If it is a propane heater, I wouldn't want it inside the trailer. As old as it may be, it may leak propane. Propane is heavier than air and settles to the floor until you use a match. That will get rid of the propane and the trailer. Remove it and cap the line securely. Use yellow teflon tape when you cap it. In the US, yellow tape is for gas lines, white is for water lines. Then it sounds like you will have to install a new furnace. The furnaces are designed to isolate the gas and fire box from inside of the trailer so you don't get propane fumes in the trailer.
Gene
Gene
