Old 10-31-2015, 06:33 PM   #15
1974 Argosy 20
Kooskia , Idaho
For everyones information, I learned the cut down vertical venetian blind slat trick and idea from someone else's post here on the forums years ago. I don't know who that was but it does work very well. Thanks to them, whoever they were.
Old 10-31-2015, 06:35 PM   #16
1971 23' Safari
Grass Valley , California
The doors are made up of several strips of 3 to 4 inch material about 76 to 80 inches long. You can get just the strip replacements on line at Home Depot, I chose to purchase the full door. It comes in white, off white, i think some other colors. I chose white because I wanted to paint it yellowish to match what I currently have. It is the same latex paint I have on my kitchen walls. I painted it cut it the width and length I wanted and slid it into the track. When I could not slide it in I bent the width, dropped one edge into the track and let the other slide in. One piece kinked but I was able to straighten it out with a screwdriver and after a day you could't tell anything happened to it.
levan is offline   Reply With Quote
Vinyl inserts in rub strips '75 Overlander Britbat Exterior Restoration Forum 1 07-22-2015 04:11 PM
Argosy exterior vinyl strips kontiki All Argosy Trailers 8 02-14-2007 05:47 PM
Orange vinyl inserts for Argosy juel Clearcoat, Exterior Paint & Trim 8 11-21-2005 02:54 PM
Vinyl side strips for '76 26' Argosy Fulbright All Argosy Trailers 11 11-05-2005 09:14 AM
Installing vinyl inserts juel All Argosy Trailers 5 12-14-2004 05:01 PM
