Old 07-22-2010, 03:32 PM   #15
Originally Posted by Distantdrummer View Post
Well from the pic in post #1 I agree that is "u"channel.
I thought all the 70's era trailers had what some have called "y" channel. That is there is a 2nd channel underneath the "u"channel that receives the plywood floor.It is all a single extrusion piece.
Maybe that "y" is used only on the straight sides and just plain "u" is used on the curved fore & aft?
Am I correct ?
The "Y" front and rear floor channels, were not used until the later 1970's models.
Correction. The "Y" shaped channel started in 1972.
Ah yes, the memory. Like the ripples in the water.
Old 07-22-2010, 04:22 PM   #16
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Yes...you can get 2024 from the supplier in Ft. Worth. Its what I use for polished panels. You can get any other you want...just talk with them.
Old 07-22-2010, 06:37 PM   #17
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Yes - the U orC whichever you want to call it is for the front and rear (fore and aft) the Y is for the straight sides. It seems the Y stops about 1 foot of the U in the rear part of the AS,
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 07-22-2010, 06:39 PM   #18
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
MR - do you have their web address by chance? PM if need be.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
