Old 08-23-2010, 12:15 AM   #1
1958 Overlander
marvin's Avatar
1958 26' Overlander
Lenore , Idaho
what is this vent for?
Still trying to get the layout of my '58 Overlander. This might help. There is a hole in the floor about 4 inches across near the front door and below, in the belly skin, there is this vent: Can anyone tell me what went above this hole/vent? Thanks
marvin is offline   Reply With Quote
Old 08-23-2010, 12:18 AM   #2
Ottawa , ON
Is your refer anywhere near that hole...?
Old 08-23-2010, 12:20 AM   #3
1958 Overlander
marvin's Avatar
1958 26' Overlander
Lenore , Idaho
Maybe it was lol. I don't have one. There is an oblong vent in the roof above it. Why is the vent so big but have only one hole? I'm afraid vents have been added through the years. I'm having a heck of a time figuring out where the oven and fridge went. If the fridge did go here, there is a copper propane line coming up about 3 feet to the right of this. I assume this is for the stove. Did Airstreams come with the stove and fridge on the same side? I've never seen one.
Old 08-23-2010, 12:38 AM   #4
Ottawa , ON
Your model is older than I'm familiar with, and I'm sure someone that knows it will come along, but I'm willing to bet that it was where the refer was.
They require a floor vent and a roof vent. LP gas is heavier than air (floor vent) and heat needs to leave (roof).
Good luck with it!
Old 08-23-2010, 12:40 AM   #5
1958 Overlander
marvin's Avatar
1958 26' Overlander
Lenore , Idaho
Good luck with it!
That makes sense, thank you!
Old 08-23-2010, 03:31 AM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Check this site if you've not done so before. There's a pic in trailer 7076 that has a vent that looks a lot like the roof vent your showing.
58Overlander
Old 08-23-2010, 04:43 AM   #7
richinny's Avatar
2011 34' Classic
you might find information here:
Airstream, Inc :: Specs - 1950
Ricky
Old 08-23-2010, 05:54 AM   #8
1977 Argosy 24
Milltown , Wisconsin
I'll bet it was for the furnace, the floor vent gave the furnace fresh air to burn which vented the fumes out of the roof. Those old furnaces were convection with no fan.
ventport is offline   Reply With Quote
Old 08-23-2010, 06:15 AM   #9
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I have a 57 Overlander and it has a similar hole/vent below the furnace Im guessing it was for combustion air.
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 08-23-2010, 08:05 AM   #10
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
furnace air supply
I believe it is for the furnace...inlet air supply. If so, look at the ceiling above and see if there is an exhaust vent hole....probable covered over.
Name:	heater stack.jpg
'76 Argosy have vent pipes at roof (nicro vent install idea) BrianD. Waste Systems, Tanks & Totes 6 11-08-2014 06:28 PM
How do I install vent covers over my vent covers? bigjohn Roof Vents, Skylights & Fans 1 07-29-2010 03:34 PM
I just need to vent. airjeff Buyer Guidelines 15 05-02-2010 08:47 PM
louvered stainless steel vent or chrome vent toastie Roof Vents, Skylights & Fans 0 10-18-2009 04:01 PM
Loosening Vent Handles and Aluminum Vent Replacement kincaidjesse Roof Vents, Skylights & Fans 4 04-16-2007 10:37 PM
