Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 02-12-2012, 04:33 PM   #41
1981 31' Excella II
New Market , Alabama
The problem is the water is drawn through cracks as soon as it splashes up against that belly band trim. Water can easily pool under there and get sucked into a crack. The holes might help with pooling but in a heavy rain the water is going to come down the skin and hit that plate and go up under the back of the trailer. The shape of an Airstream produces sheets of water that will keep that area bathed in water whether the holes are there or not. One reason we have trouble stopping leaks is that almost every surface on our trailers gets bathed in water. Rain sheets off of a square trailer(vertical walls) much easier.
If you put a slot back there then the water will sheet off and hit the ground. You don't want it going up under the skins either.
Perry
Old 02-12-2012, 06:07 PM   #42
Maniacal Engineer
barts's Avatar
Lopez Island , Washington
Originally Posted by bhutch74ly View Post
.... Where is the power supply cord/cable for these trailers supposed to be stored when not in use? The only place I see to store it is in the rear bumper compartment with the slinky pipe. I would prefer to keep it elsewhere for obvious reasons.
That's where our power cable comes out from underneath the trailer. Since we don't have black water in the slinky (we have a composting toilet), it works fine to keep the power cord there.
One project I considered was removing the power cord and fitting a Marinco marine outlet & cover on the outside of the trailer. I decided I had more important projects to do and I was pressed for time (camping season!) during the rear end repairs.
- Bart
Bart Smaalders
Lopez Island, WA
https://tinpickle.blogspot.com
barts is offline   Reply With Quote
Old 02-13-2012, 12:44 AM   #43
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
Nothing (almost) is waterproof
I am arelative newbie to these forums but know lots about condensation and how it can impact structures. The outside skin of the Airstream is what is called a leading edge conductor. Simply put cold to warm. The water will form on the inside of the skin and drip.
I would like to look at three perspectives.
My entire family has been in the commercial fishing industry (Salmon, Herring,Sardines, Halibut and sometimes Tuna. At first the boats were wood and they woul repair them with tar and creasote. Nothing kept the water out
My cousin is a maintenance mechanic for Alaska Air and he says the planes ( especially the 737's) are like sponges.
In the 1980's the City of Seattle throuth their infinite wisdom approved construction plans for multifloor wood frame condos covered with drivit.These units were then sealed up so tight that the owners started to have some problems with inside air quality, humidity etc. We were invited to bid on a solution that involved installing outside air inside air exchanges involving fans. For whatever reason we declined. About two years later the buildings were rotting away. It seems the air exchanges created a slight negative atmosphere inside the building which started pulling in the rain. The elastomeric properties of the drivit would not let the walls breathe so the water had no where to go. These buildings literally had a 10 year lifespan. I'm sure the lawsuits are still flying.
I know this has been long but bear with me.
Condensation in Airstreams is here to stay. Everything that is impacted by temp differentials will eventually develop a dew point where the condensation will occur.
I guess having said all of this I think the best advise I can offer is from my Grandpa who would always tell me about the boats."Ya gotta stay up with them kid. Don't let them get away from you". He was of course talking about maintenance and the maintenance on those old ships was tar, oalum and creasote. I love this forum and all of the knowledge. What a community. Hope to see you guys on the road.
Best,
Dan2
danlehosky is offline   Reply With Quote
Old 02-13-2012, 07:40 AM   #44
1981 31' Excella II
I put an L14-30 twist lock on a very short pigtail coming out of the back of my trialer. I only use one of the hot pins but may covert to 220V at some point and use the other pin. I unplug it and put the cord in the side compartment. The sewer pipe goes inside a garbage bag in the same compartment but it will eventually end up in that bumper compartment when I get it finished.
Perry
Old 02-13-2012, 08:16 PM   #45
1975 31' Sovereign
Valparaiso , Indiana
I have just started to restore the my '75 Sovereign and I have the same problem that everyone else has with the back bumper. Can you post a picture of the corrections you've made?
Ken
Boilermaker
boilermaker is offline   Reply With Quote
Old 02-13-2012, 09:03 PM   #46
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
I ended up staining, then coating 3/4" plywood with 2 coats of West Marine Epoxy and then 2 coats of exterior Oil based poly. We'll see how it lasts. I haven't cut any holes in the plywood yet, but will coat the sides of any holes. The chassis/frame was sandblasted and POR-15 was used. After spending the past summer with a completely gutted AS, I have seen the leaks and sealed all interior seams and rivets. I fear I will always have leaks. The second picture shows the rear hold down plate which was POR-15'd. I installed a layer of vinyl between the hold down plate and chassis/floor. Rivets came after this pic. Good luck with your project. I think the AS floor is the weakest link and needs the most protection.
