Old 04-27-2017, 08:48 AM   #1
1976 31' Sovereign
Terre Haute , Indiana
Where can I find the knobs for the window tilt out handle/lever?
1976 Sovereign -
One of the small plastic 2 piece knobs that goes on the end of the handle/lever that opens / tilts the window out is broken. I've looked at all of the online retailers I can find and none of them offer this part.
Does anyone know where I can find a replacement?
thanks,
Clay
ClayDC is offline   Reply With Quote
Old 04-27-2017, 08:53 AM   #2
Long Island , New York
Just posted on another thread, click on arrow to go there and see the attached photo.
Originally Posted by KJRitchie View Post
Purchased from Vintage Trailer Supply new window knobs. The Silver Mistress likes her bling. These knobs have set screws. Decided to switch after I lost one of the plastic ones without set screws.
Kelvin
Old 04-27-2017, 09:12 AM   #3
1976 31' Sovereign
Mine are different than that. They are round / barrel shaped. One goes on each side of the lever to make it into a t-handle. I'll take a picture and post it up in a bit.
Old 04-27-2017, 09:18 AM   #4
Nothing here I guess?
http://www.vintagetrailersupply.com/category-s/230.htm
What about this shaft, does it help?
http://www.vintagetrailersupply.com/...p/vts-2026.htm
Probably not.
Old 04-27-2017, 09:32 AM   #5
1976 31' Sovereign
nope, nothing in there unfortunately.
The levers are available on there though:
http://www.vintagetrailersupply.com/...p/vts-1051.htm
just no knobs.
Old 04-27-2017, 10:05 AM   #6
I saw those levers and thought they might be right. We had a 1985 25' AS which had those I think. You might have to jury rig something from wood dowel stock drilled out for a solid shaft/bolt with washers on each end, and an aircraft nylon stop nut on one end?
Or if you want to get fancy, get some solid aluminum bar stock and fabricate something like this? If you want to get really fancy, you could drill out the center of the bar stock knobs, tap some threads in and use threaded rod hidden inside.
Good luck!
Peter
Old 04-27-2017, 10:25 AM   #7
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Those are the deluxe window openers, and have been NLA for many years.
Old 04-27-2017, 10:51 AM   #8
Please post photos when you have a chance, in particular any end shots of the side handles which show where a shaft went (?) into/through the handles.
Old 04-27-2017, 10:52 AM   #9
Do you know if any shop ever made some up in a private run? Seems like there might be demand for such a regularly used/damaged item IMO.
Peter
PS -- Confirmed here in 2011:
Originally Posted by Inland RV Center, In View Post
Ken.
Those knobs came with the "deluxe window hardware".
They have not been available from Airstream, for many years.
Old 04-27-2017, 11:42 AM   #10
2016 28' International
Perry , Georgia
Kelvin,
Thanks for the heads up on the knobs. Perfect for my windows.
Wish jewelry for my wife was that cheap.
John
J-K Georgia is offline   Reply With Quote
Old 04-27-2017, 01:15 PM   #11
1976 31' Sovereign
Here is a picture of the knob in question.
Old 04-27-2017, 01:29 PM   #12
Thanks. Is there a threaded rod holding them together, and can you unscrew things to check the thread size? I bet a couple of standard cabinet knobs could be made up to mimic this set up.
For instance, two of these SS 3/4" thumb knobs could be joined with some hidden threaded rod running through the end of the lever arm?
https://www.amazon.com/Liberty-63118...et+knob+barrel
I imagine plenty of other sizes and finishes could be found to work, including white porcelain.
Old 04-27-2017, 01:31 PM   #13
1976 31' Sovereign
it's got a nut and bolt holding it together. There is a hex built into the center of one side (maybe both sides, I didn't look that close) that keeps the nut from turning.
I'm sure I could take a piece of all-thread and 2 cabinet pulls from the hardware store and make that work. I'm not sure on the thread size of the existing but I could find that out.
Old 04-27-2017, 01:40 PM   #14
PS -- Here's a 25-pack 17mm diameter in aluminum, for $19.99 on sale.
https://www.amazon.com/dp/B00X0LKIK8..._t2_B003E78G2U
Sold!
Old 04-27-2017, 01:54 PM   #15
1976 31' Sovereign
ok, I'll admit, that would look pretty cool!
Old 04-27-2017, 02:49 PM   #16
Definitely! Makes me want to drill out our arms and install two knobs on each arm instead of the single current model which I linked early in this thread. The two knobs sticking out left and right give you some real surface area to grab with a couple of fingers to lift and raise the window, or lift and lower to drop the window. If you decide to get some please post a photo.
Peter
Old 04-29-2017, 08:29 AM   #17
Bakersfield , California
Peter
Peter, that whole scenario is very impressive. I'm going to come to you next time I have a problem in the Baby Beluga.
babybeluga is offline   Reply With Quote
Old 04-29-2017, 09:14 AM   #18
Thanks, it won't be "stock" but those aluminum knobs would look great inside an Airstream!
Reaching over our dinette table to raise the two large windows on the street side is very difficult with each lever having the small single OEM knob. With both levers each incorporating the linked dual aluminum knobs, it would be much easier.
Old 05-18-2017, 02:02 PM   #19
1975 31' Sovereign
Henderson , Nevada
i like the idea of wood dowels, do complete change out. in your spare time
Barbcida is offline   Reply With Quote
Old 05-30-2017, 11:23 AM   #20
tonydead's Avatar
1976 25' Caravanner
Kent , Washington
Going to replace all mine with wood. Wood dowels drilled out on a drill press then finished. Will be willing to sell or give mine away, at least as many as I have that aren't broken already.
tonydead is offline   Reply With Quote
Window handle knobs jmalexan Windows & Screens 4 04-04-2018 06:54 AM
Need 8"x29.75" tilt-out Creation window glass for 1999 Safari 27' roscher Windows, Doors, Locks & Vents 1 09-29-2015 03:04 AM
Hehr 614 Link Lever - Window lever WANTED Huggsterman Airstream Classifieds 0 06-14-2014 01:20 AM
How to tighten window handle knobs on newer Airstream brad1 Windows, Doors, Locks & Vents 4 10-13-2012 01:00 PM
Window Lever Knobs 82 34Limited General Interior Topics 3 08-31-2009 05:03 PM
