Old 05-12-2014, 10:26 AM   #1
1972 25' Tradewind
fort lauderdale , Florida
What spray sealant are you using?
I bought this product a few months ago to try on something around the house but it wasn't what I needed. I then came across a plastic bucket with a split in it and decided to see if it would seal.
It did seal it but after a few months, the "Leak seal" became brittle and started breaking away. I don't think plastic provides the best bonding surface for this product BUT, I also wouldn't think this "supposed" flexible rubber coating would become brittle either.
In the near future I will be using a spray sealant on my interior rivets, seams,etc before adding new insulation and reattaching the interior skin.
What product have forum users had the best luck with?
thank you
ID:	211760   Click image for larger version
ehodg66 is offline   Reply With Quote
Old 05-12-2014, 10:56 AM   #2
1981 31' Excella II
New Market , Alabama
I would not use the stuff. I have never had much luck with Rustoleum paint either.
Perry
Old 05-13-2014, 06:48 AM   #3
1972 25' Tradewind
Thanks Perry,
Any suggestions of what I should use?
eric
Old 05-13-2014, 08:28 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Flexseal (that stuff sold on TV) looks similar to the Rustoleum product you used. It was discussed at the Vintage Trailer Academy last week in response to a question about using it on the interior of a stripped trailer to seal it. The answer from an expert was it is not durable enough and fails in a very short time. We used Parbond on our seams inside before we insulated. I haven't heard of any spray sealant that works. None was suggested at VTA, either.
Kay
Old 05-13-2014, 01:46 PM   #5
cdmagda's Avatar
Images: 51
I used Sika-Flex...I put on a bead and fingered it.
cdmagda is offline   Reply With Quote
Old 05-13-2014, 02:00 PM   #6
1972 25' Tradewind
Thanks everyone.
Looks like parabond and silka-flex are the answer
cheers
Old 05-14-2014, 06:08 AM   #7
1981 31' Excella II
You can use the Trempro-635 or any good sealant but you need to get all the old goop off first.
Perry
Newbie Using Sealant McGillicuddy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-02-2011 08:33 PM
How do you actually use the tank flush/spray? dre00 Waste Systems, Tanks & Totes 8 02-06-2009 06:20 PM
Can you Spray on a new Plastic Coat? JohnG Clearcoat, Exterior Paint & Trim 1 07-24-2004 10:38 AM
Bug Spray jbando Exterior Restoration Forum 4 06-24-2003 03:41 PM
Plasticoat vs. Clearcoat spray...?? HappyChi Clearcoat, Exterior Paint & Trim 9 08-12-2002 06:13 PM
