Old 05-29-2008, 06:59 AM   #1
1972 29' Ambassador
Saint Petersburg , Florida
where did the water pipe go?
My 72 ambassodor center bath unit was modified when the hot water heater broke by PO. He replumbed the area under the bed and added an electric WH. I am trying to convert it back to the gas unit but don't see where the original water connection to the outside went. Does anyone have pictures or the plans of how the original water input was set up?
gbroughman is offline   Reply With Quote
Old 05-31-2008, 09:56 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Water system
Here's the plumbing diagram you wanted. Hope it helps.
Waste Water pipe cap - 1964? RetroTrailer 1960 - 1964 Globetrotter 2 02-21-2008 12:06 AM
PEX pipe and the Water Heater DoorMan Water Heaters, Filters & Pumps 10 11-26-2006 08:33 AM
Bad Problem w/ Water Pipe rroessler Fresh Water Systems 20 06-05-2006 11:23 AM
Water Pipe freeze protection BB 55 Bubble Winter Living 4 05-10-2005 01:02 PM
Pipe insulation niftypkg Plumbing - Systems & Fixtures 1 09-22-2002 09:34 PM
