Old 06-30-2004, 06:45 PM   #1
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
We've got a hole - now what?
We removed the TV antenna and bracket and patched the roof - aluminum and vulkem, but now have a cosmetic issue inside...
What do we do with the interior hole? The plastic round cover plate is still on but the crank handle thingy has been removed. sooo.... here's the question:
What should we put up? The plate is about 3 inches across and near a light.
My son suggested a round mirror (every guy wants a mirror over the bed?)
Neighbor suggested a stick on air freshener..
Other neighbor suggested a periscope...
HELP!
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 06-30-2004, 07:10 PM   #2
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
Sounds about the right size for one beer.
HELP!
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 06-30-2004, 07:11 PM   #3
Would a long tube fluorescent cover the hole and the existing light wiring?
Smoke alarm?
Mark
Old 06-30-2004, 07:13 PM   #4
blucloud's Avatar
2007 27' International CCD FB
1987 25' Sovereign
1977 23' Safari
North Olmsted , Ohio
Images: 20
Lightbulb Hole!!
It may be a great place to put the smoke alarm.
Dave
Quote for today: Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside thoroughly used up, totaly worn out and loudly proclaiming WOW...WHAT A RIDE!
(author unknown)
You never know what you can do
until you try to undo what you did.
blucloud is offline   Reply With Quote
Old 06-30-2004, 07:18 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
HELP!
Hmm. (for once) I am not being a wiseguy, but why not put a TV antenna back in the hole? I replaced my Winegard with a new model, it works well, and doesn't look like something you would see out back of a laundry room. It also gave me something to put into that awkward-looking hole in the ceiling. Installation was not tough, and makes picking up distant TV stations a lot easier.
If you don't want to do that, a compact ceiling fan would be another answer. The one I am thinking about is about 14" across, has 3 speeds, is covered all the way around, and the outlet swivels around while the fan runs, circulating the air two ways.
Another thing to mount there might be the smoke detector. The two little screw holes where it is mounted now will be a lot easier to cover up then a 3" gaping hole in the ceiling. It would also get the detector another couple of feet away from the stove. Then maybe the whole campground won't know when dinner is ready.
Old 06-30-2004, 07:28 PM   #6
LOST , Hawaii
Any way you could silicone the old handle back in the hole? If you can it would come out later if you wanted.
John
74Argosy24MH is offline   Reply With Quote
Old 06-30-2004, 08:05 PM   #7
mcneon's Avatar
Go to Home Depot and look for a doorknob wall protector plate. (I have no idea what they're really called, but this is what they do.) These are sold to stick onto sheetrock walls to keep doorknobs from going through, or to cover up the hole once the knob has already made its mark.
They're plastic, about 1/8" thick, and come in a couple of sizes as well as white and off-white colors. I used a 3-1/4" one in my '74 Argosy for just the application you're talking about. The texture even matches the original panel finish nicely.
These come with double-sided tape on the back, but I added a little silicone to make the installation more secure.
Bob McKeown
mcneon is offline   Reply With Quote
Old 06-30-2004, 10:28 PM   #8
Janet H's Avatar
1964 26' Overlander
Images: 90
Great ideas - keep 'em coming.
I see this as an oppertunity for something unique - if I put a plate-type patch over it, I think it will look - well - patched.
So I need something really terriffic - like say a view from below the water w/ flamingo feet dangling....
Why didn't we put in a new antenna? Because we camp to get away - for us, that means no TV and if it rains we can put a dvd on the laptop.
Old 06-30-2004, 11:12 PM   #9
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thumbs up Stroke of Genius~
Dave
(author unknown)
Dave,
Personally, I think that's an EXCELLENT idea~!!
Gets my vote~
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 07-04-2004, 02:24 AM   #10
JohnG's Avatar
Smoke alarm gets my vote too.
Just adding my 2’ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 07-05-2004, 11:47 PM   #11
Lightbulb camping with technology
good idea- smoke detector, or another light
eaglerab is offline   Reply With Quote
Center hole dimensions of the wheel. Airstream 1975! All Argosy Trailers 4 03-05-2004 07:33 PM
Hole at the Jack lift point odfarley Jacks, Stabilizers, Lifting and Leveling 4 12-26-2003 12:30 PM
10 gal in a 6 gal Hole aviontt Water Heaters, Filters & Pumps 18 12-19-2003 06:23 PM
Overhead hole in console AccessMaster Airstream Motorhome Forums 2 04-29-2003 08:58 AM
Door hinge bolts/access hole ViewRVs Airstream Motorhome Forums 9 04-29-2003 08:44 AM
