Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 08-15-2010, 10:11 AM   #1
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Various Types Of Help Needed
I have the bathroom floor in, photo 1. Now, as I look around the Overlander I see a few more things I need help with. Photo 2 - where does this go and what is it for. I think it goes in photo 3 over the little hole but when I took the rear panel off it just fell out, so I don't know for sure. Photo 4 an 5 - what caused this and how exactly am I supposed to fix it. It is the panel that is connected to the frig. Where can I get the parts for the hood and Astrodome. Shown in the rest of the pictures. Thanks Everyone.
ID:	108815   Click image for larger version
ID:	108817   Click image for larger version
ID:	108819   Click image for larger version
ID:	108821   Click image for larger version
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 08-15-2010, 10:32 AM   #2
Wabbiteer's Avatar
Jupiter , Florida
Andy would say running gear problems in the past
I did a quick check and see no photos or commentary about your 27's shells entire outrigger - floor - shell condition. How are your outriggers?
My 73' had similar partition damage and I eventually found it had terrible outrigger damage: From accidents with a few folded up and even replacements with busted welds; rusted out pieces, failed & missing shell hold down bolts, flooring damaged by dry-rot and no longer holding the shell C-frame since it had softened.
If you have outrigger damage the flex is transmitted elsewhere, might be the other side and ten feet fore or aft but the movement is telegraphed elsewhere.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Types of brakes that comes on AS davidachoi Hitches, Couplers & Balls 9 02-25-2008 08:04 PM
Makes? types? Models? tenrsingr 1970 - 1973 Sovereign 8 12-08-2005 02:41 PM
Rivet Types lee Ribs, Skins & Rivets 2 08-02-2003 07:59 AM
