Old 09-20-2011, 01:22 PM   #1
1981 31' Excella II
New Market , Alabama
What is the inner skin coated with?
I was wondering what the inner skin is coated with? It looks like some sort of plastic fabric. Is there any way to get rid of the oily film on the stuff? I was wondering if 409 would work.
Perry
Old 09-20-2011, 01:43 PM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Graffiti remover, solvents, big-box store spray detergents - nothing worked as well or as cheaply as the $3 'Spic 'N Span' All Purpose Cleaner liquid.
I've tried everything and found spic'n span diluted 1:1 and a bristle scrub brush worked the best. Once I had found the rounded 4" nylon brush I could chuck in a drill it all got much easier. After scrubbing, wipe dry with terry cloth towels and then a clear water wet towel rinse.
Old 09-20-2011, 02:22 PM   #3
Perry
Perry.
The wall covering is a "vinyl" that's bonded to the aluninum.
Spic and span is a good cleaner, if you use a lot of elbow grease with it.
After it's clean, you might want to apply a couple of coats of "Future floor acrylic" to it.
You will be amazed of how great it will look.
You can roll it on, spray it on, or brush it on.
Every grocery store sells it.
After it's on, all you need to do is just wash an area, since it's good enough for kitchen floors.
Old 09-20-2011, 02:54 PM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
We had great success with "Superclean" degreaser. It was once sold by Castrol, but not now. One can get it at Wal-Mart. It is packaged in a purple gallon jug. We used it full strength in a spray bottle and wiped it off with a damp rag.
We did apply the Future Floor product after cleaning, as Andy suggests.
Regards,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-20-2011, 02:58 PM   #5
Regards,
How does your interior look with that Future floor acrylic on it?
If you like it, how about a photo for others?
Old 09-20-2011, 03:02 PM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Krud cutter. Can get it at Walmart. I spray on the Krudcutter, wipe off, the wash with simple green and water, then dry. Use terry cloth towels. Works.
Old 09-20-2011, 04:25 PM   #7
SteveH's Avatar
Common Sense , Texas
409 worked on ours.
Regards,
Steve
Old 10-05-2011, 06:56 PM   #8
1985 31' Limited
Nellysford , Virginia
Thumbs up Cleaning
I just washed our entire inside down with a product called "Oil Eater". Did a fantastic job of getting rid of all the old airborne grease that had built up on the unit over the years. Very easy to use. Walls and ceiling look like new. Highly recommend it. Got it through Amazon, about $12 for a 32 oz spray bottle but it is diluted before use so that will last a while.
RTurnConn is offline   Reply With Quote
Old 10-08-2011, 08:57 PM   #9
1975 31' Sovereign
1968 26' Overlander
Lost Angeles , California
It's called Zolotone. And cleaning the oily residue off of it wasn't enough for me. A couple gallons of Klean Strip from home depot and about 60 hours of labor will have your interior down to the bare aluminum leaving no memory of the grimey faded yellow zolotone.
All I need is a some solar panels, and a place to park outside the smog of LA.
1968 Airstream Overlander
1975 Airstream Sovereign
TV = 1997 Ford F250HD Powerstroke
hartley1212 is offline   Reply With Quote
Old 10-09-2011, 07:35 PM   #10
1981 31' Excella II
My Zolotone is not in bad shape overall. Not bad enough for me to want to strip it. It seems to be pretty durable stuff. My entrance door has some sort of permanant stain on it and I may strip that.
Perry
Old 10-09-2011, 07:58 PM   #11
Splitrock's Avatar
Sioux Falls , South Dakota
Wash with TSP & water, wipe with clean cotton towel. Westley's whitewall tire cleaner works too but TSP is nicer to work with by far.
Apply with Scotch-Brite sponge.
Old 10-09-2011, 07:59 PM   #12
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
As a point of clarification, I believe that ZolaTone was last used in 1964 or 1965. ZolaTone is a paint product that has a multi-color spatter finish similar to what was utilized in the trunks of automobiles in the 1970s and before. This product produces a very hard finish and can be quite difficult to strip from the panels.
Beginning sometime in 1965 or 1966, a product called vinyl-clad aluminum was utilized on interior panels and continued for more than a decade. This vinyl remains attached to the aluminum with voracity . . . removal is quite a chore. One of the chief complaints about the vinyl-clad is that its surface becomes sticky over time . . . cigarette smoke, cooking byproducts, and adhesives all have been named as potential sources of the sticky residue. The residue can be cleaned with any number of grease cutting cleaners . . . then a coat of Future Acrylic Floor Wax can be utilized to keep the sticky residue from reappearing for an extended period of time. The entire interior of my '78 Argosy Minuet 6.0 Metre is made utilizing vinyl-clad aluminum and the cleaning process followed by the Future coating has been a success in keeping my interior free of the sticky residue.
Kevin
Kevin D. Allen
AIR #827
Old 10-09-2011, 08:06 PM   #13
1981 31' Excella II
I suspect the sticky/oily film is plasticizer used in the vinyl. It is amazing this stuff lasts as long as it does.
Perry
Old 10-09-2011, 10:30 PM   #14
Zolotone was last used by Airstream in the 1964 models.
In the 1965 models, they switch to the "vinylclad" interior aluminum.
Skin & Corrosion Updates silverhound Clearcoat, Exterior Paint & Trim 39 10-11-2012 11:01 AM
Outer skin of unit (roof to outer wall) jaharper Ribs, Skins & Rivets 1 08-01-2011 01:05 PM
sticky black tape between interior skin & frame? clipperguy Ribs, Skins & Rivets 1 03-21-2011 04:00 AM
Coated Aluminum glh101282 Clearcoat, Exterior Paint & Trim 6 02-24-2011 10:38 PM
Inside corrosion of outside skin Breadbug Ribs, Skins & Rivets 4 02-01-2011 10:37 AM
