08-30-2011, 09:13 PM
1966 26' Overlander
Sammamish
What is this? - Pro-Tex all purpose pad?
Just purchased a 1966 Overlander, 26ft in need of much TLC. Cleaning and painting the interior walls, but have a mystery piece I removed, just curious as to what it was used for back in the day.
14"x17" Pro-Tex all purpose pad. Was riveted to the curve of the ceiling/wall area just to the right of the storage units above the fridge area. Front side is textured metal, underside is cardboard with the markings on it. Removed it from the wall (thinking it was a patch to cover a hole or something), and found nothing but squeaky clean vinyl wall underneath.
Any ideas?
08-31-2011, 08:00 AM
Jupiter
It appears to be asbestos or similar backing on a stainless plate made for easy grease splatter clean-up. If there were no heat sources underneath (or portable ie: Coleman stove) then it was probably there for looks alone...
08-31-2011, 08:40 AM
2004 31' Classic
lubbock
Haven't a clue, but
What will you be using to paint over the vinyl ?
08-31-2011, 08:51 AM
Ballonoff manufactured asbestos iron and stove mats in the 50's and 60's.
They were used to protect counter tops, tables, etc. Maybe a PO placed it there to protect the interior surface from a heat source.
William C. Swinney
08-31-2011, 08:59 AM
2019 27' Flying Cloud
Albuquerque
PO Had a Heater
Previous Owner probably had an unvented, propane heater tucked in that corner. Check to see if there is nearby hole in floor where he ran copper tubing.
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
08-31-2011, 09:09 AM
2008 27' Classic FB
Burkburnett
Originally Posted by Kevin245
...Maybe a PO placed it there to protect the interior surface from a heat source.
My mom had one of those when I was a kid. It was a counter/table protector so you could place a hot pan off the stove or oven on it. The warning was so folks wouldn't put it on a burner. I agree with Kevin. Maybe a PO had a Coleman stove or lantern below it and placed it there to protect the wall surface from the heat source.
AIR 47751
08-31-2011, 01:25 PM
Albuquerque
This Was Popular in That Spot in that Era
08-31-2011, 03:24 PM
1967 22' Safari
Long Beach
My '67 Safari has a propane lite (works like a coleman lantern did). You turn on the propane and lite it with a match. It's mounted at the end of the overhead cabinet in the same position your photos indicate the asbestos heat shield was located. I believe the previous responders are correct, that a previous owner mounted it as a heat shield, maybe for a heater or possibly for a propane light like mine.
08-31-2011, 05:31 PM
Albuquerque
Helmsman, Your description seems more likely than mine. Do you have a picture?
08-31-2011, 06:01 PM
"Cloudsplitter"
2003 25' Classic
Houstatlantavegas
, Malebolgia
Yep...our 63 Safari had one above the lpg light also.
I guess they frowned on now, but sure came in handy on a cool morning for a little light and warmth.
08-31-2011, 11:09 PM
1966 26' Overlander
Sammamish
Thanks everyone for the great feedback! I'm gonna go with wall protector for a heater of some sort. Would love to see a photo of your propane light, helmsman.
08-31-2011, 11:45 PM
1966 26' Overlander
Sammamish
I scrubbed all the interior with a mild soap and water mixture, then wiped down all the vinyl with an odorless paint thinner to remove any "stickiness" from the vinyl (some folks complained about a sticky substance coming through their paint, although my walls weren't sticky - better safe than sorry). I then did 2 coats of KILZ primer original (I tried odorless, but it was much too thin...like painting with water). Looks so good, I may just stick with the white primer, but if down the road I want to add color, I have the base layer all set to go.
09-11-2011, 12:55 PM
Calgary
, BigBrosMo
Where to find replacement?
I just took a similar pad off of my boler. It was under the cabinet above the gas stove. Different size but from the same company and has the same "stamp" on it. I am trying to find a replacement or something similar since this apparently has asbestos in it. Any ideas? Mine is rusted to the point of no return.
Thanks.
09-11-2011, 01:17 PM
1961 22' Safari
Union
My '61 Safari had a propane light mounted on the end of the cabinet much the same as yours. It also had a heat shield, but was a part of the lamp itself. My guess is that the pad was for the propane light.
Sam
