Old 09-23-2014, 09:24 PM   #1
Oroville , California
Wall replacement options
I'm gutting my late 60s airstream. I'm looking for interior wall replacement options. I may reuse the panels as I can. If I don't replace the bathroom, I'll need all new wall options that can contour the curves. I've seen some people using plywood, and sheet aluminum.
Where can I get a survey of all reasonable wall options?
David95966 is offline   Reply With Quote
Old 09-23-2014, 10:58 PM   #2
Plywood has been the panels for decades.
Old 09-24-2014, 08:49 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Your existing inner skins are made of aluminum. If you want to replace them, then aluminum is the obvious choice. I have heard also of people replacing their interior skins with thin plywood, and of others creating a wood interior by overlaying the plywood over the existing aluminum skins.
You will find some people of the opinion that the interior skins are "structural," and must be of a certain material in order for the shell to have integrity. I would disagree, citing the fact that many people use their trailers as "aluminum tents" without any interior skins, and no harm comes of it. The interiors are also held in place with relatively scant pop rivets, compared to the bucked rivets that hold the shell together 1 per inch or so.
My biggest concert about replacing the interior skins with anything beside aluminum would be how it will react to changing humidity, heat, and exposure to leaks. I have been in plenty of old neglected trailers, that once had beautiful birch plywood interiors, that have now become stained and warped with age.
good luck!
Old 09-24-2014, 01:08 PM   #4
good luck!
Monocoque construction, means a "load bearing shell".
Airstream is actually semi-monocoque, in that the load bearing shell is not 360 degrees around, like metal Aircraft.
The interior shell is just as important as the exterior shell.
Also, many owners do not know that the Airstream frame, does not support the shell, but the shell indeed, supports the frame.
That's why adding more weight to the rear frame, if not done properly, will cause a rear end separation, even faster.
Ask those that have been there, done that.
Wall to Ceiling attachment - Head Wall 2003 25' safari Clawdan General Interior Topics 1 11-27-2011 10:01 AM
AC replacement-options, options... Belegedhel Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-13-2011 08:54 AM
wall covering??? leather, Wall paper Josh Loki General Interior Topics 1 07-02-2011 10:16 AM
Shower Wall Coverings - What are my options? BrockLives Sinks, Showers & Toilets 7 05-15-2009 12:19 PM
Wall-to-wall carpet alternative mcneon Upholstery, Blinds, Walls & Interior Finishes 9 11-20-2008 01:41 PM
