Hi all, Wifey here, borrowing hubby's account ...
We have a
1968 Airstream Sovereign with its original gaucho on the tongue end that folds out into a bed. I'm planning on rebuilding the sofa/bed frame to extend front to back, instead of side to side. To gain extra storage for mattresses etc., I'ld like to see if we can orient the 30 gal water tank currently under the bed from horizontal to vertical. I'm pretty sure the tank would fit nicely under the window and I can frame it in to keep it from moving around.
Are there any structural/weight/force issues to consider by turning a tank on its side?
Are the water tanks designed only to lay flat (i.e. would there be too much water pressure on the walls of the tank if I turned it 90 degrees)?
Thanks in advance,
Buffalo-Woman
