Old 10-24-2013, 06:36 AM   #1
1962 24' Tradewind
St. Petersburg , Florida
What to use to clean yellowed interior walls of my '62 Tradewind
Hi there, feel like I am asking advice on EVERYTHING and grateful to this great website and all the helpful people. On my recently acquired 62 TW a former owner primed the front (kitchen forward) walls and ceilings and did a crappy job, 1. is there a way I can remove this primer? I sort of assume I just have to paint that area. As for the bedroom and bathroom the original zolotone finish is still there and in tact but it is very yellowed and discolored overall, not sure if that is from age, a smoker or old leaks but I need advice as to how to handle and clean up and freshen up. Thank you!! Mary in Florida
Mary Burris is offline   Reply With Quote
Old 10-24-2013, 06:40 AM   #2
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Hi Mary, congrats on the TW , long time comin".
Try Krud-cutter on the yellowed walls, worked great for us. Not sure what to tell you about the primer as there are many different types
GL
Barry
goshawks00 is offline   Reply With Quote
Old 10-24-2013, 08:22 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Good primers are usually thermal sets and can not be dissolved or easily removed without removing all the paint and zolo. A strong solution of Spic and Span is usually enough to get tobacco stains off. You need to go over it at least twice to get it all.
Old 10-24-2013, 09:27 AM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Mr. Clean Magic earasers have been usefull for me.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 10-24-2013, 10:09 AM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
For an off-the-wall suggestion, Efferdent denture cleaner. Better for spot cleaning than wide-area cleaning because you'd need so much of it to cover a wide area.
I've also used Efferdent as a quick-and-easy toilet bowl cleaner. Fill the bowl, drop in half a dozen tablets, and come back later to flush.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-26-2013, 09:39 AM   #6
Yelm , Washington
Images: 14
I also am pondering what do do with my 62 overlander, the interior has never been painted, original looks yellow and speckled...would rather just paint it but don't know if it will decrease the value....I just need some reassurance from a group of Airstream folks.
arlanan is offline   Reply With Quote
Old 10-26-2013, 09:53 AM   #7
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
The "speckled" part is Zolotone, it's integral to the paint - the yellow is probably just 50 years of grime. Try cleaning it with any of the above and see if you can live with the results before resorting to painting over it. For some, the original Zolotone is an added bonus to the trailers of this era and plain ol' paint is not as desirable. But ultimately, it's your trailer to do with as you please.
Shari
Old 10-26-2013, 09:58 AM   #8
InsideOut's Avatar
1956 22' Safari
Images: 108
You may want to try a very mild paint stripper like Motsenbocker's Lift-Off to see if it will budge the "primer" and leave the Zolotone. I had pretty good luck with it on our trailer before we decided to strip the whole thing & re-do the Zolotone on the whole trailer.
Shari
