Old 08-24-2019, 07:06 PM   #1
1976 27' Overlander
Milwaukie , Oregon
Using foam board insulation under subfloor
Hey guys. I saw a thread on here where one of the airstreamers used foam board insulation screwed into the underside of the subfloor. I like this idea, and plan to do something like this myself. What I don't want to do is trap water against the subfloor in the event water makes it's way between the wood and the foam board. Would it be wise to use some sort of standoff to create an air gap between the wood and the foam? Would I want to create a way to ventilate said air gap or do I want to seal things as good as possible to maintain the best insulation?
Thanks for any pointers!
(PS - Using 3/4 ACX subfloors with West Systems marine epoxy to cover the entire tops of subfloors, outer edges, and about 10" of the underside edges of the wood, leaving the central underside non-epoxied to allow the wood to breath and dry in event of a leak.)
JoleneAS is offline   Reply With Quote
Old 08-24-2019, 07:59 PM   #2
SandKSmith's Avatar
Phoenix , Arizona
Hi, I’m doing that now on my Safari. We had a vent not closed tight when it was shipped to us last January. We didn’t realize the subfloor was soaked until 2 weeks ago. Anyway, we pulled down what Airstream calls insulation to let it dry.
I had the same concerns about putting the insulation against the subfloor. We made “hat” sections to space the insulation board 1/2” from the floor. I made them out of 20 ga stainless steel- because that’s what I had (we own a sheet metal shop) and screwed them to the underside of the floor. I put some rivnuts on the flat section so I could screw the foam board to to them. I was worried that sheet metal screws would come loose over time. Screws will have a drop of Loctite on them.
Key is going to sealing around the gap between the floor and the insulation otherwise the insulation won’t be effective. My plan, although I didn’t have time to try it today, is to use expanding foam around the parameter of the panel and put it in position before it cures. It should make a form fitting gasket against the subfloor. I hope.
In the photo, you can see the headless screws that will punch through the insulation board when dry fitting it so I can locate where the screws go. That part works great.
I’m traveling all week so it will be next weekend before I get this done. I’ll let you know how it goes.
Steve
SandKSmith is offline   Reply With Quote
Old 08-24-2019, 08:07 PM   #3
1966 22' Safari
Fredericksburg , Texas
Steve, great idea using headless screws. Can’t go wrong doing that to line up perfectly.
Bubba L is offline   Reply With Quote
Old 08-25-2019, 11:05 PM   #4
1976 27' Overlander
Milwaukie , Oregon
Steve, looking forward to seeing what you end up doing! That looks like a great idea.
Old 08-26-2019, 10:59 AM   #5
Rltports's Avatar
2015 25' Flying Cloud
Bettendorf , Iowa
Following
Rltports is offline   Reply With Quote
Old 08-26-2019, 12:39 PM   #6
PEN
2019 27' Globetrotter
Bryant , Arkansas
Following
Paul & Deb
PEN is offline   Reply With Quote
Old 08-26-2019, 12:42 PM   #7
1981 31' Excella II
New Market , Alabama
Just make sure you have a path for water to get out and put some sort of spacers between the foam and floor. I chose to leave most of my floor uninsulated.
Perry
Old 08-26-2019, 01:11 PM   #8
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
foam board, fiberglass, or spray insulation can all be used.
the issue is that the metal beams are a thermal break and will provide cold spots in cool conditions as they will transmit the heat through
waninae39 is offline   Reply With Quote
Old 08-27-2019, 03:01 PM   #9
1974 25' Tradewind
Lexington , Kentucky
No floor insulation
Tough subject that's hard to prove / verify BUT..... what we did was to not insulate under the floor or reinstall a belly pan thinking how much temperature difference can it be without them and is it worth the trouble ?!
We replaced 1/3 of the frame and floor (primed & painted frame with Rust Oleum, plywood sealed) and then sprayed the under floor wood with undercoating & truck bed sealant. The insulation is going to get wet and hold moisture and rot the frame again. Sure the wood & frame gets wet BUT it dries within a day or so.
Anyway...insulation: we camp only when the night temperature stays roughly above 30* and I very much like the idea of spending a little more $ for heat or A/C than letting the smell of wet underfloor insulation (that will hardly ever dry out) permeate the living area.
The Twinkie is offline   Reply With Quote
Old 08-28-2019, 06:50 AM   #10
1981 31' Excella II
I have to agree. Insulation is going to cause problems if you have leaks. I ended up putting drains in the C-channel to funnel water out of that area above the floor and run it to the belly pan where it will run out. If it is a 3 season trailer, then it is not worth the trouble. I also have not covered my floor so I can find and deal with leaks that might occur.
You loose way more heat to the ribs around the shell since there is no thermal break between them and the outside shell.
Perry
Old 08-28-2019, 12:15 PM   #11
1976 27' Overlander
Milwaukie , Oregon
I can definitely see the argument to insulate vs not insulate. I’m in favor of insulating personally. While I agree that there are areas that reduce the efficacy of insulation (such as thermal transfer via the ribs), I’m of the philosophy that something is probably better than nothing, assuming it can be applied in such a way to not promote rotting of the subfloor. I definitely don’t plan on dealing anything entirely though and want my solution to be able to breath when water inevitably makes it in.
Old 08-31-2019, 08:33 PM   #12
SandKSmith's Avatar
Phoenix , Arizona
I finished the insulation under the floor in the rear of our 25’ FB. The hat sections I made are approximately the same height as the frame substructure so I could run the panel the full width of the airstream rails. I was going to seal with insulating foam but later decided to use aluminum tape to seal the big gaps. Most of the edges are up against the frame structure but not sealed tight. If water does get between the floor and insulation, there is a way to seep out.
I was able to get nearly the full width between the frames by scoring / breaking the panel to form a shallow V to get it in position then pressing it flat. My panel has foil on both sides so one side acted as a hinge when I scored/broke the panel.
I’m happy with how it all turned out. The top side is sealed with a penetrating epoxy so I’m not too worried about water getting through the floor to the insulation.
ID:	350989   Click image for larger version
Rigid foam board insulation in belly..XPS or EPS? Jeremy9107 Repairing/Replacing Floor &/or Frame 4 02-19-2018 10:57 PM
Insulation- Prodex or Foam Insulation Board? Danny Z General Interior Topics 7 08-26-2015 08:21 PM
Foam board thehandyman General Repair Forum 2 08-20-2013 07:20 AM
expanding foam insulation DinubaDave Exterior Restoration Forum 8 06-30-2005 08:19 AM
Foam Insulation? Aluminum? Loose Curtain Rails? Revamp Goucho? 74Argosy24MH General Interior Topics 4 02-03-2005 08:39 PM
