01-03-2010, 09:17 AM
2004 25' Safari
N/A
, Michigan/Florida
Wall-Mounting TV
I just purchased a 2004 25' Safari in excellent condition and it does not include a TV set.
I am about to purchase a flat screen of appropriate size proportion to the area and would like to wall-mount it on the internal partition that separates the fridge from the eating area over the adjacent cabinet. See attached photo.
Any recommendation as to how to mount a wall bracket (hardware?) and what kind of structure that wall has to accommodate such installation?
Thank you in advance.
___________________
Frank
2004 25' Safari
2010 4x4 Ford EB Expedition
01-03-2010, 09:42 AM
Antiquepedaler
2010 25' FB Flying Cloud
Laramie
, Wyoming
The safest mount would be with a metal back plate which would involve pulling out the fridge to get behind the wall. Faced with the same problem, I installed a horizontal mount on the shelf in the picture. Using a back plate here was simple. The best part of this mount is that the TV is at eye level.
Antique Pedaler
2021 Caravel 20 FB
01-03-2010, 09:53 AM
1967 22' Safari
1960 Caravel
Edmonds
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
01-03-2010, 10:18 AM
1999 23' Safari
Austin
Antique Peddler: I too am faced with the same mounting problem and have considered you solution as the best. Could you post a picture of your setup? Thanks
01-03-2010, 10:27 AM
Weldon Spring
, Missouri
Unless you desperately need the table-top space for something more important, I would leave the TV on the table.......it will certainly be more attractive (cable & power cord will be less obvious, and no dangling strap from the wall-mount)......drawback is you'll have to remember to secure it every time you move the trailer.
01-03-2010, 10:42 AM
Antiquepedaler
Laramie
, Wyoming
Sorry, that was in the '07 which we don't have any more. I googled horizontal mounts to find the one I got. Then thru bolted it with big washers to the shelf as far back to the corner as the TV (15"} would go and still swivel. All the wiring was coiled behind the TV, where the the wall outlet was located, so I didn't have to deal with hiding them in a wall mount.
Antique Pedaler
2021 Caravel 20 FB
01-03-2010, 11:00 AM
Loganville
, Georgia
I bought a bracket wall mount that allows me to pull the T.V. out and swing it around. I bolted the bracket to a cut 1" X 6" X 8" stained board. I mounted the Stained board on the wall you have in your picture to even out the stress from the weight. My wonderful children bought a 19" flat panel T.V. for me which I hung on the wall. I will upload a picture. I bought the bracket off of e-bay.
I have since moved all the electical components under the crendeza and have the wires coming out of a small hole. I also have wired my my TV to all surround sound, and put a DVD in. I bought a car radio with an auxillary jack to run my TV/DVD sound through. I put in cheap Wal-mart speakers in the same speaker holes the old speakers were in. It works great.
Brian
Brian & Adrienne
01-03-2010, 11:34 AM
2004 25' Classic
Prescott
Everyone has their own opinion on what works best in their trailer. To me, table top space is of great value. I mounted on the wall and take down whenever we are on the road. All it takes is loosening one screw and off it comes. I also made a shelf for the coffee pot to get more table top space.
Julia & Bob
W/ Deedee & Boo
AIR #30685
01-03-2010, 12:28 PM
1965 22' Safari
Vassar
, Michigan
Coffee Pot
RLS- great idea and job on the coffee pot shelf. Can you post another pic that shows where in your kitchen the shelf is?
Thanks in advance.....Tim
01-03-2010, 01:25 PM
2004 25' Classic
Prescott
Tim, here ya go!
Julia & Bob
W/ Deedee & Boo
AIR #30685
01-03-2010, 01:46 PM
2005 30' Classic
Burlington
, Ontario
Never done it, but that is exactly what I was thinking I might likely do if faced with teh situation.
In fact I think I might be inclined to use a metal backing plate like a sandwich on either side of the wall - but then I always to tend to go for overkill!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
01-03-2010, 02:09 PM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Bob...really like the coffee shelf...believe I might incorporate that into our "78" Ambassador. Would it be unsafe to travel with the flatscreen still mounted to the wall? Could it be anchored so as not to more? Thx!
01-03-2010, 02:46 PM
1965 22' Safari
Vassar
, Michigan
Coffee Shelf Pic
Bob - thanks for the pic. This is a really great idea and you installed it very well.....Tim
01-03-2010, 03:24 PM
2004 25' Classic
Prescott
This is a 23" TV & DVD unit, so there is some weight to it. I think it could be left up if the wall unit had a plate mounted to it on the other side of the wall it is mounted on. I would then just use a strap to hold it secure to the wall. Mine just has some good size screws that are spread out some to hold it up and I use another mount in the bedroom so I am able to switch rooms with it.
Julia & Bob
W/ Deedee & Boo
AIR #30685
01-03-2010, 03:40 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
That was our solution also, 32" Sharp Aquas fits nicely on an angle with the blu-ray player next to it on the shelf under the window. Easy to bring in the house for Winter storage or for the upstairs bedroom if needed.
I feel better having it wrapped in a microfiber blanket well secured for travel, hanging on the wall... not so much.
01-03-2010, 05:28 PM
2007 25' Safari FB SE
Sugar Land
SANUS VM2 Used
I mounted a Vizio 22 in the Safari on a Sanus VM2 articulated mount.
IT weighs about 11 Lb. The trailer alrady had the same mount int he Bedroom so I just duplicated the install in the "salon". It's a fairly long metal plate with just two rather hefty wood screws (one top and one bottom). I;ve not traveled w/ the TV on the Wall and doubt I ever will.
SailAS
01-11-2010, 09:43 PM
2005 31' Classic
Cleveland
, Tennessee
RLS:
How did you mount it to the wall/partition which backs up to the fridge? Seems pretty thin?
Thanks, Steelegood
I know you think you understand what you though I said, but I'm not sure that what you heard is what I actually meant!
"If you don't know where you are going, any road will take you there." Lewis Carroll
AIR #38011
TAC TN-4
NOVA
01-12-2010, 03:08 AM
Loganville
, Georgia
I attached a board 1" x 6' x 8' on the thin wall to distribute the weight load. I put a screw in each corner of the board and 2 toward the center. It worked great.
Brian
Brian & Adrienne
01-12-2010, 07:12 AM
Sugar Land
I did not use any "backing plate" or any further "distribution" method for the mount (the mount is over 6" between screw holes) . Since the TV is pretty light & we do not travel with the TV on the mount, there is just the static load to handle. Most of the load is on the top screw which is 1/4" diameter.
The wall thickness in the Salon should be the same as next to the Shower (FB model) and I figured if the previous owner got away with this mounting approach, I could as well. I woul dnot suggest this for a heavier set or for traveling.
We'll see. Worst case is I will end up with two screw holes in the Salon wall and will have to use a "distribution plate".
One method you coudl think about is to use "captive nuts". You would need to cut a tapered slot in the wall, put the nut thru the slot and slide it up to the narrow end. You could then "bolt" the mount to the wall.
SailAS
01-12-2010, 07:31 AM
2004 25' Classic
Prescott
As stated above, the wall thickness is about 1/2" so I made a plate to distribute the load a little better and used 4 good sized screws. It has worked for over 1 yr and is as tight now as when first put up. I would NOT trust it for traveling. If you want to leave it up, then pull the frig. out and put a plate of some kind on the inside of the wall.
Julia & Bob
W/ Deedee & Boo
AIR #30685
