Old 05-28-2007, 08:46 AM   #43
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Good eye Royce- I've owned this one for 15 or so years, it's my favorite hand tool. Really sharpens up well with waterstones and holds a fine edge for a long time.I looked at the wood shop just last week, planes are getting expensive, at least nice ones!
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 05-28-2007, 01:25 PM   #44
JimGolden's Avatar
1977 31' Excella 500
I'll check out that book DG. I had some composites training in college and have the books from that. I've worked on some boats and fixed the fairing on my Goldwing after I dumped it.
I'd like to attend several of those Sportair workshops. I did just take a semester long welding class at the local community college and got myself a new Lincoln TIG machine. That's for the plane. It'll do stick also, which is for about everything else. IF I need a new frame, I'll stick most of it.
Oshkosh is very high on my list. My best bud out in Seattle (he still works for Boeing) wants to rendevous with me up there summer 2008. Since Camp Schuler appears to be basically a field, I'll need tanks and a generator. Don't know if I can be ready in time....
Sun and Fun I flew over once in a 172 doing my long cross country back in '89, but never got to go to it. The only "big" EAA show I've ever gotten to go to was the Arlington one when I worked at Boeing. It was great though. I'd really like to get up to Osh.
I know the new AS classics are using Corian counters and hickory cabinets. Hickory is very heavy, and corian is too.
I guess rather than get super nuts with it, I'd just like to beef mine up a little bit and not add a ton of weight to it.
I woodwork too....funny how the guys on here that are into fixing up these old trailers and are into airplanes are also into woodwork. If you guys are like me, you're always busy, can never sit still, and always have a never ending list of projects to work on!
Like they said in "Conan the Barbarian", time enough for sleep in the grave.
- Jim
JimGolden is offline   Reply With Quote
Old 05-28-2007, 01:35 PM   #45
AgZep's Avatar
2005 28' International CCD
Las Cruces , New Mexico
Yeah, I'm an EAA guy too. I guess we're all alike or something.
AgZep is offline   Reply With Quote
Old 06-25-2007, 03:42 PM   #46
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Hi Jim,
Simply replacing the MDF tabletops with laminate covered AC plywood is a considerable, inexpensive, weight savings. I replace a couple in my Excella, and the new pieces were noticeably lighter to handle. Sorry, didn't weigh the difference.
Vaughan
Old 06-25-2007, 07:08 PM   #47
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I just replaced all my screens with fiberglass type, when I gathered up all the old alum screening it had some weight to it!
'77 Sovereign Intl 31' CB
Old 06-25-2007, 07:32 PM   #48
2007 16' International CCD
Los Angeles , California
Alucobond
Hi,
I have some furniture at home (swiss design) made out of Alucobond.
Originally this material was used for covering buildings and similar, but more and more designers start to use it for furniture, because it's extremely strong, lightweight, very thin (4 mm) and beautiful!
Basically it's made of 2 layers of Aluminium with a core of fire proof composite.
You can order it in many sizes, bend it, cut it any shape you want and it's structurally strong, so no need for a frame.
You can use normal utensils (like for aluminum) for cutting, drilling and folding (V shaped milling for a perfect angle)
It comes in several strengths and colors.
Besides cutting on weight, you also gain space in your Airstream.
I am going to redo my '07 Bambi in this material as soon as I have a good working space.
Alucobond - The World's Favorite Aluminum Composite Material
or google Alucobond furniture.
Sten
sos10 is offline   Reply With Quote
Old 06-25-2007, 08:58 PM   #49
1973 31' Sovereign
Portland , Oregon
Images: 22
Sten,
This looks like pretty interesting stuff indeed! It has been around for along time too and I have never heard of it. I don't suppose it would be strong enough to be used for a sub-floor? Have you been able to get any idea on what pricing would be like. Have you been able to zero in on a stocking distributor?
I would be very interested in seeing how this works out for you. Mostly depending on price I would be interested in considering it for my remodel as well. So please keep us posted on any details you find out about.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 06-26-2007, 08:19 AM   #50
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
This would probably be cost-prohibitive, but you could replace all the wooden counters and framing with Balsa wood. That is what they make many RC airplanes out of. Pick up a piece of Balsa, and a comparable sized piecce of Pine, or Oak, and you will notice a huge weight difference.
Old 06-26-2007, 08:33 AM   #51
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
Back to sandwich construction!
