Old 08-16-2016, 10:43 AM   #1
Charleston , South Carolina
Wallpapering over interior vinyl walls
Hey there,
We are the proud new owners of a 1974 Sovereign. We had a grand idea to use old nautical maps to wallpaper the interior of the trailer, however unfortunately after doing some reading it seems like we might not be able to go over the vinyl for this? Does anybody have advice on a way to do it without stripping all the vinyl from the trailer?
Thanks!
Whitpasquini is offline   Reply With Quote
Old 08-16-2016, 07:00 PM   #2
GAT
Owner Spirit of "76"
GAT's Avatar
1976 31' Sovereign
Ball Ground , Georgia
My 1976 was so bad inside I had no choice but to completely cover the entire inside. Sounded good to me until I started and it fell off as soon as I put it on. No choice so I painted everything with Kilzs primer. That was five years ago and still doing fine. Just a thought.
A husband is the biggest baby you will have and take the most adult supervision.
Gene and Elaine Thomason
Ball Ground Ga.
1976 31 foot Sovereign
2011 GMC 2500HD Denali
6.6 Duramax Diesel
GAT is offline   Reply With Quote
Old 08-16-2016, 09:48 PM   #3
1979 23' Safari
Wayland , New York
Originally Posted by Whitpasquini View Post
Hey there,
Thanks!
My biggest issue would be that when applied to the walls the paper nautical charts will still be fragile paper and not easy to clean and easy to damage.
Personally I think some 3M Super 77 spray adhesive would probably hold the charts to the walls. You'd probably have to coat the charts with some sort of epoxy you could spread over them to protect them.
Old 08-16-2016, 09:53 PM   #4
cameront120's Avatar
1972 25' Tradewind
Are you in an humid environment and are the charts made of paper? Paper, or anything organic, quickly becomes food for mould and deteriorates. Not something I'd want on my walls as the aluminum skin is a non-porous vapour barrier and interior condensation will be absorbed by the paper in no time at all.
North Vancouver, BC
Old 08-17-2016, 01:26 PM   #5
PammieSue's Avatar
1988 32.5' Airstream 325
Vista , California
If I were to do this, I would print my own maps of all the backpacking and hiking trips I've done, and I wouldn't print them on ordinary paper, I'd print them on waterproof paper made especially for maps. Since I don't have larger than a 10x14 inch printing capability, I would take it to Office Depot or any printer, that has large format printers.https://www.graytex.com/waterproof-map-paper.htm
That ^ was just one company, there are several that make waterproof paper for maps, National Geographic, ZapMeta, Igage, ToughPrint, etc.
So if you would like to print your own maps on waterproof paper, here is a resource for you: http://www.landfallnavigation.com/charts.html
Gat, I have to thank you for the Kilz Primer tip. I have wondered for the last two years how I might go about this and skip the whole stripping work.
Dysfunctional Veteran- does not always play well with others. 20 a day is 20 TOO MANY.
(Approximately 20 Veterans commit suicide everyday. Revised from 19; revised from 20; revised from 23; revised from 22. Even the VA is a work in process)
PammieSue is offline   Reply With Quote
Stripping interior vinyl covered walls Anna Upholstery, Blinds, Walls & Interior Finishes 87 10-12-2014 03:39 PM
Best way to remove Vinyl from interior vinyl clad Eric H General Interior Topics 11 10-21-2013 11:32 AM
Zolatone over Vinyl walls? Roadrunner Upholstery, Blinds, Walls & Interior Finishes 3 10-13-2009 07:03 PM
new vinyl over vinyl cabinets? Aage Cabinets, Counter Tops & Furnishings 28 09-29-2009 07:50 AM
Wallpapering danesh Upholstery, Blinds, Walls & Interior Finishes 11 06-07-2009 01:28 PM