ID:	151084   Click image for larger version
surfpod is offline   Reply With Quote
Old 02-13-2012, 09:26 PM   #47
1974 25' Tradewind
Saint Joseph , Louisiana
Perry
Thanks, I'll probably make a short pigtail with male plug that can reside in the storage box. Then I can roll the power cord up and keep it in a cleaner space somewhere. I suppose another option would be to mount a slinky storage tube (4" ABS pipe with screw-on plug) somewhere under the trailer, but, I'm not sure there is a good place to do so.
bhutch74ly is offline   Reply With Quote
Old 02-13-2012, 09:27 PM   #48
Maniacal Engineer
barts's Avatar
Well, webspinner had both cameras in England while I was doing my repairs... but I did make this drawing. Hope this gives the basic idea....
Everything got Vulkemed during riveting...
- Bart
Bart Smaalders
Lopez Island, WA
Old 02-13-2012, 09:38 PM   #49
1974 25' Tradewind
WOW, the floor looks awesome and should be a lot more resistant to water damage than our original plywood floors. I wonder if it would help to add a piece of flashing around the perimeter of the floor that the U channel would sit on. If the flashing was turned up on the inside of the wall and screwed or riveted to you inner skin and turned downward on the outside of the U channel, I think it would shed any water leaks away from your new floor.
Old 02-13-2012, 09:53 PM   #50
1974 25' Tradewind
- Bart
Thanks for the schematic. This should cure the leak problem and prevent any frame-skin separation. One question---how did you get the stainless steel plate between the plywood and frame member?
Old 02-13-2012, 10:04 PM   #51
Maniacal Engineer
barts's Avatar
The skin was loose from the C channel, and the plywood was not bolted to the floor; it was pretty easy to rotate the angle plate in from the inside. I'd prepunched all the rivet holes in the stainless, so all I had to do was line everything up and drill a hole, Cleco it, and go on to the next.
I replaced the rear 6" or so of plywood; the joint between the existing floor and the repaired floor has a 6" wide buttblock underneath it, glued and screwed w/ #10 laminating screws. The floor in the bathroom is the most rigid part of the floor in the entire trailer.
- Bart
Bart Smaalders
Lopez Island, WA
Old 02-13-2012, 10:47 PM   #52
1974 25' Tradewind
- Bart
Very good. Thanks again.
Old 02-14-2012, 05:08 AM   #53
Retired.
. , At Large
They all leak. The best you can do is seal and re-seal, and keep an eye out for new leaks. I've had 2 year old SOB trailers come in that were not much more than a rolling pile of rotted wood.
Old 02-18-2012, 11:16 PM   #54
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
I'm trying to address these deficiencies on my trailer now and have a thread going to document the process. Take a look at this summary to get my thoughts on the subject http://www.airforums.com/forums/f36/...ml#post1100621.
Steve
Steve Bryant is offline   Reply With Quote
Old 02-19-2012, 12:08 AM   #55
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Best,
Dan2
What if we're all chasing the wrong dog? What if part of the answer would be to have positive dry air pressure ventilation, drying out the condensation instead of trying to seal it in. Anybody remember a few years back (uhh, '75?) when all the cars and trucks came out with a "positive ventilation fan" that always ran for the theory to have good air or less CO poisoning or something. You couldn't turn it off, made your battery go dead and was annoyance if you were stuck next to an exhaust pipe? Would it be reasonably possible to pressure enough to stop some of the micro leaks and dry out the condensation. Without popping window glass.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 02-19-2012, 11:20 AM   #56
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
When builders started sealing houses they had some similar problems because there was little exchange of air between the inside and outside. The air in the houses was becoming nasty and humid. A trailer becomes humid a lot faster because it is not much space and usually a couple of people breathing out water vapor constantly plus washing dishes and showers. I think most of the nasty air comes from cooking and we have plenty of fans for that, but the water vapor keeps building up. We keep vents open and fans on a lot. Sometimes the bathroom vent fan is all that is needed. In the southwest humidity is less of a problem, but it can still matter. The extremes of temperature in any one day out here also contribute to more condensation.
Home contractors came up with ventilation systems using heat recovery technology for well sealed houses. Something like that could be adapted for a trailer. Whether it would work while boondocking would depend on how much power it used. Trailers could be vented while driving if they had the vents cars have and have had for generations.
