Old 06-30-2011, 11:00 AM   #1
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Vulkem not on horizontal seams?
My AS has Vulkem on the endcaps and window but not on the horizontal seams. Is there a reason for this other than saving money?
ID:	133617   Click image for larger version
Darkspeed is offline   Reply With Quote
Old 06-30-2011, 12:49 PM   #2
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Right, I have a similar question. And then there's product called Acryl-R Seam Sealer, which claims it is for use on ALL of these places. The documentation states; "For use on segment seams, Airstream built windows, beltline, rubrail, tail lights, clearance lights, exterior connections and components." What's up with all this?
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 06-30-2011, 12:56 PM   #3
Darkspeed's Avatar
1972 31' Sovereign
Everywhere there was a seam with no Vulkem there is corrosion and intrusion under the clear coat. Seems like it should be sealed from the factory.
Can I just seal it with Vulkem ???
Old 06-30-2011, 02:05 PM   #4
x
XXXX , XXXX
That's what I did after removing the corrosion. There are aircraft products for treating corroded aluminium before sealing. I sealed inside with Vulkem and outside with Parbond. Top's thread on abby's seperation H has a link to the products he used to stop the effects of the corrosion.
wasagachris is offline   Reply With Quote
Old 06-30-2011, 03:28 PM   #5
Darkspeed's Avatar
1972 31' Sovereign
Which Vulkem is the correct Vulkem ? For this job
Bursting At The Seams Woodywhite Water Heaters, Filters & Pumps 4 07-10-2011 10:08 PM
Sealing Seams jerryc41 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 05-03-2011 03:53 AM
Leaks and seams zenairman Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 04-03-2011 09:10 AM
abs plastic seams cracked rayandre Sinks, Showers & Toilets 5 02-15-2011 03:56 AM
shower wall seams - need solution adwriter73 Sinks, Showers & Toilets 4 02-09-2011 10:01 AM
