Old 06-16-2009, 06:47 PM   #1
1977 Argosy Minuet 6.0 Metre
SPOTSYLVANIA , Virginia
wall flexing
Added a fold down table to my 77 argosy on the side wall between two wall studs. Looks great except the wall flexes and the table wobbles sideways. Is there any way to stiffen up that wall short of running a strip inside from rib to rib. Piano hinge is pop riveted to interior wall. Thanks
vcu70 is offline   Reply With Quote
Old 06-16-2009, 07:11 PM   #2
You could put the hinge on a backer of wood or metal, long enough to span the two ribs in the wall and attach the backer to the wall framing. It only would need a piece of aluminum about 1/8 to 3/16" thick and maybe 1-1/2 to 2" wide. It could be screwed to the framing in the wall, but I wouldn't use pop rivets for it in this kind of situation. Pop rivets are okay for the hinge as long as you use all of the available holes.
If that doesn't work I have some other ideas
Rich
VIKING is offline   Reply With Quote
Old 06-21-2009, 03:24 PM   #3
ran a 1 by 4 -worked perfect-table is solid
Wall-to-wall carpet alternative mcneon Upholstery, Blinds, Walls & Interior Finishes 9 11-20-2008 01:41 PM
wall mounted tv Sherm Nelson Audio, Video & TV 5 06-22-2006 09:53 AM
speakers on wall brunoffrance Audio, Video & TV 0 05-22-2006 12:41 PM
Why isn't gaucho up against the wall? outerbanksdeb Interior Restoration Forum 3 02-05-2005 07:46 PM
How do you get to the rear wall? AccessMaster Airstream Motorhome Forums 1 08-24-2003 06:27 PM