O-63 Great idea! Remember that balsa is soft! So you can still purchase end grain balsa sheets.Different thickness's are available. And not cost prohibitive! Check some of the boat places. Lots of fast boats used this construction method- I used to race J-24's. Strong hulls. The balsa makes a lightweight core, then just glass or use some other material on both sides. You can even bend the end grain some and then glass over it- like if you wanted to make curved bases for new dinete area. Lotsa possibilities, show me the lay up table! As you all know I'm a big fan of composites and vacuum bagging. I'ld really like to make a composite trailer just need a financial backer. DG
www.popasmoke.com
YETI ( 65 Quart )
Old 06-26-2007, 10:25 AM   #52
Central , Mississippi
Composite
How about attending the EAA Composites workshop and get up to speed on Foam cored construction. Then you could build a fully composite frame with integral structural tanks and all sorts of other wiz bang stuff. The attached screen snapshot is a 31 foot composite frame using 45 cubic feet of volume. Anyone know what the mass is of a foam cored structural member? If you'll PM me i'll update the model and post the total weight.
Name:	small frame.jpg
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-26-2007, 10:35 AM   #53
Weight reduction.
The type construction of an Airstream trailer is semi-monocoque, which means that the "shell" is load bearing.
It does not mean that an Airstream flys like an aircraft.
With any aircraft, weight is "extrememly" important.
NOT SO WITH AN AIRSTREAM TRAILER.
Start at the west coast and go to the east coast, with the typical 60 gallons of water on board and nothing else. That payload is 480 pounds.
Duplicate the trip with "NO" water on board. You will find the difference in fuel mileage to be absolutely insignificant.
Unless considerable mountain towing is on the agenda, towing an empty or fully loaded Airstream trailer over a long distance will make almost zero difference in fuel mileage.
That information is based on a study of over 100,000 miles of testing.
Old 06-26-2007, 11:52 AM   #54
2002 19' Bambi
Lafayette , California
Andy, thanks for that information. Now I do not feel so guilty about running so often with a full or nearly full freshwater tank.
I just read through this whole thread again and I cannot help but having the feeling that many suffer from my own problem. That is, thinking how much fun it would be to build lighter and better with weight reduction only a nice excuse for doing the work. I am presently restoring a riveted aluminum rowboat built by my father in about 1950. It is 9 1/2' long, all rounded in shape, and a great accessory for our Airstream. The bare hull weighs 75 pounds, so I have saved a few ounces by making composited (for example, thin marine plywood bonded to rigid urethane foam) pieces for it. Is the weight saving practical? Well, it will increase bouyancy if the boat capsizes, but the existing flotation tanks did quite well when my brother and I were playing with the boat as kids. No, I admit it, I just wanted to see if I could fabricate these parts the way I wished!
Tim A. is offline   Reply With Quote
Old 06-26-2007, 12:45 PM   #55
There are many things that could be done. The question is the cost. Will the retail customer pay for the composite costs? I don't think so.
Traveling with a "full" tank of water, is a must for two reasons.
First, it lowers the center of gravity.
Secondly, blow a heater hose in the middle of no place. All you need is some duct tape to fix the split hose, "plus water." Ah, where oh where would you get that water?
Should this happen, do not tighten the radiator cap and shut the AC off.
It's amazing how many miles you can travel until you can get a hose, just because you have duct tape, "and" lots of water.
You can fret at home.
When you tow your Airstream, do like the boy scouts do.
"Be prepared."
Old 06-26-2007, 01:00 PM   #56
Well Preserved
1993 21' Sovereign
I can back Andy up on this. Mileage towing our Argosy 20 was 10. Mileage towing our 31' Sovereign was...10. If anything, mileage was slightly better towing the Sovereign.
I like lightweight stuff like counters, beause that means I can bring more toys without overloading.
Sovereign weight and Preferred tow vehicle JLD 1974 - 1979 Sovereign 24 06-26-2017 10:17 PM
Weight 1987 34' Excella 83Excella 1987 - 1989 Excella 6 03-26-2003 06:43 PM
weight specs for 68 Overlander 26D PeterH-Airstreamer 1969 Overlander 5 02-08-2003 03:49 PM
Trailer weight Dbraw 1969 - 1973 Safari 3 06-26-2002 12:01 PM
Help find the weight of a 1981 31foot Excella Sharon Lee Our Community 8 06-18-2002 08:55 PM
