Old 09-07-2006, 07:46 AM   #1
cookeville34's Avatar
Auburntown , Tennessee
Send a message via Yahoo to cookeville34
Where to start?
I just bought a 31', International rear bath, twin bed 1979 model, Where do I get an owners manual, Where do I start??? How do I start anything up?
cookeville34 is offline   Reply With Quote
Old 09-07-2006, 08:03 AM   #2
Riviting Espresso
ColdEspresso's Avatar
1978 25' Caravanner
Boca Raton , Florida
Send a message via AIM to ColdEspresso Send a message via Yahoo to ColdEspresso
Hey Neighbor,
We are just up the road in Nashville. There are quite a few resources for manuals. just look through the forums and use the search feature. I have a 78 25 ft Caravanner and there is probably a lot of similaraties. You may want to come to the North GA Rally in October. There will be folks who are more knowlegeable than me and I'm sure we both will get a few tips. Don't forget to post some pics of your rig.
Mario & Kelly
Music City, USA
AIR# 12509
1978 Caravanner
2002 Chevy Avalanche Z71
2009 VW Sportwagen TDi
Rancilio Espresso Machine w/ Rocky Grinder
ColdEspresso is offline   Reply With Quote
Old 09-07-2006, 08:13 AM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
If you are looking for manuals, you can get reproductions from Helen Davis at Secretarial Services, PO Box 484, Sidney, OH 45365 (937) 492-8885. High Quality reprinted Service and Owners' Manuals are also available from the Airstream Store at www.airstream.com look under books. If you don't see the year(s) you need contact Airstream.
Learn to use the search tool on the upper blue bar... there are answers to most repair issues here - and most systems are the same from model to model - in any given decade. Good luck.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 09-07-2006, 11:53 AM   #4
Very american 4 a french
brunoffrance's Avatar
1971 27' Overlander
DUNKERQUE / FRANCE , Nord
Images: 68
My best advice to discover your new "baby" is ... simply to clean it . you'll discover all "squares" , all faucets, all pipes, water or lpg , et cetera and really it'll be a great first step to understand ( or triing understand ) all the connection; even with the manual, you'll not know how that work if you don't do that;
welcome in the community,
Best regards from FRANCE.
Bruno.
My blog:The american dream in FRANCE:
My pictures in high quality: Pictures on FLICKR:
My videos are on YOU TUBE
My AIRSTREAMLIFE ning
brunoffrance is offline   Reply With Quote
Old 09-07-2006, 07:27 PM   #5
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, cookeville34,
Start by finding out if you're lucky enough to have all the keys to the outside compartments, and then go look in them just for the heck of it.
Gently pull your batteries out onto the lid/cover and see if they have any fluid in them. Add distilled water (from any drug store) if they need to be topped off to the split ring.
Then put them back in their holes and plug the trailer in. Walk to the front and listen for a BUZZ. If you hear one, congratulations, you have a UNIVOLT. If you don't hear one, go inside and try some lights. If they work, even more congratulations are in order because you don't have a Univolt, which means that somebody put in something quiter. Then again, your Univolt could be both original and kaput. No lights at all would indicate that.
Then go to Wal-mart and look in the RV section. For less than $10, pick yourself up a little brass Marshall water pressure regulator. Put this on your spigot and then hook the water line to the trailer. Open the valve and count to five. Then turn it back off and go look to see if anything is leaking outside the trailer.
Then open the water heater door and see if anything is dripping there.
Then go inside and look under the sinks, in the water distribution center (which I think is in the cabinet in the bathroom in a rear-bath model), and around le toilette.
If no floods are apparent, go outside and turn the water on. Then hop back inside and do the inspection for leaks again. Listen for something that sounds like "Phssst!" That's bad news.
Then open the hot and cold water on the galley (kitchen) sink, and see if, after much popping and spluttering, you actually get water. That's a very good sign.
Try the same in the bathroom.
Under the sinks, you can see some water lines. Check them for moisture by feel.
Once you have either determined that nothing is leaking or have made note of the places that will need repairs, it's time to try the propane system.
Each appliance has a shut-off valve under the trailer. There's a good chance that these valves have never been moved. Crawl under there and find out if they will move. Inline with the pipes is on. Ninety degrees in relation to the pipes is off.
Try turning off everything, and then turn the gas on at the tanks up front. If you don't hear a hiss or hiss and rattle as the system pressurizes, then you have no gas. If the selector built in to the regulator is manual, slide it to other tank and open that one. If still no hiss/rattle, close the valves, take the tanks off and go to the propane store for filling.
This is also fraught with the potential for additional cost if the tank outlets haven't been updated. Your propane guy at the propane store will let you know if this applies.
Back at the trailer, slowly open a tank valve and listen for the hiss/rattle. If you hear it, great.
Then get your soap solution (thick dish detergent in a little water) and go around and check all the joints for leakage by slobbering the mixture all over the joints, which will make little bubbles if they're leaking. If you hear a big leak, skip the pressure test and turn the gas off.
Inline valves for seventies models can be had at Lowes. Be sure to use TWO wrenches when disassembling and reassembling.
