Old 06-01-2007, 11:50 AM   #1
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
What's with the Rubber Plug in the Floor?
I'm refinishing the cabinets in the 58 Flying Cloud. Pulled out the streetside cabinet with the fridge. Under was this plug, all taped up. I looked at the belly and found that the plug is over this 1 1/2" screened hole. Anybody have an explanation?
ID:	38418   Click image for larger version
bevman is offline   Reply With Quote
Old 06-01-2007, 12:54 PM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I wonder if the original refrig was an icebox? Perhaps this would have been connected to a drain hose?
I'll bet you are enjoying your project!
Pat
pmclemore is offline   Reply With Quote
Old 06-01-2007, 12:59 PM   #3
An icebox is a good suggestion. Also, some RV refrigerators, including our Dometic, have a drain hose to collect the meltwater while de-frosting. In ours, it collects in an aluminum cup at the rear of the refer. This can fill and overflow, so your drain-hole is a good system.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 06-02-2007, 12:27 PM   #4
bevman's Avatar
All indications point to the existance of a 3-way original equipment fridge (venting, roof cap, propane stub, soot, etc.). I found the warranty card from the "new" fridge - a Norcold dated 1974. It had a harvest-frickin-gold front panel that just screamed "Replace me!" A friendly guy at the local plywood specialty store sold me a scrap of cherry veneer ply, and even cut it to size. $5!
I'll tear open the rubber plug and see what's under it. I'm dubious that it is a water exiting portal since it's an inch and a half, and covered with a screen. Seems like it would allow water to get between the floor and belly skin, rather than a clean exit.
I'll be back
Old 06-02-2007, 02:53 PM   #5
Ready-to-Travel
pmclemore's Avatar
Good old Harvest Gold. Or Avocado, for that matter. No doubt about the era, is there?
Pat
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 11:21 AM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 06:28 PM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
Total floor replace 74Argosy24MH Repairing/Replacing Floor &/or Frame 1 06-27-2002 04:05 PM
