Old 09-06-2011, 03:24 AM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
What to use for trim inserts
The old trim is discolored and to fragile to save. I want to replace trim but am wondering if anyone has tackled that kind of project?
Mrcrowley
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 09-06-2011, 06:00 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Mrcrowley!
Mrcrowley
If you are referring to your 1977 Sovereign, the trim molding inserts are still available for both interior and exterior. I have seen other sizes posted at various times, but I suspect that all of the nosing and insert trim pieces can still be located through an Airstream dealer or service center.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 09-06-2011, 08:27 AM   #3
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Standard Replacement Items
As Kevin says, all sizes are widely available and easy to remove and replace.
Inland RV Center - The Nations Leading Expert in Airstream Innovations
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 09-06-2011, 08:35 AM   #4
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
If you have a table saw and some laminate (Formica or similar) of your choice, you can rip strips that will fit in to the interior of your trailers aluminum trim. I did that in my previous trailer. Just use the Vertical Grade laminates. It is thinner and slides in very easily.
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 09-06-2011, 07:02 PM   #5
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Some of the trim inserts are aluminum. Specifically, the round overs on the overheads and beds/gaucho and the inserts that fit into the plastic tambour rollers. They are all aliminum pieces with the wood grain cemented directly to them. So, if u want all to match, be selective with your replacements.
Phrunes is offline   Reply With Quote