When you have that marvelously exposed propane system repaired and repressurized, open the valve going to the stove, and then go inside and look at your stove. Is it a four-burner Magic Chef? If so, this stove has TWO pilot lights. One is under the stove top and is below the lower shelf near the rear of the burner.
To test, you don't need the pilot lights.
The left-hand knob should be in the fully clockwise position - NOT the OFF position because that would be too logical. (Push in and turn clockwise.)
Now take your camp igniter (long snouted lighter) and turn on one of the burners. Spark around the burner until you get propane to the stove. When it lights, do the same for the other three.
Now for the water heater. There are a few types. If you're really lucky, you'll have an extra switch in a cabinet or somewhere else in the bathroom that turns on the water heater. When you depress it, it should turn red to indicate that it's trying to light. If you don't hear it light, try it again. It may take several tries to get a startup.
If you can't find the button, go outside and lower the water heater cover. Do you see a potted circuit board and a big ignition wire going toward the burner?
If so, go back and look for that switch again. It should be in there SOMEWHERE.
If not, you have a pilot model. If you're really lucky, the instructions will still be stuck to the water heater. Try doing what they say, again using your camp igniter.
If it won't light, do a forum search for "water heaters" and you'll learn about propane-loving micro-spiders and other problems water heaters can have. Be prepared to be reading for a while.
Once you have the water heater lighted, go back into the trailer and open the freezer compartment. Do you feel any cold?
If so, great. Check it tomorrow to see how cold it gets.
If not, get on your knees and look at the fridge knobs. One should say "Electric." The other one should be about on number 4.
Well, this should get you started. If you plan to actually move it somewhere, there will be some other considerations.
Good luck!
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 09-07-2006, 08:27 PM   #6
update on my "new" "old" trailer
Well, the good news is the AC blows cold and the outlets work. We decided to ditch the entire propane system which appeared to be full of holes and go with all new electric appliances. Picked up a new electric fridge at Walmart for less than $200.00 and it fits exactly in the hole where the old fridge came from. Gutting the kitchen and living area. Didn't have time to check the water systems yet. Old gas appliance will be going to ebay with no reserve in a couple days, if anyone needs this stuff.
Old 09-07-2006, 08:31 PM   #7
Waynon's Avatar
1986 34' Excella
Where to start?...
Just clean. Don't worry, as you start touching and cleaning every little piece you will find more than enough to do. For goodness sake, don't look for things to fix. Smile.
Waynon
Waynon is offline   Reply With Quote
Old 09-07-2006, 09:15 PM   #8
Round on both ends
SafeHarbor's Avatar
1975 28' Argosy 28
Rutledge , Georgia
That's the last time I give a long answer without knowing the owner's intentions.
Lamar
Klaatu barada nikto
Old 09-08-2006, 04:47 AM   #9
After we pressure washed the outside (and then my 4 year old and I had to be decontaminated with 2 baths) we could not understand why the A/C would not come back on, also the outlets would only work if the old non-working fridge was turned "off", worked on this for hours. Until i figured out I had a bad outlet in my garage! Changed outlets and everything (110v electrical) worked perfectly. What a day. Next the kitchen goes out the door.....
Old 09-08-2006, 06:49 AM   #10
kramynot2000's Avatar
1978 31' Sovereign
Sacramento , California
Images: 20
Lamar
Lamar,
I just picked up my '78 31' Sovereign about a month ago so you long answer is perfect for me!
Tony and Gale
1978 31' Sovereign International
kramynot2000 is offline   Reply With Quote
Old 09-08-2006, 10:21 AM   #11
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
Hi safeharbor, your advice did not go unheeded.. I have not used my propane since I got my moho. after reading your advice I went out and applied your advice. found 3 leaks..THANK YOU for posting your thread..
bobchevy89 is offline   Reply With Quote
Old 09-08-2006, 10:54 AM   #12
Waynon's Avatar
1986 34' Excella
Not wasted info!
Hey Safeharbor, don't worry, looks like several of us really enjoyed and found your post useful.
I've owned my Excella for a couple of years and thought I knew a whole lot about it, but had never realized there was a separate cut-off for each appliance. Thanks for that. I'm new to the forums and am trying to learn all I can. If that's all I learn today it's enoungh to make the visit worthwhile. Thanks.
BTW, as I said I'm new and haven't figured out the "Karma" system, but I sent you a positive karma vote for that long and thoughtful post.
Waynon
Old 09-08-2006, 12:08 PM   #13
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Hang in there Safeharbor- looks like you have a few friedlies here in northern california! P.S. I did not think your post was all that long considering all the good gouge you offered up.
doorgunner is offline   Reply With Quote
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
Start of restoration '77 Argosy 20ft barbwire All Argosy Trailers 18 08-15-2004 06:42 PM
Aaaargh!!! Motorhome won't start!!!! AGAIN!!! eraffety General Motorhome Topics 14 01-19-2003 06:40 PM
I must be sick ? Bfrank Airstream Motorhome Forums 14 08-14-2002 02:30 PM
