flow, it is confusing to block it. "This looks odd".
Doug and Cheryl
Old 01-28-2014, 01:37 PM   #6
Full Time Alumaloafer
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
We installed our vinyl plank flooring front-to-back in our TradeWind. Simplified installation and came out looking rather nice. Only drawback we have noticed is a small gap is needed between the planks lengthwise to allow for expansion when in warmest weather or in the sun. Had 3 or 4 joins that required a blade-width to be trimmed after the installation.
Very easy to keep clean and surprisingly resistant to cat claws!
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
louaxtjr is offline   Reply With Quote
Old 01-28-2014, 01:51 PM   #7
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Go Long
ChillBilly...run it lengthwise. Mark your center line and work out from there. Our Bamboo Allure looked great upon installation but opened up from the cold Winters. Maybe you're far enough South that won't be a problem. FYI
Indiana, PA
Roadrunner is offline   Reply With Quote
Old 01-28-2014, 04:29 PM   #8
Chillbilly's Avatar
1987 32' Excella
I'm actually installing this in a trailer which sits vacant from May through December in hot, wet southern Florida. Others have used it and claim it holds up well if a small gap is left around the wall for expansion. I guess I'm inclined to install it lengthwise as suggested by most. I ripped up all the parquet flooring which had been glued and stapled down, and the carpeting which was installed with carpet strips. The sub-floor is chipboard, which I filled and smoothed using Durhams Rock Hard. I'll try to post a picture of the finished install. Thanks to all who responded.
Chillbilly
Old 01-29-2014, 01:55 PM   #9
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
We ran ours at a 45 degree angle just to be different. Looks great in our opinion but then, everyone has one. Good luck.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 01-29-2014, 05:38 PM   #10
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
We ran flooring in our kitchen diagonally (in the house). Amazing how much wider and roomier it looks. I think I'd do the same in the AS if we were doing plank flooring.
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Air compressor recommend pappy19 Tires 30 06-08-2013 02:49 PM
Recommend shop to replace a rear corner skin on W Coast? rebelhoop Interior Restoration Forum 4 10-21-2012 05:34 PM
Please recommend a brake controller... 3campers Towing, Tow Vehicles & Hitches 26 06-15-2012 12:07 PM
Would like to Recommend Trailers for Less Services benjisgal Tires 6 01-18-2012 04:01 PM
Anyone recommend a repair person Eureka, Ca? magna1111 General Repair Forum 5 05-30-2008 11:43 PM
