Old 01-03-2010, 09:17 AM   #1
greatlakes's Avatar
2004 25' Safari
N/A , Michigan/Florida
Wall-Mounting TV
I just purchased a 2004 25' Safari in excellent condition and it does not include a TV set.
I am about to purchase a flat screen of appropriate size proportion to the area and would like to wall-mount it on the internal partition that separates the fridge from the eating area over the adjacent cabinet. See attached photo.
Any recommendation as to how to mount a wall bracket (hardware?) and what kind of structure that wall has to accommodate such installation?
Thank you in advance.
___________________
Frank
2004 25' Safari
2010 4x4 Ford EB Expedition
greatlakes is offline   Reply With Quote
Old 01-03-2010, 09:42 AM   #2
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
The safest mount would be with a metal back plate which would involve pulling out the fridge to get behind the wall. Faced with the same problem, I installed a horizontal mount on the shelf in the picture. Using a back plate here was simple. The best part of this mount is that the TV is at eye level.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 01-03-2010, 09:53 AM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Here is a thread for you. http://www.airforums.com/forums/f450...een-43440.html and http://www.airforums.com/forums/f450...-fb-43062.html and http://www.airforums.com/forums/f450...ps3-58150.html. OK, I got carried away.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-03-2010, 10:18 AM   #4
Chasmorgan's Avatar
1999 23' Safari
Antique Peddler: I too am faced with the same mounting problem and have considered you solution as the best. Could you post a picture of your setup? Thanks
Chasmorgan is offline   Reply With Quote
Old 01-03-2010, 10:27 AM   #5
fmrcaptevil's Avatar
Weldon Spring , Missouri
Unless you desperately need the table-top space for something more important, I would leave the TV on the table.......it will certainly be more attractive (cable & power cord will be less obvious, and no dangling strap from the wall-mount)......drawback is you'll have to remember to secure it every time you move the trailer.
fmrcaptevil is offline   Reply With Quote
Old 01-03-2010, 10:42 AM   #6
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Sorry, that was in the '07 which we don't have any more. I googled horizontal mounts to find the one I got. Then thru bolted it with big washers to the shelf as far back to the corner as the TV (15"} would go and still swivel. All the wiring was coiled behind the TV, where the the wall outlet was located, so I didn't have to deal with hiding them in a wall mount.
Antique Pedaler
Old 01-03-2010, 11:00 AM   #7
Lothlorian's Avatar
Loganville , Georgia
I bought a bracket wall mount that allows me to pull the T.V. out and swing it around. I bolted the bracket to a cut 1" X 6" X 8" stained board. I mounted the Stained board on the wall you have in your picture to even out the stress from the weight. My wonderful children bought a 19" flat panel T.V. for me which I hung on the wall. I will upload a picture. I bought the bracket off of e-bay.
I have since moved all the electical components under the crendeza and have the wires coming out of a small hole. I also have wired my my TV to all surround sound, and put a DVD in. I bought a car radio with an auxillary jack to run my TV/DVD sound through. I put in cheap Wal-mart speakers in the same speaker holes the old speakers were in. It works great.
Brian
Name:	hiding wires tv.jpg
ID:	93415   Click image for larger version
Name:	2stereo cabinet.jpg
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 01-03-2010, 11:34 AM   #8
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Everyone has their own opinion on what works best in their trailer. To me, table top space is of great value. I mounted on the wall and take down whenever we are on the road. All it takes is loosening one screw and off it comes. I also made a shelf for the coffee pot to get more table top space.
ID:	93417   Click image for larger version
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 01-03-2010, 12:28 PM   #9
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Coffee Pot
RLS- great idea and job on the coffee pot shelf. Can you post another pic that shows where in your kitchen the shelf is?
Thanks in advance.....Tim
tkasten is offline   Reply With Quote
Old 01-03-2010, 01:25 PM   #10
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Tim, here ya go!
Julia & Bob
W/ Deedee & Boo
AIR #30685
Old 01-03-2010, 01:46 PM   #11
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Never done it, but that is exactly what I was thinking I might likely do if faced with teh situation.
In fact I think I might be inclined to use a metal backing plate like a sandwich on either side of the wall - but then I always to tend to go for overkill!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-03-2010, 02:09 PM   #12
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Bob...really like the coffee shelf...believe I might incorporate that into our "78" Ambassador. Would it be unsafe to travel with the flatscreen still mounted to the wall? Could it be anchored so as not to more? Thx!
Roadrunner is offline   Reply With Quote
Old 01-03-2010, 02:46 PM   #13
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Coffee Shelf Pic
Bob - thanks for the pic. This is a really great idea and you installed it very well.....Tim
Old 01-03-2010, 03:24 PM   #14
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
This is a 23" TV & DVD unit, so there is some weight to it. I think it could be left up if the wall unit had a plate mounted to it on the other side of the wall it is mounted on. I would then just use a strap to hold it secure to the wall. Mine just has some good size screws that are spread out some to hold it up and I use another mount in the bedroom so I am able to switch rooms with it.
ID:	93437   Click image for larger version
Julia & Bob
W/ Deedee & Boo
AIR #30685
CB antenna mounting slapshot1031 Argosy Motorhomes 1 02-13-2010 01:19 PM
Wall-to-wall carpet alternative mcneon Upholstery, Blinds, Walls & Interior Finishes 9 11-20-2008 01:41 PM
Regulator Mounting? dnrtheil LP Gas, Piping, Tanks & Regulators 2 04-03-2008 11:27 AM
tv mounting katsix Audio, Video & TV 4 01-01-2008 08:01 AM
Help Mounting LCD to Wall Italiano86 Audio, Video & TV 26 08-13-2007 07:38 PM
