Old 10-30-2015, 05:14 PM   #1
Lexxy's Avatar
1973 23' Safari
Brevard , North Carolina
Images: 16
Vinyl inserts for aluminum riveted strips in 73 Safari
I need 1 1/8" vinyl to replace the strips that crumbled when I removed the rivets in the aluminum strips in the bath. There are so many available but they are not wide enough. Is there some place I can get flexible vinyl to cut. I tried vinyl siding but it didn't slide well. I tried vinyl tape but it eventually peeled off. I saw some for $1 a foot but that's a bit expensive.
Does anyone have any ideas?
Lexxy
After circumnavigating on 40' sailboat, cruising the USA in our '73 Safari, Tara!
Lexxy is offline   Reply With Quote
Old 10-30-2015, 05:31 PM   #2
Southwestern , Ohio
Is this the stuff you're looking for?
Vinyl Bath Insert
Nuvite-F is offline   Reply With Quote
Old 10-30-2015, 05:38 PM   #3
Central , Mississippi
I have a question...
How do you get that dang stuff into the slot? If you bend it very far it stresses and turns white. At the end of the cut, how do you work in the very last end?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 10-30-2015, 07:32 PM   #4
Lexxy's Avatar
1973 23' Safari
Images: 16
I thought I had checked vintage but wouldn't you know it would be there. I will check with them and make sure it will fit. Thanks.
I want to know about that installation also. I thought I'd lubricate it and slide it in.
Lexxy
Old 10-30-2015, 07:47 PM   #5
bigjohnn's Avatar
los lunas , New Mexico
I bought for my bath it was hard as a rock could not install it .It would brake up
bigjohnn is offline   Reply With Quote
Old 10-30-2015, 07:50 PM   #6
Lexxy's Avatar
1973 23' Safari
Images: 16
Perhaps a heat gun would soften it to make it pliable.
Lexxy
Old 10-30-2015, 09:03 PM   #7
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
I used strips of Formica from my dining table. Worked great, looks good, not original.
DryFly is offline   Reply With Quote
Old 10-30-2015, 09:06 PM   #8
Lexxy's Avatar
1973 23' Safari
Images: 16
The Formica.....did you just slide it in .....doesn't bend does it?
Lexxy
Old 10-30-2015, 09:15 PM   #9
1974 Argosy 20
Kooskia , Idaho
Cut thin strips of Formica. But the best replacement (non original) is to take vertical venetian blind slats (go to a window covering store for a huge selection) and cut them down to the right size. Squeeze them slightly to bow them in the center and they will slip right into the Aluminum track. The thing that is so nice about the venetian blind slats is that there are a huge number of types and patterns available and you can really dress up the interior with a different choice than the white vinyl they had originally. Also, some trim like the light covers use very wide material, and the blind slats will work there too.
Old 10-30-2015, 09:18 PM   #10
Lexxy's Avatar
1973 23' Safari
Images: 16
That's a terrific idea....I have a bunch of spares that came with my house. Gonna try it soon.
Lexxy
Old 10-31-2015, 12:12 PM   #11
1992 29' Excella
1972 27' Overlander
Wakefield , Rhode Island
See also:
http://www.airforums.com/forums/f38/...oom-50968.html
msimon is offline   Reply With Quote
Old 10-31-2015, 12:21 PM   #12
Lexxy's Avatar
1973 23' Safari
Images: 16
Irdroba you are brilliant. Those vinyl strips from vertical blinds are so easy to cut....and ends up being 1/4 the cost of the brittle stuff. Solved my problem
Lexxy
Old 10-31-2015, 05:23 PM   #13
1971 23' Safari
Grass Valley , California
Vinyl bath inserts
I had the same problem with my 73 Safari. I found some paint I liked at HD and noticed the vinyl strip door material as I was browsing. Bought both and experimented at home with cutting the strips, no problem, very flexible paint holds nicely, material has a slight texture so is shows similar to original.
Good Luck
levan is offline   Reply With Quote
Old 10-31-2015, 05:39 PM   #14
Lexxy's Avatar
1973 23' Safari
Images: 16
What is vinyl strip door material?
Lexxy
Vinyl inserts in rub strips '75 Overlander Britbat Exterior Restoration Forum 1 07-22-2015 04:11 PM
Argosy exterior vinyl strips kontiki All Argosy Trailers 8 02-14-2007 05:47 PM
Orange vinyl inserts for Argosy juel Clearcoat, Exterior Paint & Trim 8 11-21-2005 02:54 PM
Vinyl side strips for '76 26' Argosy Fulbright All Argosy Trailers 11 11-05-2005 09:14 AM
Installing vinyl inserts juel All Argosy Trailers 5 12-14-2004 05:01 PM
