Old 01-30-2015, 01:37 PM   #15
1982 31' Excella
Rochester , New York
This is an interesting article on foil Insulation.Stay Away from Foil-Faced Bubble Wrap | GreenBuildingAdvisor.com
Dragonfly100 is offline   Reply With Quote
Old 01-30-2015, 03:59 PM   #16
DFlores's Avatar
1968 22' Safari
Prodex is not foil faced bubble wrap, Reflectix is foiled faced bubble wrap.
Prodex has a foam center.
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 01-30-2015, 04:12 PM   #17
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
Just finished up with 1.5" R-Tec from Home Depot. $16 per 4'X8' sheet. What was interesting is there seemed to be 2 different "flavors" of it. Some sheets on the shelf were more dense and less flexible, others were softer and more spongey. I used those for the more curved sections. I saved the scraps and did the knooks and crannies last which resulted in very little waste. Very exciting when all the sudden my shop light is heating the camper and I'm peeling off layers to keep from sweating and it's 35F outside!
'61 Safari
http://airwave503.blogspot.com/
Airwave503 is offline   Reply With Quote
Old 01-30-2015, 05:23 PM   #18
Harperbear's Avatar
Arden , North Carolina
Beyond r value has there been any talk of close cell being a water barrier? From my understanding open cell foam is an air barrier and closed cell is a water barrier. Sprayed in the trailer it should seal all rivets and seams. If that is true the value of closed cell foam just went up in my book. Let me know if I am wrong
Harperbear is offline   Reply With Quote
Old 01-30-2015, 06:09 PM   #19
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Closed-cell foam will not ABSORB water. However, that doesn't mean it will BLOCK water from getting inside if you have a leaking outer skin seam. Everywhere you have a seam in your foam, there is a potential for water to leak through.
And yes, even blown-in foam can have seams, between one pass of the spray gun and the next.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-02-2015, 07:04 PM   #20
1973 25' Tradewind
prospect , Connecticut
Has anybody thought of spraying inside of skins with Lizzard Skin Ceramic Insulation? its waterbased, will act as a waterproofing over all rivits, ceramic beads are supposed to stop heat transfer, it acts as sound reduction, and a vapor barior all in one. I used it in the restoration of my 1950 Chevy, it worked great. its not cheap but does alot of things for one price. i was going to use that and the blue foam board. I have multiple thickneses on the foamboard as it was all for free, about 30 sheets, all seconds from foam plant where my friend works down the street 1/2' to 1'. what about liquid nailing those foam sheets to inner skin, mainly where it curves to keep in place, and than gluing together tomake one thick sheet? That was my plan. Look into the Lizzard Skin, lots of info out there on it.
alistheman is offline   Reply With Quote
Old 02-03-2015, 07:59 AM   #21
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
Alis, Your Lizzard skin approach is probably pretty good. I didn't find a need for any adhesive because I cut my pieces to fit snug so they held each other in place, even in the rounded end cap. Then I went over the seams with foil tape for the full vapor barrier.
Depending on how thick the Lizzard Skin is you should probably be able to go with the 1" throughout.
'61 Safari
Old 02-04-2015, 06:12 AM   #22
1973 25' Tradewind
lizard skin is 1 or 2mm when dried, I forgot its been 5 years since i used it. alot of people tried to mix latex paint with ceramic spheres, but sometimes ya just got to bite the bullet and go with the real deal.
Old 02-04-2015, 07:02 AM   #23
1988 Argosy 32
Lomita , California
I have a 1989 square stream, when A.S. bilt it they shot the inside of skin with ureathane.
The stuff is as good as the day it was guned on, look into haveing it shot by a pro Copany
Wolfe is offline   Reply With Quote
Old 02-04-2015, 09:54 AM   #24
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
Great thread: I'm at a similar junction with a '65 and there is something
about plastic bubbles in an area that might well get over 100 degrees
that just rubs me the wrong way. BIG fan of Prodex spacers for minimal outer
shell contact and air barrier.
Del Gurney is offline   Reply With Quote
Old 02-04-2015, 10:14 AM   #25
Cardinal283's Avatar
Dallas , Texas
Slightly off topic but I'm at the same stage in my restoration. Getting ready to do a combination of prodex and fiberglass. I've been concerned about applying a sealer to the inside of the exterior skin before putting the insulation in. Perhaps something similar to lizard skin. Is there a thread about sealers to use to replace the tar like substance that was originally used on mine?
Cardinal283 is offline   Reply With Quote
Old 02-06-2015, 06:05 AM   #26
Gal
Gal's Avatar
1960 26' Overlander
In the North , FRANCE
Images: 8
Hi,
I've stopped my choice.
Many possibilities and each person thinks different, few insulate material are better than other and some different prices etc....
I choose rockwool in 45mm (the same as the beginning...), why ? Because :
It's easy to remove,
It isn't very expensive
it looks like the same as he original brand (fiberglass)
I begin this weekend by the door
1960 Overlander
2002 Chevrolet Tahoe
Gal is offline   Reply With Quote
Old 02-10-2015, 03:20 AM   #27
Unka Jack's Avatar
Fonthill , Ontario
I was just speaking with Roxil yesterday. They also have a commercial product called "Acoustic Fire Batt" which is the same product, but comes in a variety of thicknesses in 1/2" increments including 1.5, 2, and 2.5" priced comparatively to the regular batts. That way you don't have to split the regular batts to get the thickness you need.
Cheers,
Jack
Although it seem like I know what I'm doing, I'm just standing on the shoulders of giants who have done this before and kindly posted their journey.
Cheers,
Jack
73's VE3ZPW
Unka Jack is offline   Reply With Quote
Type 3 Glass Bar in a Type 2 Hinge rasmuw Windows & Screens 0 12-09-2013 10:18 PM
Best type of floor insulation? project66 Repairing/Replacing Floor &/or Frame 12 06-20-2012 10:43 AM
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 12:16 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