A question about subfloor sealing:
I am exposing my subfloor by removing the crummy and cheap vinyl sheet. I will be putting in a better quality vinyl floor. So far I don't see any problems with the plywood subfloor but I haven't removed much yet. It has some black stuff painted on the plywood about 6 to 8" from the exterior wall. I suppose it is suppose to seal the plywood. I would like to seal the plywood I expose—the visible floor and in some cabinets where I can get the sheet vinyl out. Epoxy paint seems a lot more than needed at this point—expensive, complicated perhaps. I looked briefly for it and it seems you have to buy big buckets that I don't need. Maybe I'm wrong. And since I can't get to the edges, maybe epoxy makes little sense. If I were replacing whole sheets of plywood, I'd epoxy them, or if I had some soft spots I'd fill them with epoxy. I hope not to find any soft spots; I'd think I'd have felt them through the sheet vinyl. The alternative I'm thinking of is a couple a coats of exterior oil based polyurethane (I think it is better than water based, but I may be wrong about that). The floor will be 3/16" vinyl planks that can lay loose (they are really hard to move on a smooth surface—I've tried it with a large sample) attached to the floor with pressure sensitive glue. With this type of floor and glue, I can remove planks from time to time to check the plywood. Locking planks or tiles have the problem that the locking part can be fragile and once removed, may not go back properly.
Gene
Old 02-19-2012, 03:57 PM   #57
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Hi guys. There's no such thing as a water-tight Airstream. Doesn't exist, never will.
When I ripped the floor out of ours, I followed the generally accepted wisdom on the forums for treating the new floor before it went back in. I used West Marine epoxy around the first 6 to 12 inches against the wall/c-channel/u-channel (including the edges). The rest of the floor got two coats of verathane. t\The bathroom was entirely coated on the top side with epoxy before the vinyl floor covering went in. This was six years ago (damn, I'm getting old).
We now have rot in several places on the new floor, but I hope it's not "fatal".
The roadside radius area up front has a leak that is pretty serious. Given all the precautions I took to seal the floor, I can only surmise that i drilled thru the seal at soem point, causing a route for water into the wood. Result is black rot in the new wood. Under the galley, there's another leak, but I think that was is from the intake/exhaust for the old heater. This one is not too serious and can be repaired fairly easily.
That dang bumper area, on the other hand.....That wood in the new floor is just about shot directly under the rear hatch. The weird part is that it just sneaked up. I never noticed any problem until last fall when I reached in there and noticed the new wood was brittle. This one will have to wait until the winter rains stop and it warms up a little. One thing is certain, tho. I ain't pullin' that bath back out to fix it. There'll be a new way to do floors invented before I go thru all that again.
BUT YOU KNOW WHAT? I'VE ALWAYS WANTED AN AIRSTREAM, AND NOW I HAVE ONE THAT IS FUNCTIONAL. And after 4000 miles of towing it all over the southeast, it's still intact, warts and all.
Keep it in the road, boys and girls and all will be fine. Our 'Stream will be 40 years old in September. Not many people can say that.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 02-19-2012, 04:15 PM   #58
x
XXXX , XXXX
Wow Jim that is indeed devastating news. I feel better about my choice of product to seal the floor. I hope that it will do it's purported job and prevent the wood from absorbing any water. It will be some time before I can test my floor as I have a lot more to do to finish the project.
DIY Wet Basement Waterproofing, Finishing & Flooring, Swimming Pool, Deck & Concrete Crack Repair, Roof & Industrial Floor Coating
wasagachris is offline   Reply With Quote
Old 02-19-2012, 04:41 PM   #59
Wow, that was weird. I had a response typed up that was shear genius and when I hit send, my computer went nuts. Hope I didn't send a launch code to anything at NORAD by mistake.
www.nesa.org
Air No. 6427
Old 02-19-2012, 04:44 PM   #60
Master of Universe
Gene's Avatar
I have about half the vinyl out and found a damp spot by the edge of the door opening by the jamb. It was not very big, but it looks like water has run about 4' inward along the plywood at some time. There is a water stain, but no rot nor mold.
Most likely there's a leak along the rear side of the door or less likely, the panos.
It is snowing now and the good thing is that I may be able to trace the source of the water when the snow melts. The bad thing is I won't be able to put sealant outside for a while, though I may do something temporary. In a few days it will be warmer and I could run some duct tape along the outside to keep it sealed until it is warmer I can use the proper sealant. The problem with that is it is a pain to remove the glue, even with the usual way, WD-40.
Gene
Airstream MH for FT? kb0zke Land Yacht/Legacy Motorhomes 13 10-23-2016 07:28 AM
